2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions N57S shredding serpentine belts
      12-17-2023, 10:24 AM   #1
ana100
Finland
Drives: Z4, 530e, M550d, ex...335xi
M550d pre-LCI, so with N57S. engine. Shred two serpetine belts - it has only one long one.
Changed tensioner and checked all the pulleys, all are OK and working smoothly.
Noticed that the standard belt is a bit too long and it made contact to tensioner "bolt" i.e. the knob which You use to turn the tensioner. Put a shorter belt. Now that shorter belt been running OK for a month, now noticed that there's rubber pieces at the backside of the belt, like it scrubbing somewhere... Can't see where? Harmonic balancer seems fine also. Any ideas?
      12-17-2023, 12:23 PM   #2
ana100
Finland
This is how it looks like
That's how it looks like. The tensioner vibrates clearly on idle, but not when revs are even slightly higher than idle.
      01-31-2024, 10:06 PM   #3
dpalumbo25
Drives: BMW 535d
So I have a 2014 535d. I just did the turbo, tensioners, waterpump, pullys shredded 2 belts. Indy shop changed the harmonic balancer/cam pully. Said this was my source of the belt smoking. ...... now 4 days later i think the timing chain tensions shit the bed. trying to figure this one out..... but Id guess you need a new cam pully. Especially if everything else is moving well.
Tags
#n57 #serpentine
