2010 2011 BMW 5 Series Forum F10 My 2011 BMW 550ix "M5 conversion" |
10-27-2014, 04:18 PM | #23 |
Rep 541
Then I have finally started on the body convertion of my 550ix..
First parts off was the side skirts. Since some of the screws to unmount the fenders are under here, it was the place to begin Then the bumper came off. I started with some unmounting of steel bars, some plastic parts, fog light and finally cutting in the plastic surrounding of the radiator to get it to fit the M5 bumper. New M5 airducts was fitted and modified to fit a 550. My biggest problem with this convertion is my Active Cruise Control radar. M5 are not delivered with this option. Since M5 have a completely different lower steel bar and it is this one my radar is attached too, I have to do some good modifications to it. After test fitting the M5 bumper, I also saw that the radar will hit my grill inserts in the M5 bumper So some thinking and a good plan hopefully will sort it out Testfit of the bumper Look where bumper/fender meets. It is a lot wider this bumper The fenders was easy to remove. Some screews on the top, one under the bumper, one under the side skirt, one inside the inner plastic wheels arch and two within the front door. It will be a completely different car with this bumper So then the M5 parts is shipped away to the paintshop. Just looking forward to get them back now
[SIGPIC][/SIGPIC]
10-28-2014, 04:07 PM | #26 |
Rep 541
Yes, I think it will be quite a different car when it is finished
[SIGPIC][/SIGPIC]
10-28-2014, 06:52 PM | #27 |
Rep 25,989
Awesome progress, can't wait to see the finished product
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
10-28-2014, 08:58 PM | #28 | |
Rep 26
I wanted to the same thing to my 650 cabrio. But it seems that it requires too many mods. Probably just go for the M6 cabrio in the future. |
10-31-2014, 06:49 PM | #30 |
Rep 541
Today I got my parts back from the paint shop
So got started on the Bimmer again... Here`s the M5 bumper freshly painted Since the M5 do not have Active Cruise as an option. It has been a little challenging to get it fitted in the M5 bumper. I cutted the lower mounting bracket off since it wouldn`t fit the new flat M5 bar (look at the picture). Had to make a new one The new mounting bracket was made of solid aluminum. I did it long to give extra support for the new M5 bar that is made of plastic (the old one is metal). After some new black paint, this is how it turned out. A solid bracket that I was happy with Some measurements later, I cutted a hole in the plastic mesh So the finish product got like this Had to buy the M5 engine undercover as well, this was not either a direct fit. Did some new mounting brackets towards the center of the cover. Some cutting in the plastic was also done. This was because it hit some of the suspension parts. Those nice fenders had also some work with them First of all, the window washer tank was in the way for the new right hand fender. This is because the M5 airvent sits deep So I fixed this with moving the tank a little closer to the chassi of the car. The side vents have the indicators fitted on M5. The original indicator wires was then too short. Had to extend them and switch + and - to get the leds working. The inner plastic wheels arches was different on M5 also. Also here it was some need to cut in the plastic. The pieces close to the engine was different, so had to go After those mods, the fenders was a easy fit New M5 mounting brackets was fitted almost everywhere behind fenders and bumper.... Here it is, almost done with 2014 M5 grille The car is also lowered with 30mm Eibach Pro Kit at these pictures Really have to do something with my wheels
[SIGPIC][/SIGPIC]
11-01-2014, 02:14 AM | #31 |
Rep 5,110
Looks great!!!
But please remove the "5" in the ///M5 badge on the grille and fender vents... It's not an M5 so it shouldn't be badged as one either. At least in my opinion Will you use a M5 rear diffuser as well? |
11-01-2014, 11:06 AM | #32 | |
Rep 541
For the fender badges, I have order a custom badge designed by my self
[SIGPIC][/SIGPIC]
11-01-2014, 11:25 AM | #33 |
Rep 634
Wow, I never understood anyone who does this to a car, especially in Norway.
