2010 2011 BMW 5 Series Forum F10 2015 535D stumble at or near idle and 1 & 2nd gear |
06-15-2023, 10:54 AM | #1 |
Rep 6
I've had a frustrating, on-going issue that the dealer seems is unable to diagnose. I'm in Illinois.
For the past year or 2, my 2015, 535d X-drive, 59,000 miles, often has a barely noticeable to violet stumble and hesitation within the first minute or 2 of engine start. The rpm's can drop by 100-200 or it will just feel like a little hiccup. This doesn't just happen when it's in park, it will frequently happen when I'm in drive and the engine is in 1st or second gear. There is a noticeable hesitation in power delivery when it happens. The issue seems to be more prevalent in hotter weather but I can't say for sure. Things I've done to try and fix. : --Taken it to the dealer 3 times. "we can't find anything" --I've tried switching fuel stations for a couple of fillups, issue remains. --carbon buildup was removed around 10,000 miles ago, issue remained. --recall for the ECU cooler was performed,...issue remains... --fuel additive, issue remains. I'd appreciate any additional help I can get. Thank you. P. Last edited by 1.9liters; 06-15-2023 at 11:38 AM.. Reason: Spelling |
06-15-2023, 06:58 PM | #2 |
Rep 111
Fuel filter change? This is pretty cheap and maybe something to try.
StradaRedlands4961.00 |
06-19-2023, 07:30 PM | #4 |
Rep 44
I would replace fuel filter too. I've done it, the main hassle is the fiber panels that must be removed to get to it. Annoying. Also verify with dealer that they checked fuel pump function.
Tags |
dealer service problems, diesel, engine problem, misfire, shifting gear, stumble |
