2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
04-09-2023, 02:17 AM | #595 | |
Rep 108
Thanks Blue Angel, for the informative table. I am looking to replace (upgrade) my rear (345x24) rotors soon, so decided to have a closer look at the table. Couple of questions arised:
1. Why are the F01/750 and F01/760 on the comparison? I thought we'd loose the hand brake if using them, as they don't have the electronic one. How was it with M5, I don't know. I read the long thread about brake upgrades but there was a lot to read, so might have missed that one. 2. In the table 750 and 760 present same ID, piston dia etc. yet % increase is different. Where does the difference come from? 3. Brake bias ranking. Is this a ranking of the total torques, not the rear only? If so, what can I use this information for? 4. Does higher torque give you lighter pedal press or how do I perveice it? In this case, could a low torque be compensated with more efficient booster (or different size of master cylinder)? I am looking at the column of 550, so there aren't so many options for me to upgrade... Quote:
04-09-2023, 11:27 PM | #596 | |
Rep 1,050
2. % increase is only relative to the next column to the left. The rear F01 760 is the same as the rear 750 so 0% increase, and the rear F01 750 is 8.8% higher than the F10 550. 3. Yes, ranked by total braking torque. Brake bias front to rear is only for comparison. I did this so we could see what the different system combinations offered compared to the M5, which is probably the most rear-biased setup you should shoot for on a street car. 4. Assuming the same brake pad coefficient of friction, a brake system with more torque would equate to more deceleration for a given pedal force. Given the difference between the M5 and 528 is only 15%, a grippy pad on the 528 could give equivalent or better braking than the M5. Of course, the M5 brakes are massive by comparison and can handle far more heat, so more repeat stops or stops from higher speeds without overheating. It's all about thermal mass. And bling. |
04-14-2023, 10:26 AM | #597 |
Rep 252
Do the Xdrive f10 and Rwd have different knuckles for the 374 swap? Can i use the 2014 750i knuckle? Yes mine is Rwd
04-14-2023, 11:14 AM | #598 |
Rep 1,356
The hub bearing is the same for 5, 6, and 7. The carrier that the caliper and hub bearing are only interchangeable with 5 and 6. RWD and xDrive have different carrier
04-14-2023, 11:41 AM | #599 |
Rep 252
04-14-2023, 11:55 AM | #600 |
Rep 1,356
04-14-2023, 12:23 PM | #601 |
Rep 252
04-14-2023, 12:28 PM | #602 |
Rep 1,356
04-14-2023, 01:58 PM | #603 |
Rep 252
So something like these?
04-14-2023, 06:01 PM | #604 |
Rep 252
From all i gathered today is a set of the brembo pads for the 750xi with a lil trim will have me bolted up, so now my question is will trimming mess with the wear sensor?
04-14-2023, 06:58 PM | #605 |
Rep 75
No when they say trimming they are referring to the bottom of the pad. May need to cut 1/4" or less off the hub side of the pad and backing plate to clear the hub side of the rotor. When you go to install you'll see exactly what's up.
04-14-2023, 07:00 PM | #606 |
Rep 75
Also my new pads had a slight clunk at very low speed braking. Like radio off through the neighborhood could hear it but that was it. So after some digging I bought some 3m 468 high temp adhesive tape and put it on the back of the pads where the pistons lay. This is just like the OEM pads come. Now no more clunky. So if you have this issue with your new 374/395 rotor and caliper setup this is the easy fix. Also I had some slight pedal softness after my install. Quick abs cycle and rebleed brought it back to rock hard and consistent braking and pedal. Just some informative tips for those doing the swap if you get those minor road bumps
04-14-2023, 07:00 PM | #607 | |
Rep 1,356
Pads does not have to be trimmed if you have the right rotors. If you use rotors from F01 like a 2015 750 then no trimming at all. Sensor will clip right in without any mods. |
04-14-2023, 09:05 PM | #608 |
Rep 252
Thats the problem the rotor i have the hat is 205mm i think it was and the pad is a lil long, if trimming a tad wont hurt the pad thats what im going to do. They are a Powerstop rotors for 2014 750i they fit the caliper very well its just the pads.
04-14-2023, 09:08 PM | #609 |
Rep 1,356
Maybe powerstop made the hat for their rotor a little too big. I use OEM rotor and it cleared without any issue
04-14-2023, 09:14 PM | #610 |
Rep 252
04-14-2023, 09:17 PM | #611 |
Rep 252
I was going to try the Brembo pads thats in the calipers now for markup and order a new set if all goes well.
04-14-2023, 09:30 PM | #612 |
Rep 1,356
04-14-2023, 09:34 PM | #613 |
Rep 252
04-15-2023, 11:49 AM | #614 |
Enthusiast
518
Rep 321
Drives: 2025 M4 Comp xDrive
So far the install has been going great at the shop until just the drivers side caliper … the brake line would not seat properly
The shop tried to remove the brake line and needed to take out the nut at top that’s connect to the abs line They tried anti seize overnight and in the morning attempted to twist but the abs line bent Luckily they found that the line that bent does not go to the master cyclinder but to the abs module Seems like the drivers side line is shortest as the abs module is in the front wheel well. Anyone every change these lines? What exactly is needed to do an electronic abs bleed? Any tips of remove the old line and putting in new one? I’m the diagram below the line labeled (8) is the line being changed and going into the abs module with 4 slots The picture in the bottoms shows the abs module and the place he is pointing to is the slow the line goes into
2025 M4 Competition xDrive
IG: Automaz_ |
04-15-2023, 07:52 PM | #615 | |
77
Rep 174
Your best bet when changing fluid on a F10 or other BMW with brake lines that route through several pumps is to use ISTA and a pressure bleeder. ISTA cycles the pumps and walks you through the process. |
04-17-2023, 02:43 PM | #616 |
Rep 252
So i found out that a 348 pad will work but you have to slot the retaining pin hole, at this point im trying both methods later this week🤞🏾
