2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Borla Exhaust tips on 550i
      11-12-2012, 05:00 PM   #45
JimmyD
Jimmy D. 2011 F-10 550i Sport, Black Sapphire
JimmyD's Avatar
Drives: 2011 F-10 550i
2011 BMW 550i  [0.00]
Originally Posted by HDEddie1 View Post
Thanks to Jimmy D, I was able pick up his chrome tips to switch out my black tip . I set them about 3/4" from the bumper facia...the contrast with the M Sport diffuser looks good to my eyes. Car is otherwise still a stock and mellow ride.
Just as a back up, I'm sitting on a set of '07 M6 mufflers ready for a quad tip conversion just in case I tire of chrome square tips. If I go that route, I think all will be lost since I'll want to put on an M5 style diffuser, add some 3" mandrel bent pipes all over, drop the car with some coil overs, through in some Dinan 2, etc (Yikes!)
They look good, I am glad it worked out
      10-29-2014, 07:07 AM   #46
Alpine550
Drives: 2013 Alpine 550i
Originally Posted by JimmyD View Post
Thanks for your help and your post
Hey Jimmy I'm wondering if you can post some pictures from the side profile I'm concerned about the tips angling downwards.
I already have the borla tips and planning to do this Mod soon so I am just taking some extra precaution.
      12-20-2014, 11:09 PM   #47
Alpine550
Finally got mine
      11-04-2015, 10:18 PM   #48
-Z-
Drives: Black Pyrat
Originally Posted by Alpine550 View Post
Finally got mine
Looks fantastic. What brand/model are they?
      02-13-2017, 01:43 PM   #49
vk535i
vk535i's Avatar
Drives: play genre classic rock
hey,
I just came across your post and the photo of your car so nice. I want to do same as you did. Where do you get the tips? and if cut off the flap valve, does it throw an error code ?
      04-12-2017, 01:11 PM   #50
Mackie02
Drives: 2014 550i M-Sport
Possible to Cut Downstream of Flapper Valve?
Originally Posted by tp550i View Post
The factory exhaust is about 2-1/4" in diameter, but a good shop can make the tips 2-1/2" inlet diameter work.
I'd be more concerned about the 4" diameter outlet, since the factory muffler outlets are about 3-1/2" apart, center to center, the 4" dia. tips will be a very tight fit -both side to side and up against the 550 standard diffuser.
Its worth a try, you can always return the tips to Summit and go with 3" tips like the ones I installed
Is it possible to cut downstream of the flapper valve instead of upstream of it and just trim the Borla tip down then weld it?
      04-12-2017, 05:59 PM   #51
xxpanipuri
Drives: 550i
Looks good!
I just put the cyba 90mm tips on my m5 comp package exhaust. they are a little bigger, so they fill out the space in the m5 diffuser a little more.
did you consider the exhaust meister (device plugs into the electronic module for the exhaust flaps) and allows you to manually open and close the flaps...you can also program it to the home link.
I too replaced my stock 19" rft's with 20" Michellin PSS and ACS Springs.
The car feels alot tighter!
      04-24-2017, 07:37 PM   #52
STR8-6IX
Drives: RWD 528i N52
I have to admit I liked the look of the original tips better - more suited to the car.
if you want good performance gains yet still keep everything quiet, I would look into a downpipe. totally serene and no sound or drone when cruising, but it opens up and sounds great when you really step on it!
      05-06-2018, 05:57 PM   #53
Gixxer550i
Drives: 2015 550i
2023 BMW G05  [0.00]
Bringing this post back from the abyss.
I'm looking to just replace tips. And adding DTM style CF diffuser. Anyone can recommend the best size for the quad tips only that would fit the DTM style diffuser?
Reading prior post it's seems 3in would be the safest bet for stock diffuser.
      05-07-2018, 02:00 AM   #54
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
for a DTM diffuser i'd recommend at least 3.5" max 4". i wish i could get 4" but my Meisterchaft's only allow a 3.5" tips
3.5" with a DTM diffuser
4"
      05-11-2018, 10:46 PM   #55
Gixxer550i
Drives: 2015 550i
2023 BMW G05  [0.00]
4"
Thanks. Got my diffuser today. Unfortunately it's a bad fitment. Can't diy it. I'll post pics once I get someone to retrofit it for me.
      05-12-2018, 06:54 AM   #56
lsturbointeg
mine was a bad fitment as well since it's from Ebay. i did have to work it a bit. taking the rear bumper helped. i had to drill some holes in the tabs and than put screws to keep the tabs from popping out. Here's a picture of mine
      06-12-2018, 09:26 PM   #57
AG2009
Drives: Space Grey 2014 535i Msport
535i tip alternative
First post, so don't be too hard on me...I wanted quads on my 535 with the sport diffuser for the longest time, after looking through all of the ebay links, and other vendors, I settled on using the tips from a Porsche 997. they more or less were a direct fit for the the stock exhaust (after removing some material from the muffler side), and look pretty damn similar to the Borla tips in this thread. FYI
bake601.50
