2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Bootmod3 for F10 535i
      02-12-2017, 04:29 PM   #67
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Originally Posted by Bmw doubles View Post
FSociety and that's why your my favorite on these boards all seriousness, you the homie and yes GSR now branded as some other name was my first love. The break up was difficult, but we realized that we couldn't have kids together so we separated...wait that's the wrong story. Mission Performance 1st 535 was mine, and its the best it's been thus far. It will only get better with a big ass turbo, shed 3-400 lbs and meth injection.
Also are you saying the JB4 didn't play nice with your ecu at 1st? You had to send data logs to Terry? If so how long did that go on for?
Exactly you see I am PTF & Enzo's first X4 as well =D and yes I was JB4 first X4 after months of spending money at drag-strip and dyno, they just weren't interested in investing time into the M2/X4 M40i (share the same engine and similar software) where standard settings for N55 weren't working right.
I had jb4 from May till Nov, car was very inconsistent (even with latest firmware, more settings tweaked, e85 blend or 93, downpipe or stock cats, all wires including the extra EWG).
It's the same story every M2 I talk to tells me or I see, BMS says you need more fueling u need more BMS tied down, BS! They tie u down spending money on their kits and then later on say "It is what it is" well it is what it is my 93 oct BM3 Map outperforms the e30 map1/2/5/7 with jb4
Originally Posted by DigitalNav View Post
UPDATE: DME Unlocked, looks like the car is throwing an error for the HPFP that the car wasn't seeing before until everything was reset and the car had to re-read everything.
Going to go Tuesday to BMW to get that replaced... then will go back to get the final step of BM3 done!
What is the error ?
Keep us posted
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-12-2017, 05:04 PM   #68
DigitalNav
Drives: 2013 535i M Sport
What is the error ?
Keep us posted
It started throwing these codes:
P0485
P10D9
P0137
P12A8
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      02-12-2017, 05:56 PM   #69
WTFBRUHM3
Drives: F10 535i & F80 m3 on order
I would be careful bringing in your car to the dealer for warranty repair as your ecu has been tampered. PTF did say that the tune is detectable during dealer visits and they may refuse or void the drivetrain portion of your warranty.
P0485
P10D9
P0137
P12A8
AWF87M2826.50
      02-12-2017, 05:57 PM   #70
DigitalNav
Car is still under warranty so no harm in trying to set them to replace things.
If not, i know another dealer that is friendlier with mods, i can take it there if my local refuses.
Alpine White
Oyster/Black
      02-12-2017, 06:05 PM   #71
AWF87M2
AWF87M2's Avatar
827
Make sure your local dealer doesn't flag your car in the system/database for your tune. I remember seeing a post of it happening to someone on the F8x boards.
      02-12-2017, 07:37 PM   #72
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
As long as his car is flash back to stock hes fine. If his ECU has the tampered code he would be seeing this already. And PTF knows how to delete this as some cars get it, some cars don't.
Exactly, btw use another code reader and see what other codes u may have?
It was a JB4 car actually just recently, not BM3 car
IG: @bmwF9XG80
      02-12-2017, 07:53 PM   #73
DigitalNav
Car hasnt been flashed yet, just DME unlock so i should be fine. We didnt do any tune yet because the car is being put in LIMP mode until the codes get fixes. I plugged in my own OBD reader and thats the codes its throwing. Should be a simple fix as i read up on the codes, could be somre wires or sensor thats it.
Alpine White
Oyster/Black
FSociety3812.50
      02-12-2017, 08:01 PM   #74
AWF87M2
AWF87M2's Avatar
827
No it was not a JB4 car, it actually happened to a Gintani tuned car.
http://f80.bimmerpost.com/forums/sho....php?t=1346542
      02-12-2017, 08:19 PM   #75
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
You should be fine
Hopefully no one else goes thru a horrible SA like that one, flagging u for downpipes.
Here's the one I was referring to http://f80.bimmerpost.com/forums/sho...&postcount=242
IG: @bmwF9XG80
      02-12-2017, 11:17 PM   #76
DigitalNav
Will keep you guys posted after i drop the car Tuesday. hopefully its a quick fix.
Alpine White
Oyster/Black
      02-13-2017, 10:28 AM   #77
vivanapoli806
Drives: 2012 535i Xdrive Msport
How many miles you at that you're getting all these codes ? I'm really thinking about doing bootmod3. I'm at 54k and just did my plugs and coils within last 1k miles. Only downside for me is the authorized dealer by me doesn't have a dyno. I want to do a before and after dyno for my 2012 n55 xdrive since I'm stock and run their 93 map.
      02-13-2017, 11:24 AM   #78
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
As long as you go anywhere with Dynojet should be fine even if its not your dealer
IG: @bmwF9XG80
      02-13-2017, 11:58 AM   #79
vivanapoli806
Yeah I know. I just wanted to do everything all at once. Not have to dyno somewhere stock. Then get bootmod3 and then have to go back and dyno again. I'm going to try and work something out maybe since this shop hasn't done any f10 n55 yet. They have done other vehicles.
      02-13-2017, 12:00 PM   #80
DigitalNav
Im at 48K miles right now. Reading up on codes it could be simple wires reading sensors wrong or needs a replacement pump.
Alpine White
Oyster/Black
      02-13-2017, 04:51 PM   #81
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
So what should this whole thing typically run me out the door? I'm in SoCal. Shoot me a PM if you'd like. Interested if it's that much more worth it than my current JB4 setup.
      02-13-2017, 05:39 PM   #82
DigitalNav
Typically $1000 ... +300 if you want the module to control from phone.
Alpine White
Oyster/Black
      02-13-2017, 05:44 PM   #83
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Oy. Sub'd for your results!
      02-13-2017, 05:54 PM   #84
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
With BM3 you have the option to flash right on the spot as long as you have your OBD2 to Enet cable, Laptop/Device/Or Tablet to run the Agent and/or paired up with your phone. You can flash to stock or tune within 2mins done.
Contact SSR Performance if you're in SoCal, they' have unlocked and tuned the most BMW's in the whole state for BM3 since they were the first US Dealer.
IG: @bmwF9XG80
      02-14-2017, 10:12 PM   #85
ruben356
Drives: F13 M6 _ San Marino Blue
Sub'd awaiting your results and feedback. I wonder if they could possibly tune in other extras, like Overrun or that burble effect?
      02-14-2017, 11:17 PM   #86
DigitalNav
Ill be making my own separate thread with review once everything is done.
Alpine White
Oyster/Black
      02-14-2017, 11:19 PM   #87
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
What year is your car? EnzoRacing when you ready
PTF reposted my 4455lbs Sport Acitivity Coupe (BMW Name lol)
IG: @bmwF9XG80
      02-15-2017, 11:10 PM   #88
badass335
badass335's Avatar
Drives: 2017 540i Xdrive
Is there anyone local in Vancouver, BC, Canada that can unlock the ecu? I'm looking st getting this done but prefer if I can keep the Ecu local!
