2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Lowering a 520D with EDC..help!
      11-13-2015, 07:33 AM   #1
Adofly
Drives: 520D M-SPORT
Hi Guys,
I just got a 520D M-SPORT 2013 with EDC suspension. I want to lower the car 20-25mm. I've read that I may have problems with the EDC if I install lowering springs. Is that true?
What springs do you people suggest?
Thanks.
      11-13-2015, 09:04 AM   #2
ausfahrt
Drives: 2001 325i Touring
Originally Posted by Adofly View Post
Hi Guys,
Thanks.
I've got ACS lowering springs on my car that has EDC. It's been on for several years now and I've had zero problems.
      11-13-2015, 09:38 AM   #3
BimmerV8
Drives: 2015 550i xDrive M Sport
EDC with Eibach Pro-Kit springs. 30mm front, 25mm rear. perfect setup.
      11-13-2015, 11:33 AM   #4
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Shouldn't be a problem, lots of people in here has lowered they're f10s when they have EDC.
      11-13-2015, 04:45 PM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Hi Guys,
Thanks.
you should be fine!
      11-14-2015, 05:37 AM   #6
Adofly
Thanks guys!
I'm going for Eibachs, however my car is M-SPORT, which I suppose is lower than a standard car, so will the 25mm Eibachs will do the job, I do not want it to be slammed.
Thanks again
      11-14-2015, 05:59 AM   #7
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Thanks guys!
Thanks again
Go with the eibachs, they have what I would call the least amount of drop. I have h&r's and my car slightly rubs on the driveway when I pull in and out. A lot of more conservative people go with the eibachs for a more refined lowered look that doesn't scream lowered. If that makes sense
      11-14-2015, 09:33 AM   #8
lsturbointeg
ACS from what I read has the least amount of drop. Eibach's than H&R's with the more aggressive drop
      11-14-2015, 10:47 AM   #9
remmib
remmib's Avatar
Norway
1568
Thanks guys!
Thanks again
I'm pretty sure it isn't lower since you've got EDC, only the M-sport suspension is 10mm lower I believe.
      11-17-2015, 04:49 AM   #10
BimmerV8
not sure whether Eibach's are lower than ACS having in mind that the manufacturer of ACS springs is no one else but Eibach. The technical specifications of both products are identical.
ACS says: 20mmm lower than M Sport suspension and up to 35mm than stock suspension.
      11-17-2015, 04:58 AM   #11
BimmerV8
http://f10.5post.com/forums/showpost...04&postcount=1
      11-17-2015, 09:28 AM   #12
lsturbointeg
      11-18-2015, 04:54 PM   #13
lsturbointeg
According to the info here yes ACS is made by Eibach but they lower the car about 30mm whereas Eibach from about 38mm all around.
http://f10.5post.com/forums/showthread.php?t=460813
That is why we here in this forum call the ACS a subtle drop. Here's a fellow with a great example
http://f10.5post.com/forums/showthread.php?t=1173155
      11-19-2015, 05:45 AM   #14
BimmerV8
If people are saying this, fine. But in general I can not beleive this.
Find below what Eibach Germany is saying for its springs, in this case for a F10 LCI 550i xDrive. Part Nr. is E10-20-022-02-22. Exactly the ones I have installed on my car.
I have attached the description taken from their homepage as well as all the technical specs shown on the TÜV Gutachten (official approval document). I have highlighted all relevant details here (the front and rear spring part numbers for the 550i xDrive as an example).
So it would be really good if someone has the same/similar doc from AC Schnitzer for comperison.
      12-04-2015, 07:58 AM   #15
jorihaloo
Drives: BMW 520d F10
If you order msport with EDC the car will come with normal height springs (not low msport springs).
      12-04-2015, 04:08 PM   #16
lsturbointeg
Hi Guys,
Thanks.
Did you ever get these done?
      01-25-2016, 04:22 AM   #17
Adofly
Yes! EIBACH 25mm all round
      01-25-2016, 04:36 AM   #18
lsturbointeg
      01-11-2022, 02:52 PM   #19
aa240sx
aa240sx
Drives: 2003 BMW M3
So I'm now in the process of lowering my F10 535i Msport with EDC (didn't even know I had it til I was wrenching on the struts...)
And..I bought some used Bilsteins B8's ugh. as well as H&R spring (new in box, used). Wish I knew ahead of time and could have just skipped the bilsteins, but I guess these will go up for sale soon.
Anyway, I guess I could try the bilstein H&R combo anyway, but then would have to code out the EDC errors correct?
Frustrating..
Update - Finished the Job! Took two days, but it's done and on the first test drive, a ton of klunking and banging sounds almost from every corner. Panicked quite a bit, stopped driving and starting analyzing what I did wrong. So, for me, the issue was the strut/shock bolts and the 3 surrounding bolts on all 4 corners!! I thought they were tight (no didn't use torque specs), but they weren't. Once that was done, ride was sublime.
But if I'm being honest, I really couldn't see a difference in ride quality before/after. I will try each of the EDC setting to see if that affects anything, but I do like the 1.25" drop up front and almost 1" drop in the rear. I assume after a month of driving these numbers should change by an 1/8 to 1/4".
Probably will drive around like this for awhile, until I figure out the whole 'coding out EDC' thing using ESYS. I really would have preferred to install the H&R springs with the Bilstein shocks.
2012 F10 535i Msport - Sophisto Metallic
2003 E46 M3 6speed (converted) - Alpine White
      01-24-2022, 07:35 AM   #20
bamberjim
Drives: 2012 F10 535D
How's is the ride on H&R?
I fitted Eibach springs to my Adaptive drive (SV2A) (2012 535D) and although the car sits lower, if feels really bouncy like the springs don't match the shocks.
its a little better in Sport mode but doesn't feel right at all
      01-24-2022, 07:49 AM   #21
bamberjim
hi wondering if you could offer some info, i have adaptive drive (SV2A) on 535D and fitted Eibach pro sport springs, car looks much better but feels really bouncy!
how's yours on the ACS springs, wondering if hey are a different spring rat to the Eibach?
      01-24-2022, 05:13 PM   #22
aa240sx
aa240sx
Drives: 2003 BMW M3
I almost always drive around in eco pro with start stop turned off, so call me 'low and slow'
haven't even tried the sport setting, but in the eco pro setting, car rides exactly as it did before and I only notice the difference in ride quality if the road is really bad and even then it only feels slightly bouncy.
