09-13-2013, 09:36 PM | #224 |
Rep 63
09-14-2013, 10:12 AM | #225 | |
Rep 483
09-14-2013, 07:08 PM | #226 |
Rep 238
09-14-2013, 08:52 PM | #227 |
Like No Other.
557
Rep 1,833
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT my work: http://www.instagram.com/CorsaAutoDesign |
09-20-2013, 09:38 AM | #228 |
Rep 13
Drives: 2103 528i x-drive
Has there been a determination what rear bar to upgrade to from a stock 528ix? Would like to match the upgraded M5 front bar as close as possible. Thanks in advance.
09-20-2013, 11:20 AM | #229 |
Rep 29,202
So you has the M5 front sway bar on you 528i xdrive? Then why didn't it fit onto Akkord29's 528i xdrive in post #213?
09-20-2013, 12:13 PM | #230 |
Rep 8,823
My rear M550D/650 rear sway bar just arrived. Its 16mm and going to put it in my LCI 550 tomorrow. Stock size on my car is 14mm.
09-20-2013, 01:00 PM | #231 |
Rep 13
I don't see why it won't fit the 528ix if this is an accurate assumption. I am going to get it up on the lift see when it comes in. If not, then check the classifieds next week for a deal on an M5 bar.
09-20-2013, 04:43 PM | #232 |
Rep 318
Even though the 16mm is only 2mm (or about 14%) larger, I suspect the difference will be felt nonetheless. I read a while back on a Porche post that the resistance factor was exponential to the increase in bar diameter. I just don't remember the formula or factor but nevertheless, I can't help but believe there'll be a benefit. Can't wait to hear your report.
Thanks...Keep up the good work! |
09-22-2013, 11:31 AM | #234 |
Rep 2,232
Drives: Made in Bavaria
where did you source yours from? rear sway bar I mean...I've already done the front sway bar replacement. Have a 2012 550i with M Sports package. Would it be a direct fit?
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten '15 BMW M3 (Black/Black) - gone not forgotten '10 BMW X5M (Black/Black) - gone not forgotten '08 BMW M3 (Space Gray/Black) - gone not forgotten |
09-22-2013, 04:28 PM | #235 |
Rep 29,202
Looking at the pics, I assume it's the two new bushings (33556788630) in the plastic bags. And that's all you need, plus the sway bar (33556791932), right?
09-23-2013, 12:09 AM | #236 |
Rep 1,198
09-23-2013, 08:44 AM | #237 | |
Rep 8,823
Alan
09-25-2013, 04:48 AM | #238 |
Rep 11
Alan,
Do you feel the difference after swapping the rear sway bar from 14 to 16mm? Swapping the front is more noticeable than swapping the rear? I suspect swapping the rear will add "oversteer" to balance out the extra "understeer" added by swapping the front. Better feel when exiting corner? I am planning to swap both front and rear at the same time, if the rear makes a different. |
09-25-2013, 09:12 AM | #239 |
Rep 8,823
yes the rear does make a difference but not as dramatic as the front. Well worth the $190 price tag for the parts and the install for the rear is super easy.
Alan
09-25-2013, 09:35 AM | #240 |
Rep 2,416
LIKE A BAUS!
2011 550i RWD 60-130 7.35
09-25-2013, 03:31 PM | #241 |
Rep 621
I just put on the rear bar last week as well. Agree with what Alan said. Rear is less noticeable, but made the car handles better overall.
09-25-2013, 08:50 PM | #242 |
Rep 1,198
