2010 2011 BMW 5 Series Forum F10 Subwoofer upgrade alternative ? |
01-08-2016, 10:36 AM | #1 | |
Rep 738
on my lunch break bored browsing around I found this on ebay.
http://www.ebay.com/itm/Ampire-Subwo...4AAOxygPtS1XPf not bad, 160$ for each speaker. (320$ shipped for both) Seems like a cheaper alternative to Bavsound ones ? (500$ for both) They are 100W RMS / 200W PEAK, same as Bavsound. Translation: Quote:
Im really thinking about pulling the trigger on this, just waiting to see what you guys think.
2011 550i
2013 M5 2014 M5 CP 2016 550i Last edited by 550Reasons; 01-08-2016 at 11:06 AM.. |
01-08-2016, 02:29 PM | #3 |
Rep 738
Im still recuperating from Christmas, so Id have to order them beginning of February
2011 550i
2013 M5 2014 M5 CP 2016 550i |
01-08-2016, 03:50 PM | #4 |
Rep 14,522
550Reasons...did you already upgrade your components? i'm going Gladen Extremes. i've read into those Ampire awhile back and they are about the same as the SWS8 earthquakes. most reviews said they're nice but still somewhat muddy on the excursion side because it's trying to do both mid/low
specs for the included Gladen 8" woofers 2x 225/150 rms (Woofer) into 2 ohms + 2x 150/100 rms (MHT) at 3 Ohms great reviews on these as most guys from what they posted are excellent for mid bass! which is what i'm primarily using them for. still leaving the duties for the low end freq for the subs in the trunk. just ordered 2 Kicker 40CWR124 1000W 12" Dual 4 ohm CompR for my Nissan Titan and if they sound good to me i'll end up getting another set for the Beemer!
01-10-2016, 11:05 AM | #5 | |
Rep 738
Is this what your talking about ? http://www.germaniks.com/speakers/gl...7x-e8x-e9x-fx/
2011 550i
01-10-2016, 02:05 PM | #6 | |
Rep 14,522
http://www.germaniks.com/speakers/gl...7x-e8x-e9x-fx/ Here's the Mosconi bundle...I'm checking to see if I can run a monoblock amp for the trunk subs through the Mosconi amp...I think I can? http://www.germaniks.com/bmw-e60-e61...osconi-gladen/ This package for BMW E6x, E7x, E9x, F1x, F3x and more incudes the following: - Amplifier Mosconi 60.6 (6 channels) - Gladen speakers BMW 201 ALPHA - 4 channels radio plug - Rear speakers (Gladen RC 100) - Fuse wiring kit - Free remote BMW coding to HIFI (You must have a Windows laptop and a BMW OBD plug : You can buy the BMW plug from http://www.cable-shack.co.uk/ for example) Amplifier's specifications Target powers: 65 Watt per channel @ 4 Ohm 60 Watt x 4 @ 4 Ohm/ST + 230 Watt x 1 Ohm @ 4 Ohm/BTL 100 Watt per channel @ 2 Ohm 200 Watt BTL mode @ 4 Ohm Input sensitivity: (Power rating ref) 0.34 V ÷ 15.57 V Xover functions: (HIGH Pass or LOW Pass) HIGH Pass or LOW Pass FRONT (45 ÷ 225 Hz – 12 dB/oct) REAR (20 ÷ 225 Hz – 12 dB/oct) LOW Pass SUB (45 ÷ 225 Hz – 12 dB/oct) Special Features: Remote Volume Control (optional) Front Stage Adjuster Phase Shift 0° ÷ 180° (Rear) High Low Adapter F mix R Size: 310x200x50 mm Weight: 2,77 Kg here's the spec on the Bimmertech amp at 4 Ohms 8 x 55 Watts / 110 Watts at 2 Ohms 8 x 70 Watts / 140 Watts
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-10-2016 at 03:08 PM.. |
01-11-2016, 01:30 AM | #7 | |
Rep 135
01-11-2016, 06:47 AM | #8 | |
Rep 14,522
01-11-2016, 08:52 AM | #9 |
Rep 832
But that amp doesn't have a built in dsp. You should be looking at this if you want to compare it to our amp http://www.germaniks.com/amplifiers-...i-d2-80-6-dsp/ and it's only 6 channels.
03-20-2016, 08:31 AM | #10 | |
Daddy Wagon
12
Rep 119
i drive a 2014 f10 and the difference is night and day. best 1400 ive spent. i dj semi pro and my mates used to slag me about how flat the stock audio was. i got the amp with dsp function. he changed both underseat subs, rear speakers, tweeters (my car didnt come with tweeters), front speakers. its a combo of gladen and mosconi products. (i have two amps installed) |
03-20-2016, 09:38 AM | #11 | |
Rep 14,522
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 03-20-2016 at 09:43 AM.. |
03-20-2016, 09:48 AM | #12 | |
Daddy Wagon
12
Rep 119
So i think its a 4-channel amp running the mids and highs and another 2 amp channel running the underseat subs. |
03-20-2016, 09:49 AM | #13 | |
Rep 14,522
03-20-2016, 10:09 AM | #14 |
Daddy Wagon
12
Rep 119
03-20-2016, 10:56 AM | #15 |
Rep 14,522
Nice! i'll have to see what they'll charge me for the rears as i don't see any rear kits listed here in the US unless the place you went to will ship Internationally?
03-21-2016, 10:09 PM | #17 |
Rep 258
Interesting topic, I'm upgrading my subs soon and would be interested to hear what happens if you get them
2013 528i Silver with Black interior "Tallulah"
Black Kidney Grills Bavsound Stage 1 upgrade BimmerTech Amp |
03-24-2016, 07:32 AM | #18 | |
Rep 14,522
http://f10.m5post.com/forums/showthread.php?t=1238885