The price difference between a 550 and an M5 is so small by the time you are done modding you might have bought a real M5. Unless you got the car dirt cheap, and work as a mechanic with BMW and get parts for cost price.......... I really appreciate the work put into the car though, personally I'd just buy an M5 in the first place. |
11-01-2014, 11:51 AM | #34 |
Rep 5,110
11-01-2014, 12:05 PM | #35 | |
Rep 5,110
The cheapest 2010 (one year older) M5 I can find on mobile24.no ends up at NOK 1.050.000,- with taxes paid. Most of them are around NOK 1.150.000 to 1.200.000 though (if you want a lower mileage one). That means that the M5 is at least NOK 220.000 to 320.000 more than his 550ix... I am pretty sure he doesn't spend 2-300.000,- on the body parts here... And the difference between a brand new 550ix and M5 is even larger: 550ix starts at NOK 1.270.000,- M5 starts at NOK 1.700.000,- 550ix costs 74% of a M5 In Germany the difference is: 550ix starts at EUR 75.000,- M5 starts at EUR 105.000,- 550ix costs 71% of a M5 So, as you can see, the relative difference isn't that big EDIT: You could even buy an aftermarket M5 conversion kit for as little as $1600,- http://f10.5post.com/forums/showthread.php?t=1042869 http://www.x-ph.com/2011-2014-bmw-5-...onversion-kit/ Last edited by Boss330; 11-01-2014 at 12:28 PM.. |
11-01-2014, 01:34 PM | #36 |
Rep 634
Last 550i i saw for sale was just about 1 million nok.
I guess this kind of conversion is easy 100.000 nok. Just painting the parts is 20-30.000 nok. So unless you have access to discounted parts, contacts to have paint and such done cheap, this kind of conversion will not come cheap. For a normal person this project would easily end up around 1 million nok. To me you end up buying an expensive car, using a lot of money to make it look like something it's not, and looking at the end sum, the difference to "the real deal" is not that huge. And you are lacking the power and handling of the real deal. But that's just me I can appreciate the work going into this, even if it does not make sense to me |
11-02-2014, 03:43 AM | #37 | |
Rep 5,110
He did say he needed X-drive though. Perhaps that's why he choose the 550ix, or perhaps the conversion is much less than your estimate... I did a conversion on my car and did NOT spend that much on paint, less than half of your highest estimate. And that was done at the paint shop used by BMW as well... |
11-02-2014, 06:47 AM | #39 | |
Rep 634
But like I said, I can really appreciate the work going into this car, and the use of oem parts makes this a quality build. From my point of view it does not make sense financially, if it had been a 528 or 535 the economic part would be a lot more sensible. But like I said, if the op has access to parts at cost price, works in a shop with access to all tools needed, and has friends or contacts to get things painted cheap, then this makes a lot more sense. |
11-02-2014, 02:36 PM | #40 |
Rep 541
Wow
This has been a nice big discussion about if it`s financially correct to do this with my car. In Norway, it is much easier to sell a expensive big car with 4 wheel drive. The 550ix is the closest you will get to a M5 with Xdrive. So that`s the main thought about the conversion. But of course, it is also a price question. As it was mention in some of the posts: I work in a great workshop (Ferrari & Maserati), have 30% discount on BMW parts. Have our own paintshop and do all modding myself So it`s get a lot cheaper, but not cheap The Rear M5 bumper will arrive from the paintshop next week, so then I will mount the sideskirts, the rear M5 bumper and diffuser
[SIGPIC][/SIGPIC]
11-02-2014, 02:50 PM | #41 |
Rep 541
Today I finally got time to mount my interior trim. They where painted perfect and I`m very happy with the result.
The color is from Mercedes, Obsidian black metallic. It's a very dark black metallic color. Perfect for interior All the parts was detailed with sanding of dust and finally polishing step by step After polishing, they where glued together with the alumimuim parts. Really glad to get rid of those wood panels
[SIGPIC][/SIGPIC]
11-03-2014, 01:10 PM | #43 | |
Rep 634
I figured you had a job like you do, for me, this would not be possible to do cheap, and I might as well buy the real deal. Even if I have x-drive now, I'm not sure I need it on my next car. Good luck modding, will be interesting to see the final result. |
11-03-2014, 03:39 PM | #44 | |
Rep 541
It is a very nice an special car you own. Congrats with that one I think I will get my rear bumper this week. When it arrives I have to install it on the car. When I have done that, I have to do the exhaust Really looking forward to hear the true sound of the V8 Now it sounds like a Rolls Royce, too quiet
[SIGPIC][/SIGPIC]
