2010 2011 BMW 5 Series Forum F10 Heating system - confused! |
02-14-2015, 12:07 PM | #23 | |
Rep 114
If I cranked mine up to 25 I'd be asleep at the wheel in no time... |
02-14-2015, 02:01 PM | #24 |
Rep 158
Turning the AC on and off should make no difference to the output temperature of the air (unless it's warm outside). The AC is there just to reduce the humidity of the air, which helps comfort, alertness and it stops any misting. Keeping it on also prolongs the life of the system.
02-14-2015, 02:33 PM | #25 | |
Rep 114
Definitely true that keeping it on is best to extend the life of the aircon system though. Might be worth the OP spending money on some thermals |
02-14-2015, 03:52 PM | #26 | |
Rep 15,858
If you set a cabin temperature say to 22C and the ambient is 5C, the CC will heat the cabin to 22C as efficiently as possible. How does having the A/C on (or off) change the request to heat the cabin to 22C? You are not requesting a cooling function when the cabin is below 22C. I see no difference in heating the inlet air from say 5C ambient temperature across the evaporator (when A/C is off), or across the evaporator running 5C with the A/C on, the heating side of the HVAC must perform the same function to fulfil a request to heat the cabin to 22C. What is your reasoning for the A/C function blocking the heating requirement? Mine heats effectively from low temperatures with A/C left on for dehumidifying and conditioning the inlet air flow, as I expect it to. As have all the cars I've owned with climate control. HighlandPete Last edited by HighlandPete; 02-14-2015 at 03:59 PM.. |
02-14-2015, 04:15 PM | #27 |
Rep 186
02-14-2015, 04:26 PM | #28 |
Rep 619
^^ I am in agreement with Pete and Gordon, my climate is on all the time, and if I ask for hot air, my vents will blow really hot air
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
02-14-2015, 04:34 PM | #29 |
Rep 215
I have this... and it doesn't seem right, none of the other BMW's I've owned over the years have done this... Can we see if we can figure out if it is an LCI thing... build date thing etc?
Mine is a Sept 2014 build with the B47 engine. |
02-14-2015, 05:05 PM | #30 |
Rep 114
Aircon works by taking in air, cooling it, then heating it again accordingly. If you remove the cooling part from the equation by turning off the A/C, you'll find that you can heat your car a lot quicker.
http://www.bmw.com/com/en/insights/t...ditioning.html |
02-14-2015, 05:45 PM | #31 | ||
Rep 15,858
As I understand HVAC function, it is only really more efficient in heating, if the ambient air is above the evaporator working temperature range (>8C) and not being cooled down first by the A/C function. At higher ambient temperatures heating is not so critical anyway, as the temperature differential is less, so heating is more rapid. If I'm missing something here please enlighten me. HighlandPete |
02-14-2015, 05:56 PM | #32 | |
Rep 15,858
We'd also need to see if it only a basic CC function and/or with the extended features CC. HighlandPete |
02-15-2015, 08:55 AM | #33 |
Rep 619
Mine is a Nov 13 LCI, no issues here as mentioned
02-18-2015, 06:08 AM | #34 |
Rep 835
So i was testing this out again yesterday. I set the heating to 27, hot even by my standards. But the car was already warm, i wasn't uncomfortably cold or anything, but nevertheless the heating on my side was 27 passenger 25.
I closed the middle vents to rule them out of the equation. My drivers side right hand vent was blowing cold air, not freezing, but certainly not 27. I'd guess somewhere around 19. Like i said, the air in the car was not cold overall, so whether the vent SHOULD have been blowing cold air is what I'm asking. I am presuming that it tries to main the set temperature in the car and therefore needs to blow cold sometimes if the car gets too warm. However it seems to always be blowing cold. It's really confusing, I don't understand it and my last BMW didn't do this at all, I'm sure. If i wanted hot air, I got it. Also, in any older car I've had without climate, if I turned the dial to Red, the vent would blow hot air. With climate in modern cars, can the same be achieved? I.e. can I, if i choose, have a face full of hot air without it trying to control the climate in the car? A steady, constant stream of air at the temperature that I choose? Perhaps this is faulty, i don't know? |
02-18-2015, 06:12 AM | #35 |
Rep 835
Also to add, there is a setting in the iDrive for eco pro climate, I don't know what this actually does and I have turned it on and off with no noticeable change but if someone could explain if they know...?
02-18-2015, 08:56 AM | #36 | |
Rep 1,207
A good way to test it is this: On a cold morning... Select ECOPRO Climate setting as enabled in iDrive (default) Select ECO Pro mode Turn on Front Seat heating to level 1. Watch how long it takes to heat the seats ! Now, do the same without ECOPRO climate setting, the difference in seat heating is quite prominent. The same is true for A/C heating as well. The car takes a lot longer to heat up with the ECO setting on. Same happens with Air Conditioning, but you will really notice this in the summer. The A/C takes ages to cool with ECOPRO climate on. I have turned the ECOPRO climate setting OFF; and my A/C runs all year (in fact, I have never turned the A/C off in any of my 5 BMW cars in last 10 years) - as the fuel saving (if any) does not commensurate with the aspect of a luxury executive car.
02-18-2015, 08:58 AM | #37 |
Rep 835
Thanks for that Gspannu, and I agree, I've also never turned the AC off in any of my cars that have had AC/Climate. The humidity reduction and all round niceness that it adds to the environment is worth the small reduction in economy to me!
02-18-2015, 01:05 PM | #38 | |
Rep 619
I drive on motorways quite a bit, and the number of people who drive with steamed up windows is odd to say the least!
02-18-2015, 02:04 PM | #39 |
Rep 86
The reason those people drive along the motorway, or any other road for that matter, with steamed up windows, is because they only ever look through the front windscreen to a point just in front of their bonnet. So they would have no idea that their rear windows/rear view mirrors were even there.
02-18-2015, 03:27 PM | #40 |
Rep 5,083
I think its worth keeping the A/C on all the time as it needs to be run regularly to avoid issues later (reduction in gas leaking out)
it is after all an air CONDITIONER, not just for cooling in summer. I too have tunred off A?C in the ECO-PRO settings, so the only benefit I get from it is from the throttle being "dulled" requiring more movement for set level of power and the gear changes where it changes up sooner. |
