2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 spark plug torque and gap
      10-21-2015, 11:06 PM   #1
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Looking for the torque and gap for the OEM plugs on my 2013 f10 550. Yes, I know they come pre gapped, but they are not alway in spec. Yes I know plugs have a crush gasket but I want the exact torque value because it is easy to torque the plugs as they SHOULD be if possible.
      10-22-2015, 02:38 AM   #2
mikekilpatrick
Bosch plug, ZR5TPP33, BMW Spark Plugs Plug Set High Power Double Platinum Bosch OEM 37582 (8pcs), on Amazon for $87.70 (http://www.amazon.com/Spark-Plugs-Do...=A39702CCOVJH2) or at Rock auto for 70.00.
So I have 23 nm, or 16.96 ft pounds for the torque and .8 mm which equals .0315 (let's say .030 or .032) on your spark plug gaping tool. According to website https://www.rexbo.eu/bosch/spark-plu...00151&at=38524
This is for a 2013 F10 550 xi, but this plug should fit 2010 till now:
Built: 02.2010 today
Performance: 300 kW (408 hp)
Engine size: 4395 cc
Fuel: Petrol
Engine code: N63 B44 A
Engine Type: Petrol Engine
Cylinder: 8
Valves: 4
Body Type: Saloon
Drive Type: Rear Wheel Drive
Fuel Mixture Formation: Direct Injection
There you go, all the information you need in one place. Will post pics and install procedure so you can use this as a DIY thread.
Just to put the myth to rest, the OEM BMW plugs are identical in every way to the rock auto plugs listed above for $70.00. Same number, same engraving, just missing the BMW symbol. Will be doing plugs in next to weeks and draft up th diy. Have to complete my surround view retrofit first
      10-22-2015, 11:36 PM   #3
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
Cool man! I got my plus changed during the ccp so I'm good for a while. Please post a diy in the diy section!
      10-23-2015, 06:16 PM   #4
mikekilpatrick
No worries. I am going to gap them at .030. As an FYI, FROM BMW they were OFF at like .028 to .029. NEVER TRUST pre gapped plugs! ALWAYS check them! I also purchased the BOSCH plugs off of ROCKAUTO and BMW, going to do a side by side comparison showing they are the same plug.
      10-24-2015, 08:23 PM   #5
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
badblack550xi ARC550 can help on the gapping specs for N63/N63Tu
I know for N20, N55 its best to gap .018-.022
I just upgraded to S55 plugs and they came .027 stock
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      10-24-2015, 10:25 PM   #6
mikekilpatrick
Well, on the OEM BMW spark plugs box, it says 23NM for the torques spec, right along the lines of the recommendations as listed on the website posted above. Several of the OEM plugs came with the .0315 gap as listed as well. I would say the .031 would be a good number for the 2011-2013 N63 550. Will check with those guys as well. Next time I spend 30 bucks for the BMW TIS website, I will check it there as well. Thanks for the heads up.
      02-03-2019, 01:53 PM   #7
tcabill
tcabill's Avatar
Drives: e63 650i, F10 535i, E93 335i
So I have 23 nm, or 24 ft pounds for the torque and .8 mm which equals .0315 (let's say .030 or .032) on your spark plug gapping tool.
I know this is an old post but 24ft lbs of torque will likely break a plug or strip the head on your motor. 23 nm equals 16.96 ft lb. I go a little more because with higher than stock boost levels the plugs will get loose, but not 24 ft lb.
2012 535i M-Sport PWG, Wagner FMIC, VSRF no meow, chargepipe, Walbro 450 with custom fuel lines, MHD map e30 2+, JB4 (monitor and logging only now), xHP Stage 3, K&N drop-in, Paddleshift retrofit
      02-04-2019, 05:37 PM   #8
mikekilpatrick
Good Call, that was a type. Should be 23nm or 17 Foot lbs
      02-04-2019, 06:28 PM   #9
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
I gapped mine at .025
      02-05-2019, 12:34 PM   #10
mikekilpatrick
Gap depends on Motor. The instructions I typed up were for a V8. I am sure a 6 Cyl will be different
      02-12-2019, 06:18 AM   #11
tcabill
tcabill's Avatar
I assumed it was a typo, just didn't want a DIYer making the mistake.
