2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds Alpina B7 Turbos for Sale
      01-08-2016, 08:42 AM   #1
747flyboy
Drives: 2008 M3 2012 550i M
USD 1,800.00
✓ Will Ship
Hi Guys,
I seem to be the one stumbling over available Alpina Turbos for sale.
I bought a set with 19000 miles in awesome shape that I like to put on the market. You too can turn your 2011-2012 N63 to a 540 WHP monster. Asking $1800
Photos will follow
      01-08-2016, 09:31 AM   #2
omak81
omak81's Avatar
145
Drives: 2020 M2CS Black/Black Manual
What about tuning for these, im assuming you would need an Alpina tune for these?
1985 Euro E24 M6 5Speed - Graphite Metallic/Black Buffalo Leather
1998 E36 M3 5Speed - Titanium Silver/Black Vaders
2011 550i X Drive M Sport - Carbon Black/Cinnamon
2020 M2CS 6Speed-Black Sapphire Metallic - Black Style 763M
      01-08-2016, 09:37 AM   #3
747flyboy
Tuning is ideal. Presently running the same setup with burger tuning S2. The car is effortless Alpina vs OEM N63 turbos.
      01-08-2016, 09:43 AM   #4
747flyboy
The quote below from knowledgeable board member Fenix_Mike, sums it all.
"Its much like anyone elses "aftermarket" turbos for our cars, they send the housings out to be opened up, larger wheels are installed, and then reassembled. Its really the best option for our cars since its a proprietary housing (not an "off the shelf" turbo you can just bolt on anything) and having someone like Garrett or Precision make a true aftermarket turbo for our cars would be a fortune due to lack of demand, R&D costs etc. With the "larger" Alpina or *insert brand here* turbos, you don't really lose anything on the low end as most internal components are the same, it just has a better cold side wheel to flow more air and allow a better high end boost curve with significantly better efficiency. Believe it or not, adding a larger turbo doesnt just mean more boost, nor does it really effect the vehicle negatively in this case because nothing changes as far as the car is concerned other than possibly a bit of spool time on the very low end, and a bit more of a boost spike when the wastegate finally opens until the computer learns to control it better (also depending what device you are using to control boost). The wastegates will still open at the desired boost level, but the upside to a larger wheel is the more efficient air now seen as the turbo isn't trying nearly as hard to achieve the desired boost. Most of the time increasing efficiency of the turbo will pick up significant horsepower even at identical boost levels, so if 747 even didn't touch his piggy back, it likely gained at least 20 horsepower down low from cooler intake air temps and better air charge, and probably quite a bit over 5,000 rpm where the stock turbos start to choke a bit, and now flow much better. Unfortunately to really take advantage of aftermarket turbos you really need a true custom tune (I may have something up my sleeve for us N63 guys since until now, the only option is drop an Alpina or Dinan file into our computers IF access can be somehow gained, but more on that as I get more info from my guy). 747 has taken quite the advantage of proper octane which has allowed him to run significantly more boost on stock timing than any of us can with 91/93 octane, which now with a larger turbo should make even more power.
Since I don't have the interest in running race gas, I'm going to wait until I find out about the ECU tuning. If that works out for me, ESS has turbos for our cars as well and I may just do something silly"
      01-08-2016, 11:18 AM   #5
omak81
omak81's Avatar
145
Thanks
      01-10-2016, 02:54 PM   #6
747flyboy
Price drop
      01-10-2016, 09:19 PM   #7
Simple5
Drives: 2013 M5
Are these another set you found our the one that is from your? You ever dyno your car again post turbos?
      01-10-2016, 11:06 PM   #8
747flyboy
Total new set. Did not have a chance to Dyno. Job has me overseas majority of the time'
My set had 37000 miles, this set has only 20000 miles.
Joe
      01-13-2016, 12:06 AM   #9
Husni08
Drives: 2013 550i M Sport
Would these fit a 13' 550i?
      01-13-2016, 07:10 AM   #10
747flyboy
Perfect fit
      01-15-2016, 10:15 PM   #11
747flyboy
Photos added
      07-09-2016, 06:03 AM   #12
747flyboy
Bump
      07-09-2016, 06:44 PM   #13
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Originally Posted by 747flyboy
Price drop
what is the price now? definitely interested.
      07-10-2016, 07:39 AM   #14
747flyboy
Make me an offer!
      07-22-2016, 06:24 PM   #15
TheBlackGT
Like No Other.
TheBlackGT's Avatar
Drives: BMW F07 LCI
do they work on the N63TU btw?
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT
my work: http://www.instagram.com/CorsaAutoDesign
      08-03-2016, 01:24 AM   #16
2011BMW550i07
2011BMW550i07's Avatar
Drives: 2011 BMW 550i
Hi Guys,
Photos will follow
I'm interested in your turbos if they're still available. Please let me know thanks.
      08-03-2016, 09:52 AM   #17
747flyboy
Still available.....send PM please.
Grumpy514624.50
      08-03-2016, 09:12 PM   #18
2011BMW550i07
Pm sent
      10-01-2016, 08:57 PM   #19
550i_scorp
Drives: BMW N63 550i 2011
Are they still available? Any price drop?
      10-02-2016, 01:22 PM   #20
747flyboy
Turbos
Still available
      10-02-2016, 05:46 PM   #21
550i_scorp
Sorry if this sounds a silly question, but didn't understand it very well. I have a 2011 N63 550i, do you mean I DO need to tune the car for the new Alpina turbos?
My car has the latest N63 Burger MotorSports stage 3/JB4 that came out in June, 2016; would that be an issue for the Alpina turbos?
Thank you
      10-03-2016, 03:07 AM   #22
747flyboy
Non issue....Identical setup as mine. You will achieve additional 40 to 60 WHP or greater (dependent on Octane) with Alpina Turbos and JB4 Stage 3.
