2010 2011 BMW 5 Series Forum F10 F10 - N63,N63TU intake system |
03-10-2015, 01:01 AM | #90 |
Rep 2,416
bottom to top
2011 550i RWD 60-130 7.35
03-12-2015, 07:00 PM | #92 |
Rep 249
I'm still waiting on elbows from the machine shop, he's been backed up from the unusually large amount of snow.
I have all other tubing/reducers/filters in hand. I'll install and drive it long enough to adapt, then it will be dyno/track time. |
03-12-2015, 10:52 PM | #93 |
Rep 1,408
Is your intake different than the one that badblack is showing?
03-13-2015, 06:13 AM | #94 |
Rep 249
Same setup, we've worked together to try and get this done right this time. He can speak for himself, but both of us getting machined components back is what is limiting progress. I received the last part I needed (besides elbows) yesterday. So we're getting close to installation and testing.
No butt dynos will be used, as I'll use the same dyno I used before. Plus, I found a pretty good 1/8th mile track within 45 min of me. After all that we should have a pretty good idea of what we're working with. BB is working the same thing in parallel. |
03-13-2015, 07:37 AM | #95 | |
Rep 2,416
03-15-2015, 01:12 PM | #97 |
Rep 1,300
03-15-2015, 07:14 PM | #99 |
Rep 1,300
03-15-2015, 07:23 PM | #100 |
Rep 249
Well, I broke a vacuum line. Tried to chase a phantom vacuum leak, lost a small piece of rubber via the PCV. So, I'm waiting for the car to crap it out the backend.
So, it was a crappy day. Back to stock until I can buy new vacuum lines. I did successfully install and drive an F10 550i with a cold air intake before I started breaking stuff. Sounded great by the way. I'm going to leave it up to BB for now, he's got the same setup in the works. This is promising, just needs some careful adjustment, which apparently isn't in my skill set. |
03-15-2015, 08:39 PM | #101 |
Rep 2,416
You're such a whore!
03-16-2015, 09:08 PM | #102 |
Rep 249
Well, BB and I managed to think through potential problems. I think we came up with a solution. So elbows go back to the machine shop tomorrow.
It doesn't hurt that my wife found the rubber plug I thought my car ingested sitting in the driveway. So game on again! |
03-16-2015, 11:17 PM | #103 |
Rep 2,416
Fingers Crossed!
03-22-2015, 05:19 PM | #105 |
Rep 249
I'm close (that's what she said), and I've already proven it will fit (that's what I said). I drove it, but had some issues with the MAF flange height. Dropped the elbows off with the machine shop to get the flanges cut down on Friday. I expect them back by mid-week, install this weekend to see if it solved my misfire problems.
The only thing I can come up with is the larger tubing doesn't sit up in the flange as much, so though it may have worked previously, the heating strip that the MAF uses to meter air was partially obscured, and that led to multiple MAF errors/misfires. I could keep the car running, but it hated me. I'm confident it's close to a working prototype now, and the changes will allow the car to adapt. After that we'll know if this is possible. I start shift work this next week, working day shift, so install will likely need to wait until the weekend even if I get the elbows back mid week.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
03-27-2015, 12:30 AM | #106 | |
Rep 1,300
And then.... |
03-27-2015, 09:04 AM | #108 |
Rep 2,416
Summer is here those cones under hood will just suck some of that nice HOT AIR.
03-27-2015, 11:44 AM | #110 |
Rep 2,416
His car is basically mine considering the amount of work i did on it
