2010 2011 BMW 5 Series Forum F10 550i needs to be "linked" to do dyno? |
10-08-2015, 01:18 AM | #1 |
Rep 99
Trying to get a dyno done on my f10 550i with the racingchip but the shop says the car might be required to be "linked" in order to do the dyno and wont do it untill i get clarification. Im guessing they are talking about the front and rear wheels to spin at the same time. Since mine is inly RWD, how do you guys do the dynos? Turn traction and stability control off and go for it?
Anything else i should know before i take it there? |
10-08-2015, 02:07 AM | #2 |
Rep 862
10-08-2015, 10:15 AM | #3 |
Rep 844
Mine was dyno'd just fine on a 2wd dyno, about 15 pulls to be exact.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
10-08-2015, 10:41 AM | #4 |
Rep 249
The issue I faced was with the stock intakes installed there isn't much room to clamp onto the coil wire (at any coil) to be able to get RPM, and therefore a solid torque value.
It ultimately took my popping the zip tie, and sliding the wire sheath back so they had enough room to clamp on. I believe it's a brown wire with a black stripe, but that is from memory well over 1.5 years ago. My guys ran it without doing that, and only got RWHP. They ran it again for free after I figured out how to hook it up to get torque. They knew where they should connect to, but it really is a different looking setup, and I don't fault them for having some difficulty.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
