2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Seat clicking on turning left
      03-16-2011, 01:13 PM   #1
Dom
Ireland
44
Drives: 2013 520d SE space grey
Just wondering if anyone else experiences a small click or slight movement in the drivers seat when cornering hard.
      03-16-2011, 05:04 PM   #2
cliveywolves
Drives: 330e M Sport Plus Edition 2020
I get a little creaking noise sometimes from my drivers seat doubt you can do anything about it though
      03-16-2011, 05:18 PM   #3
deejaygee
Drives: 320d M Sport
Yes me too drives me loopy!!! Common fault maybe?
      03-16-2011, 10:45 PM   #4
kd6lor
Drives: 08 335 Coupe
I had a little upwards movement and click under my right thigh when accelerating lightly. Drove me batty. Could hear and feel. Click, click, click. After a small amount of insistence they replaced the seat rails. This occurred after about 20K miles in my 335i. Sometimes a small item like this can ruin the experience. Paul
      03-17-2011, 12:27 AM   #5
Losco
Japan
14
Drives: F10 528i M-sport
it does that sometimes on my F10, but it doesn't occur enough to bother me. I do get annoyed by these things, but this one's not so bad as my previous car.
      03-17-2011, 07:22 AM   #6
ghueser
Drives: 2014 M5
I have found that a lot of clicking is coming from my Sun Visor. The vinyl is evidently sticking to components in the assembly and on driving and vibration, makes a noise. I just ususally swing it down and work it a little and the noise goes away for a couple of days. Obviously this has nothing to do with the seat, but thought it might give you another avenue to check for "clickning" noises.
      03-17-2011, 07:22 AM   #7
Dom
Ireland
44
Drives me nuts - just waiting for it to happen on each left turn!
      03-17-2011, 07:40 AM   #8
ghueser
Drives: 2014 M5
No doubt that it does. I would try one other thing. Move your seat to the extremes (like all the way up, all the way forward, all the way reclined) and then go back to your memory position.
Just a long shot that it might get reset,...... so it doesnt click.
      04-30-2012, 03:08 PM   #9
BlueWire
Drives: 2012 BMW 535i M-Sport
Wondering if anyone else has had this seat noise - the click on cornering? My 2012 535i driver's seat does the click when turning right (only occasionally when turning left).
Totally agree with the OP - just waiting for the click on each right turn is infuriating.
It's actually in the shop right now for service attempt #4 - I finally got the shop manager in for a test drive, and he sat in back and heard the problem. Suspects a loose or broken plastic clip inside there somewhere.
      04-30-2012, 11:40 PM   #10
Hanschien
Drives: 2012 535i
I had a clicking sound also. Turned out to be my sunglasses sliding around inside the driverside small glove compartment.
      05-01-2012, 12:03 PM   #11
chinese_food
Drives: BMW 528
I'm having the same issue. Im taking my car in tomorrow. Hopefully the techs will find a resolution. Ill keep you updated
      05-04-2012, 11:50 AM   #12
kmac1980
Drives: '19 540xi
I have this too on cornering.... usually happens once or twice at the beginning of a drive and then stops.... you can actually feel it in the seat bottom as though something inside the seat is shifting.
      07-31-2012, 05:16 PM   #13
faz
Drives: 2023 X5 x40i, 2018 330i F30
OK, I am glad I searched and found this thread. I have exactly the same problem as above.
Only recently it has started to happen (sayin the last month or so). When I drive away from my home on our side street, at about 100 yards, I have to make a right at the stop sign. The first right hand turn of the morning, it does this. It feels like if one of the bolts holding the seat down being a bit loose and the seat kind of wiggling/clicking just a tiny bit (like a loose bolt would cause.)
I have occasionally noticed it in the evening drive from work to home as well, and it is always only the first few blocks of driving that this can happen in (and only once.)
I have checked and nothing in the back seat pocket, nothing under the seat that can move around and hit the seat, no seat belt clicking, etc.
Has anyone of the above had the problem fixed?
