2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA Newbie from Hong Kong
      10-16-2012, 02:32 PM   #23
grimlock
Drives: F10 N52B30@255PS
Originally Posted by F10E70E90 View Post
I get it from the front only, the noise actually come from when i step on the brake into complete stop at the lights and then slightly slowly remove the brake, and step on the brake again.
i start to wonder if its something to do with the wheels...as i have no problem at all when i use the OEM 18" wheel
Mine does that exact same thing. Got it fixed yet?
      10-19-2012, 12:26 AM   #24
F10E70E90
Drives: F10 MSport ; E70
Your does the same too? Which wheel do u have it on? OEM 17"?
I still have the problem...i have no idea what makes those noises...
      09-11-2013, 10:39 AM   #25
tofuflower
Drives: 528i
Hi Ching,
I switched mine from 18" to 20" m5 oem wheels, same thing happening to me, I went to BMW for them to check and they told me nothing to do with the brakes and it must be my second hand wheels got scratched so it makes sounds...(seems like they just doesn't want to work on it since I switched the wheels) then I brought it to a wheel shop and ask about the sound they told me it has something to do with the loading on the stock brakes. when we switch to bigger wheels, the original brakes couldn't handle it and therefore create the sound that we hear.
Any Ching out there ever heard about this explanation? Because I might get a BBK for this reason/excuse......and I really wanna fix this sound...
Thank you
Chings
      09-13-2013, 01:38 AM   #26
F10E70E90
Hey,
Yes, i still have those noises, only on the first few brakes, after the brakes warm up, the sound will disappear. Is that the same to you?
Went to BMW couple of weeks ago for my first service, and i have the exact answer from your wheel shop, the BMW service advisor said this is to do with the loading and the F10 brake can't handle it at all. He suggest the only thing i can do is to change another set of wheel or change the brakes.
I tired the wheels on the 7 series as well and had the same problem.
There's a few member in the general forum had the 19" style 345 or 20" style 343 M5 OEM wheel on their F10, and they did not have any issues.
Is that something to do with our F10 in Hong Kong only?
I really want to fix this as well, this is really annoying.
Originally Posted by tofuflower View Post
Hi Ching,
Thank you
Chings
      09-13-2013, 02:05 AM   #27
grimlock
Guys I fixed it search 'akebono' in this section
      09-13-2013, 02:15 AM   #28
F10E70E90
Yeah, i remember seeing this thread about akebono as well, which 19OEM u running at the moment?
Where did you get the akebono from?
Thank you,
      09-13-2013, 02:19 AM   #29
grimlock
rockauto.com
6 months still perfect!
      09-14-2013, 03:33 AM   #30
tofuflower
Drives: 528i
Yes , Exactly same situation. Only when i start the car and when the car cools down.
I guess we should try grimlock ching's suggestion before jumping into BBK.
Thanks grimlock Ching.
      09-15-2013, 08:26 PM   #31
F10E70E90
Thanks grimlock...
Will probably give it a try first.
Any shop you guys would recommend for this?
Thanks~~~
      09-16-2013, 09:55 PM   #32
AC_S5
AC_S5's Avatar
9
Drives: 2011 F10 523i
Nice wheels vs squeaky brakes.
I choose the first one
2011 F10 - Sophisto Grey / Cinnamon Brown
You can find me in E60.net too!
Gone (but not forgotten)
2005 E60 523i, 1999 E39 523i, 1998 E46 323i
      10-08-2013, 12:48 AM   #33
NCEC
Drives: F10
I had the same issue when I switch from 17" to 21", took it back to factory they said maybe the weight of the wheel, but that's kind of BS, then I replace the brake pad Akebono from Rockauto, just the front now no more noise no more brake bite, feels great! If I knew I would do that even without the wheel upgrade, OEM brake pad sucks!
One more thing, the brake dust are all gone!
      10-11-2013, 09:31 PM   #34
fung0001
Drives: f10 2013 520i Hartge Tuning
is brake dust due to the brake pad?
it seems that just replece the pad is ok
      10-11-2013, 10:12 PM   #35
mlai
mlai's Avatar
Hong Kong
168
Drives: 650GC/E93M3/Lexus LS600HL
No more brake bite?
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      10-13-2013, 01:06 AM   #36
NCEC
Drives: F10
I mean irregular particularly at low speed
      11-21-2013, 08:33 PM   #37
528imsport
528imsport's Avatar
Drives: Msport
Originally Posted by mlai View Post
No more brake bite?
Hi I on the subject on the pads I what to change to Ferodo 2500 pads. Dose any 1 know if they make them for our 528i M-Sport cars?
      11-24-2013, 10:36 PM   #38
sith
Hong Kong
Drives: F10 520i 2012 Sophisto Grey
I got these squeaky noises from the brakes as well after upgrading from 17' wheels to 19" wheels last year. I brought back to BMW and they said these noises are resonance sounds of the wheels. (I don't believe it at all.) They said they had tried switching back to OEM wheels but without my presence and the noises went away. So BMW would not do anything for it.
Earlier this month, when I brought back my car for 1st year maintenance, they cleaned the brake pads and the noises seemed to be lower a little bit.
So, I am pretty sure this is a problem of the brakes.
