2010 2011 BMW 5 Series Forum F10 Easy work around for city drivers with dead battery issues. |
01-11-2015, 03:15 PM | #1 |
Rep 510
We all know the dreaded problem for city drivers needing new batteries prematurely. I live in DC so it's a problem for me. I tested some behaviors with the car on how to get it to charge if you're in low speed traffic. You can tell when it's charging because the fuel economy bar underneath your tach swings to the blue side. Here's what I found.
Problem: If you drive in normal mode, it rarely charges the battery under 45mph. That's a huge problem as you don't get to go 50+ in the city. Solution: Use Sport Mode or hold a lower gear longer. Basically, you are engine braking at a higher rpm and forcing it to engage the alternator. You burn more gas but use less brakes. What I found: It seems like it is based on rpm rather than speed. In normal mode, it doesn't like to go past 2.5k rpm. If you hold a gear higher than that when decelerating(engine braking), it will charge your battery. I took a 2 mpg hit but I've never had to use an external charger anymore. On the highway, whatever mode doesn't matter as the rpm will be high anyways. However, if you are in sport mode, then it just engages the alternator a little quicker(nothing significant). This has worked for me and kept the battery charge up at optimum level. Even when I left my car in the cold for 3 weeks without driving it, it still cranked up. When the temperature dropped recently to 6F, it still cranked up without a hiccup while every other car in the parking lot had problems. I did about 4 months of testing with this on the highway and city(I drive mostly city). It was the only way to get the car to charge the battery more often in city driving. Recommendation: Drive in sport mode in the city. It's fine to use normal or comfort on the highway. |
01-12-2015, 10:36 AM | #2 |
Rep 1,472
Interesting suggestion, I'll give it a try, nothing to lose I guess.
Had a long chat with service manager on this last week as we've had few days of -20 Celsius or below in the city. His response was "well that's normal, these cars are all electronics, and any battery left overnight in this cold will drop down in charge" which, I can "buy" to a certain extent. He's also suggesting installing trickle charger "we do this with each new car we sell in here in this dealership" and have the car plugged in every time temperatures drop below -10 (which is really 4/5 of the winter days where I live). My understanding is that "charge battery" warning comes on after battery charge drops below 80% on these cars and I can even understand that's the case due to electronics which are sensitive things are setup this way. I also "buy" that because the battery is in the trunk, the engine warmth doesn't protect it as much as it would in any other car during these cold days. But.... I asked him to consider this explanation from a customer point of view. You're buying luxury sedan, and having to take these steps to protect the battery seems like a major pain. I also jokingly suggested that this should've been mentioned in either vehicle brochure or manual (not sure that comment was appreciated), and that having to run cables for most of the winter in my driveway is a pain (and never had to be done with any other vehicles I owned in the past). Even if you were willing to live with "low battery" warning, the issue is that the car starts shutting off the features (like fans and heating, kinda important on a cold day - though must admit good thing is that windshield defrost works at least). Also, I find that on those very cold days, driving the car on the highway for 20-30 minutes doesn't charge enough (does not clear the warning) but the very next day, with temperatures above -15 Celsius, the warning was gone, only to come back the following day, again below -20. Funny thing is that they kept the car to check the battery and charge it overnight if needed, and gave me a loaner 2014 320xi with 5K km on it. By the time I arrived from dealership to work, parking the loaner and shutting it off gave me "low battery" warning. Also on a very cold day, just to disappear the very next day when the temperatures climbed a bit. I've read quite a bit on this, and it seems to be "hit and miss" where some owners have this issue and other like me are wondering "can this really be generic BMW issue" that these cars just, to quote my service adviser manager "don't like the cold" ? |
01-12-2015, 12:38 PM | #3 |
Rep 2,323
The only time I have seen the blue bar light is when I am coasting. I have not notice the blue bar light up while the car need to charge the battery while it is not coasting.
01-12-2015, 01:06 PM | #4 | |
Rep 1,472
Again, maybe I'm wrong on this one, someone else can correct if I am. |
01-12-2015, 01:36 PM | #5 | |
Rep 2,323
01-12-2015, 01:51 PM | #6 | |
Rep 585
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
01-12-2015, 02:37 PM | #7 | |
Rep 1,472
BTW same service manager mentioned that trickle charger won't really charge the battery as much as keep it on level it currently is at with minimal to no loss of charge in very cold weather. |
01-12-2015, 02:43 PM | #8 | |
Rep 2,323
01-12-2015, 03:16 PM | #9 | |
Rep 1,472
I bought the car CPO this summer exactly at 3 year since "in service" date, so I'll assume battery is 3 year old. If I was told battery is old and an issue here, I would have no problem asking them to put a new battery in and move on. He did initially say that battery itself seems to be fine. The issue I have is getting advice to, in theory, trickle charge even brand new battery every time temperatures are dropping down below -10 because "these cars don't like cold". Friend of mine who purchased brand new X3 from the same dealership was given same advice, gets "low battery" warning now and then and plugs his in from time to time. Winters here are just brutally cold and I get that doesn't help, but again, this is the only car I've ever owned where I'm told to install and use trickle charger regularly. Spoke to few MB and Audi owners I know, thinking that those cars have just as complex electronics, and might be that they are just lucky ones, but no such issue on their cars. |
01-12-2015, 04:41 PM | #10 |
Rep 697
Drives: 2013 535xi
Bbb34 - I think we are in the same climate, and my car had the first low battery warning when it was just 3 months old. I'm convinced that my battery is still fine. As was initially proposed, I also occasionally do my commute in sport mode to keep the revs up, and this seems to cure the problem, most of the time. I learned this trick with my previous 5-Series (E39) that also had a habit of running the battery down in Winnipeg. The good news is that even with the low battery warning, my F10 has never failed to start, even when it was -25C.
