2010 2011 BMW 5 Series Forum F10 2016 550i xdrive with m343 tire issue |
10-02-2023, 07:31 PM | #1 |
Rep 143
Hey guys,
I have a 2016 bmw 550i xdrive awd with stock suspension that i put the following m5 343m rims and tire sizes on: Michelin Pilot Sport 4S 245/35/20 with 20x8.5 wheels for front Michelin Pilot Sport 4S 285/30/20 with 20x10 wheels for rear I believe these are the stock dimensions but the issue I am running into is that there is a big wheel gap, very noticeable in the front. See pictures I was wondering if I could use the following tires without an issue: Michelin Pilot Sport 4S 245/40/20 with 20x8.5 wheels for front Michelin Pilot Sport 4S 285/35/20 with 20x10 wheels for rear They are still <1% (0.7%) difference in diameter from each other. Tire rack sells them and surprisingly they are even cheaper than the tires i have on now. And no I don't want to get lowering springs because I have the F10 dynamic handling packaging and i dont want to mess up the suspension or change it. 1. I was wondering if anyone ran the 245/40/20 & 285/35/20 on their F10 550 and if it had any rubbing issues or drivetrain issues? 2. Will this fix the tire wheel well gap that is there now Last edited by SocomCA; 10-02-2023 at 08:04 PM.. |
10-03-2023, 11:12 AM | #2 |
Rep 29,203
Since the 245/40 tires are about half an inch taller, you’ll get half an inch less gap too.
10-07-2023, 07:26 PM | #3 |
Rep 2,595
245/40/20's fit on the fronts. That's what I run on the fronts for my 343M's. Any taller and you'll hit the knuckle, though.
2015 BMW 535xi
ChiltiCoatl891779.50 |
10-08-2023, 11:30 AM | #4 |
Rep 143
10-08-2023, 11:31 AM | #5 | |
Rep 143
Whats weird is that i had 245/40/19 inch tires on my f10 before and there was no wheel gap but now there is. Idk if something is wrong with the suspension or firestone did something wrong during the install |
10-08-2023, 10:59 PM | #6 | |
Rep 2,595
I'm lowered, so no related photos, sorry.
2015 BMW 535xi
10-11-2023, 01:33 PM | #8 | |
Rep 2,595
It's a weird optical illusion.
2015 BMW 535xi
10-11-2023, 01:38 PM | #9 | |
Rep 143
The 19inch are on the bottom |
10-11-2023, 04:58 PM | #10 | |
Rep 2,595
Additionally, increased offset can make the gap look bigger. Think about it for a second: mathematically, there's literally no way for the gap to objectively increase in size. It's therefore a subjective illusion.
2015 BMW 535xi
10-12-2023, 06:21 PM | #11 |
Rep 167
I have oem 345m wheels on 265/40/19 and 295/35/19
No rubbing at all. total height is 27.3" front and 27.1" rear. I want to run 265/45/19 (28.4") and 295/40/19 (28.3") but might hit the knuckle per Unspec that has 27.7" height in front. 28.4" -27.7" = .7 / 2 = .35" so less than 3/8" closer to the knuckle. Visually It seems I have about an inch from the tire to the knuckle, might give it a try next year. Unspec What do you have on the back for tires? |
10-15-2023, 11:54 AM | #12 | |
Rep 2,595
2015 BMW 535xi
10-31-2023, 11:47 AM | #13 |
Rep 1,156
i run 255/35/20 and 285/30/20 in the back.
2014 550i (RWD) lowered on ACS Springs. run 3mm spacers on front. Changing tires will not reduce the wheel gap, only thing that will is lowering it...Dinan / ACS are the 2 i'd recommend, that work with the EDC...and maintain the stock ride... i'm running ps4 All season up front and ps4s summer in the back (we have alot of potholes here) so the fronts do take a beating... the SUMMER ps4s i had up front DIDN'T rub. these all season ones do rub...(on bumps). So i may go down to 245 all seasons up front...which should eliminate the rubbing. |
Hornet-01165.50 |
11-28-2023, 12:38 AM | #14 |
Rep 143
11-28-2023, 01:35 AM | #15 |
Rep 2,595
I run all seasons with KW v3's, so no lowering springs.
2015 BMW 535xi
mickeyvalentine7.50 Hornet-01165.50 |
11-28-2023, 02:26 PM | #17 |
Rep 2,595
As I had stated previously, I run 245/40/20 and 275/35/20. No rubbing.
2015 BMW 535xi
01-15-2024, 05:42 AM | #18 | |
Otaku
Rep 23
sorry to bud in. That is with the 343m stock offset, correct? I can't recall if you mentioned elsewhere you had spacers or not.
2016 LCI 550i Glacier Silber |
01-15-2024, 11:37 AM | #19 |
Rep 143
I installed the stock m343 rims 9jx20 front & 10jx20 rear and for a LCI 550i xdrive, you need a set of 3mm or greater spacers to clear the caliper
mickeyvalentine7.50 |
01-16-2024, 03:29 PM | #20 | |
Rep 2,595
On 550i's you need a 3mm spacer due to the larger 550i calipers, but 535i stock brakes you can get away with no spacers.
2015 BMW 535xi
01-26-2024, 01:24 PM | #22 |
Rep 129
Drives: BMW 550 xdrive
Your car looks very nice
I have lowering springs, but they are not enough anymore, I also want KW v3 Last edited by Hornet-01; 01-26-2024 at 01:27 PM.. Reason: clarification |
Unspec1311.50 |
Tags |
343m rims, 550i xdrive, awd, f10, m5 rims, pilot sport 4s tires, tire issue, tires |
