2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Doing meth on 550xi
      07-05-2014, 12:06 AM   #23
badblack550xi
badblack550xi's Avatar
Originally Posted by dvs0690 View Post
hey bad black, any specific reason why you would run meth before the intercooler? Ive always seen them ran after the intercooler.
That's what terry said to do so im doing it....
2011 550i RWD 60-130 7.35
      07-06-2014, 10:30 PM   #24
badblack550xi
Parts are coming in this became more work than i thought.... got some parts from Devils Own for quick release. And BMS parts slowly appearing in mail.
      07-07-2014, 08:11 AM   #25
gclions
gclions's Avatar
78
Drives: 2011 550i
Dude, I found just what you need!
I've seen these before, and I think this will make install WAY easier!
You cut a hole in the hoses, and clamp these assemblies on! Perfect fit, and only $14.99 each.
I would hold off on welding, and give these a shot. Here's the link:
http://www.siliconeintakes.com/produ...roducts_id=500
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      07-07-2014, 11:34 AM   #26
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
Good work Black....
dvs - that location is after the intercoolers right before air enters the turbos.
Alan
      07-07-2014, 12:38 PM   #27
dvs0690
Whooo Whooo!!!!
dvs0690's Avatar
Drives: 72' Pinto, 73' Gremlin
Originally Posted by Alan l. View Post
Good work Black....
Alan
Thats an incorrect airflow path. Air enters the turbo from the intake and is shot out from the spot you see to be cooled. The reason i asked is because ive worry about condensation build up in the intercoolers. But if terry is doing it if must be good 👍
72' Ford Pinto - Turbocharged, Supercharged, NOS, Headers, Iceman cai, 5" exhaust tips, tornado gas saver, apc trunk wing, Underglow kit, cut stock springs, vtec badges, hid's in halogen housings, unpainted retrofitted civic buddyclub bodykit, vinyl graphics, chrome front fender vents, altezza taillights, autometer tachometer, fire extinguisher on passanger a-pillar, lambo doors, whistle tips
      07-07-2014, 02:17 PM   #28
badblack550xi
Correct where i am putting the meth it's actually after turbos going to inter-coolers.
      07-07-2014, 02:25 PM   #29
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
On other N5x series setups, meth is connected directly to the charge pipe.
      07-07-2014, 08:19 PM   #30
badblack550xi
Kit is here
      07-08-2014, 07:42 AM   #31
Alan l.
Alan l.'s Avatar
5437
I stand corrected. I normally know what i'm talking about but not yesterday lol
Alan
      07-08-2014, 08:44 AM   #32
badblack550xi
Alan
Happens to the best of us... can't know it all!
      07-08-2014, 11:49 PM   #33
badblack550xi
Originally Posted by gclions
Easy day dude, I don't even think they need to be that fancy.
The stainless steel v-band piece inside the rubber hose closest to the turbo flange is at least 1 inch long.
Attachment 1053009
I would start by measuring the inside diameter of the v-band flange. Take that measurement to a reputable shop and have them make a 2 inch long section of stainless tubing of the same diameter, and weld a bung towards one end of that piece, have them make two of them.
So now you should have two pieces 2 inch long with bungs welded in each.
Unscrew the v-band flange clamp, remove the band.
Cut off the hose clamp holding the flange to the hose end.
Remove the v-band flange from the hose end.
Weld the fabricated pieces to the v-band flanges with the bung closest to the v-band end.
Cut the hoses to a shorter length to allow the assembly to line up.
Hose clamp the new pieces into each hose.
Attachment 1053023
Good thing about something simple like this is the piece can be loosened and rotated to the position you need. Something like this would work, just a thought.
It's not stainless steel ... It's aluminum... Now my whole meth install is delayed for at least 2 more days I might not make it to my event. We took it out and my guy that does the piping was like fuck.
      07-09-2014, 07:06 AM   #34
gclions
gclions's Avatar
78
Drives: 2011 550i
That sucks dude. It looked like stainless to me, but I was just checking for how deep the flange went into the hose.
I guess the idea is the same, you just need two aluminum bungs and a short section of aluminum tubing with similar diameters. Is your guy set up to weld aluminum?
      07-09-2014, 12:46 PM   #35
badblack550xi
He don't have alluminum pipe that size so we are waiting for delivery. In the mean time I'm getting my meth kit installed and then piping and testing.
      07-09-2014, 12:47 PM   #36
badblack550xi
It's happening
      07-09-2014, 12:57 PM   #37
gclions
gclions's Avatar
78
Drives: 2011 550i
Dude, that is going to be sweet!
So, he is sticking with the original plan then? Just waiting on materials?
      07-09-2014, 01:03 PM   #38
badblack550xi
Basically for now we might have to hack the stock rubber pipe but I'm ordering custom silicone one to make it look clean.
      07-09-2014, 06:07 PM   #39
badblack550xi
About to test fit
      07-10-2014, 10:22 AM   #40
badblack550xi
so the rubber hose i cut are $265 a pop wow
      07-10-2014, 10:34 AM   #41
gclions
gclions's Avatar
78
Drives: 2011 550i
Uhh, holy crap. Dude, no going back now!
Did you learn this before or after you cut them?
      07-10-2014, 11:33 AM   #42
ClassM
Drives: BMW 535i msport/M5 E60/M3 E9x
Goodluck with that! Def hard to go back now expensive both ways lol
      07-10-2014, 12:22 PM   #43
badblack550xi
after hahaha
      07-10-2014, 07:17 PM   #44
badblack550xi
For now it's a hack job to get me to the racing event tomorrow and Saturday.
