2010 2011 BMW 5 Series Forum F10 20 inch Wheel Fitment Question. |
02-01-2018, 06:30 PM | #5 |
Rep 14,521
i'm running et 38 on a 21x11. so take a .50" off i think it'll tuck? those are sweet looking wheels bro! what color scheme are you planning on going with? is that a true 2-3 piece wheel?
604_e90325i18.00 |
02-04-2018, 10:49 PM | #6 |
Rep 687
Nah, one piece. from Niche. Check their website in the 2018 collection. Should be available for me in Canada by June. I have the Sophisto Grey colour so i'm looking at something different. I have always liked the look of brass on your car.
02-05-2018, 01:34 PM | #7 |
Rep 14,521
I think it'll look really good! Anyway to photoshop the wheels onto your car?
02-05-2018, 04:06 PM | #9 |
ZEROdoubleZERO
228
Rep 659
To get a 20x10.5 +35 to tuck you will need to run negative camber and a 285 and it will rub on a hard dip. For perfect fitment with no rubbing and no inner tire wear from negative camber the rear will need to be atleast a +40 and a 285. If someone tells you it wont rub and tucks with a 295 with a +35 on a 10.5 they dont have that setup or they are guessing. I've tried that setup and it rubs when it tucks.
02-06-2018, 01:14 AM | #10 | |
Rep 687
02-16-2018, 01:40 PM | #11 |
Rep 634
I'll chime in here too.
I'm also considering a 9" et25 front and 10,5" et35 set of Vossen CV3R on my F11. I have X-drive with adaptive suspension and plan to drop the car with ACS springs. Thought I would run 285 rears, and did not expect any rubbing since the car would not be lowered that much. So et30/40 would be a trouble free combo compared to et25/35? I would hate to get et30/40 and end up putting on 5mm spacers. Last edited by Noggie; 02-17-2018 at 05:20 AM.. |
02-16-2018, 01:52 PM | #12 |
Rep 91
Im going 20 by 10 all the way around and don’t wanna Tun spacers on my 535 xi msport and cluenhow insit the most flushed as possible tire size advice too iff anyone has any. I was told I had to run a spacer in the back
02-17-2018, 12:42 PM | #13 | |
ZEROdoubleZERO
228
Rep 659
02-19-2018, 11:17 AM | #17 |
Rep 687
That's what I'm running with the same tire size "super sports". Fits no problem !
02-20-2018, 09:24 AM | #18 | |
Rep 634
I did the math and based on measurements 10,5 et 35mm could be an issue, but I was not sure how much the added camber due to the lowering would play in. Also I have an F11, so it has air suspension in the rear. I guess 25/40 it is. Should see the front come out 14mm and the rear 16mm compered to the stock setup. |
Teddylongtooth228.00 |
02-21-2018, 09:15 AM | #19 |
Rep 14,521
you get these wheels on yet?
03-12-2018, 09:28 AM | #21 | |
Rep 91
Can I run 20x10.5 in the front with no fender modding and if so I can only assume I need to run a specific tire size keeping in mind I have an x drive to be able to pull it off. The only thing is that I live in jersey and the streets are shit. Iv run through 4 tires in the last 6 months and they have all been sidewall damage/tears. The wheels I’m looking at in order to get the look I need to run 11s in the back. Also if I’m looking at a wheel with a lip does that change anything on the fitment in order to clear the calipers? |