Cheers.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
01-12-2015, 05:50 PM | #11 | |
Rep 1,472
Anyway, just got a call from the dealer, car is ready, battery is fine, nothing else (beside the cold) is drawing the power away, and this seems to be just considered "normal" behavior with these cars. "This is normal" line coming from the dealer is, as understanding as I'm trying to be, what I'm struggling with. Just the fact that I might need to plan to have an outlet handy or be prepared to go for a longer drive to charge the car during multiple day ski trips, visiting family... etc...so I can only hope your advice works. I barely drive in any but sport mode anyway (though have been leaving it in default "normal" mode recently due to slush and snow on the roads). I'll also give trickle charger a try as well, and see how that goes, but am not exactly thrilled about having to use it. Last edited by Bbb34; 01-12-2015 at 09:11 PM.. |
01-13-2015, 12:37 AM | #12 |
Rep 237
My battery had the low warning once in the winter of 2012-2013 when the car was about 7 months old. I already own a charger with 2, 15, and 100amp settings so just charged it. I've used it just the once. My 535xi usually only runs for 7-10 kms in the city every other day and hasn't been on a highway for a month. I often use Sport to increase the rpm as others suggested. I doubt you would need to use the trickle charger every day, even when its extra chilly, but it won't charge the battery so you may still want to use a regular charger. The three settings in mine are for trickle, regular and super start. I got it at Canadian Tire.
My F10 lives outside. If your battery is three years old it may just be wearing out. BTW, my retired E60 had two batteries in 2.5 years and I used the same charger a lot with it. E60s had a lot of battery problems due to the car not going to sleep when it was turned off. Based on forum comments, F10s don't seem to have as many problems in this regard. Good luck.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive |
01-13-2015, 05:09 AM | #13 | |
Rep 697
Drives: 2013 535xi
-23C / -9F this morning. Dang!
01-13-2015, 06:04 AM | #14 |
Rep 15,858
The OP's suggestion of using the transmission to get more revs, simply illustrates that many users are not getting enough battery charge in their normal daily commute.
Let's not forget the electrical demand is very high in winter, so besides the temperature issue we are needing more charge than summer use, just to maintain battery condition. Look at it this way, there will be thousands of drivers without IBS in their motors (no battery condition warnings) running low battery state/charge, driving around "blissfully ignorant" they are doing so. HighlandPete |
01-13-2015, 08:50 AM | #15 | |
Rep 1,472
But again, as reasonable as (I think) I'm trying to be, not crazy about suggestion to run cables to my car regularly. Talking to those around me with different brands and just as sophisticated electrical system and demands, so far I have not heard them dealing with similar issues, maybe they are lucky, maybe there are differences in electrical power demand, system design, speed of charge, I'm not sure . This is just one of the threads out there on the topic. http://www.bimmerfest.com/forums/sho...d.php?t=655109 In order not to hijack the thread, yes, I will try suggested solutions, both, slightly higher revs and trickle charger. |
01-13-2015, 09:07 AM | #16 | |
Rep 15,858
Don't know if that could be a valid reason, as I've not researched it. HighlandPete |
01-13-2015, 09:12 AM | #17 | |
Rep 10,185
I know for a fact newer Mercedes and VW here often have low battery problems
BMW if you are reading, I need a job, Please. |
01-13-2015, 09:21 AM | #18 |
Rep 510
Hi guys, thanks for suggesting the trickle charger. That's been an old fix but it's very inconvenient. It's not even realistic for most city folks as we don't have a garage.
I don't know if the car charges the battery automatically if power is below 80% or not. That sounds like a really crazy threshold because batteries are considered bad(need replacement) if maximum capacity is only 80% of original capacity. If it does in fact automatically charge the battery if it's below 80%, then why all the dead battery problems? Even I had problems before from city driving. Here's what I do know. The battery included in our car is made for high discharge and recharge. They also tend to not hold their charge over long periods of time. It's just physics. The higher the charge/discharge rate, the higher the self-discharge rate. So your only solution is to keep it at optimum level. |
