2010 2011 BMW 5 Series Forum F10 Standard speakers upgraded to OEM Top Hifi (retrofit) |
10-03-2013, 10:45 AM | #45 |
Rep 39
Looks good, I got my F07 ( 530D SE GT ) with standard sound ( 4 x mids and 2 x subs ) be nice to upgrade to top Hifi tweeters in front door pillars and the mids in the doors and see how that rocks as the bass is good from under the seat just needs more clarity ,definition and height
has anyone done just that ? on F07 or F10 / F11 |
O1NE0.00 |
10-12-2013, 10:43 AM | #46 |
Rep 18
is there a schematic were to understand ohm values for different setup?
I have a european x3/f25 model with professional navigation so no clue what is the hifi setup. I know I have no tweeters but I bought cheap used top-hifi tweeter willing to add these to the existing mid/sub unit. Will I affect (lower) the impedance? Thanks |
10-16-2013, 07:46 PM | #50 | |
Rep 359
10-22-2013, 03:24 PM | #51 |
Rep 18
if replacing audio base loudspeakers (single midange without tweeter) with hifi speakers (midrange PLUS tweeter) is there any problem for the audio amp to drive two speakers (less resistance value) instead of a single one?
10-23-2013, 07:34 PM | #52 |
44
Rep 208
No -- tweeters in this context don't significantly change the load presented to the amplifier.
10-23-2013, 07:35 PM | #53 |
44
Rep 208
By the way, great job and thanks for sharing. For the record, you *could* have contacted us for plug and play upgrades which sound EVEN better than the Harman Kardon speakers.
10-26-2013, 05:25 AM | #54 | |
Rep 13,001
The iDrive unit can handle 2ohms according to BMW. Less than that and the unit will overheat. This has to be done the right way. |
10-26-2013, 05:33 AM | #55 | |
Rep 13,001
This has to be done anyways for two reasons, impedance and to make the woofers sound the best with what you got. They should have their own amplifier channel so each can be tuned/crossovered more efficiently. There is no filter or crossover between the woofer and the mid with the iDrive system, so the sound is just split (highs/mids/lows) by each speaker own frequency response and that's it. |
O1NE0.00 |
10-27-2013, 08:05 AM | #57 |
Rep 13,001
10-28-2013, 08:54 AM | #58 |
Rep 359
Thanks
Btw, i have come across this http://www.focal.com/en/dedicated-driverspeaker-kits/396-ifbmw-c-3544051750530.html Is it compatable with f10 ?if yes, just replace front door speaker with this and sys safely improved? Thks |
10-28-2013, 09:44 AM | #59 | |
Rep 13,001
10-28-2013, 10:12 AM | #60 |
Rep 359
oh no
thanks tech Manual says that it is compatible with 1 Series, 3 Series and X1 can't imagine why 5 series is not on the list http://www.focal.com/en/dedicated-dr...050750531.html may be first stage, cut woofer & install some compatible stuff like ifbmw-s ( rock & roll is not my cup of tea) then second stage amp for woofer ( any cheap & simple installed amp in the market recommended?) Last edited by fung0001; 10-28-2013 at 10:17 AM.. |
10-29-2013, 09:28 AM | #61 |
Rep 359
Ooops!
i just found this from BMW HK: Radio BMW Professional, four-channel amplifier ( have amp in standard stock?), double-tuner reception, aerial diversity, scan function, CD drive with MP decoder, six loudspeakers. |
10-29-2013, 04:31 PM | #62 |
Rep 13,001
That's your iDrive unit. There is no external OEM amp in your car.
10-30-2013, 11:27 AM | #64 |
Rep 13,001
10-30-2013, 05:58 PM | #65 |
Rep 359
Yes you have mentioned earlier
The idrive is stable at 2 ohm Am i do it the right way as follows: Front: 2 Tweeter + 2 mid speaker in parallel Rear: 2 woofer + 2 mid speaker in parallel |
10-31-2013, 04:26 AM | #66 |
Rep 13,001
You need to run new cables to the underseat woofers (thus separating the front from the woofers), that's the easiest and the right way.
