2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
03-24-2014, 10:47 AM | #67 |
Rep 40,737
Drives: 2018 Alpina B6 650ix GC
Depends what you are diagnosing with, but for INPA it is good.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-24-2014, 10:54 AM | #69 |
Rep 40,737
Depends on the version, but most support ENET via built-in ICOM Emulator.
03-24-2014, 11:08 AM | #71 |
Rep 40,737
Depends on the Diagnostic software if it supports ENET or not.
03-24-2014, 11:18 AM | #73 |
Rep 40,737
Yes, looks good to go.
03-24-2014, 11:39 AM | #75 |
Rep 40,737
ISTA/D...and performed by my dealer as my car is still under warranty.
04-13-2014, 10:16 PM | #77 |
Rep 40,737
For proper connection:
1) Make sure motor is running if car is not on a Charger. 2) Make sure EDIABAS.ini (for Tool32 or INPA) is set for Interface = ENET. 3) Make sure Windows Firewall is disabled 4) Make sure all Antivirus programs are disabled. 5) Make sure LAN Adapter is set for DHCP and not using a Static IP. 6) The Target Connection Window should not be blank (It should show multiple target connections for different chassis').
04-14-2014, 12:05 AM | #78 | |
Rep 103
Please refer to below
04-14-2014, 12:17 AM | #79 |
Rep 40,737
What is a USB ENET cable?
ENET is LAN x OBDII.
04-17-2014, 07:20 PM | #80 |
Rep 385
Long story short picked up a 2014 535d this week and the SOS emergency call malfunction will not go away and the dealer, BMW customer service and BMW assist have no idea how to fix it but are working on it. Apparently this is a problem with 2014 F10 and X5 vehicles. Here is a brief description: HELP - BMW Assist and Real Time Traffic http://f10.5post.com/forums/showthread.php?t=926790" rel="ugc" target="_blank">http://<a href="http://f10.5post.com...p?t=926790</a>" rel="ugc" target="_blank">http://<a href="http://<a href="http...926790</a></a>
Question: Anybody have any idea how I can did this with coding? Is there a setting I can set to active or not active etc? BMW assist says all is set up correctly on their end and it is something wrong work the car hardware or software. Thoughts please? |
06-01-2014, 05:41 PM | #82 |
Rep 44
E-sys files
Hello to all from Spain
Have a 535d xDrive EU & will try to code a few options. Shawn, I've been pointed to you for the latest working E-sys (3.24) & data files, I've already bought a one year token. Thanks!!! |
06-01-2014, 06:48 PM | #83 |
Rep 40,737
PM sent.
06-05-2014, 09:10 AM | #84 |
Rep 23
E-sys 3.23 cannot connect my car
06-05-2014, 09:28 AM | #85 |
Rep 40,737
Your Target Connection Windows is empty. This means either your PSdZData is not installed correctly, or you have not gone under E-Sys options and set the data path to point to your data folder. If your PSdZData is in C:\Data\psdzdata, then your E-Sys Data path needs to be set to C:\Data.
06-05-2014, 10:26 AM | #88 |
Rep 40,737
PM sent.
