2010 2011 BMW 5 Series Forum F10 F10/11 Focal front speaker install |
01-09-2016, 11:14 AM | #1 |
The Flasher
55
Rep 164
Where do i start?...
As always i start by thinking it wont be a bad job, and to be honest it wasnt to bad ive only had one trim clip snap on me, schoolboy error on my part though. Be prepared to strip your door if your attempting this setup mind and it wont look pretty heres a pick mid install but with the help of a Bavsound video to aid stripping the door card off its once again not rocket science, just google f10 door card removal and its there. Right i have tried to take several pics and i wont go into to much detail for door card removal as the bavsound vid has everything for that area. first of all you will need to purchase the tweeter housings and plug and play speaker connectors from bmw here are the following part numbers here are the ordered parts I also purchased,and used may i add a focal k2 component set, glad i did though I started by mounting the tweeters within the housings, to be fair they didnt fit perfect but then i suppose they are designed for bmws oem offerings, i used a glue gun with hot melt glue to seal them in dont be shy with the glue it wont hurt to fix it securley. I also had to order the bmw 4" adapter plates due to the speakers being a standard aftermarket 4 bolt fitment and bmws use on 3 securing bolts, adapters as shown i used stormguard door draft seal 10mm thick sandwiched top and bottom between adapter plates to provide a super snug sealed surface for speaker to sit. right now its time to watch bavsounds vid, several times! just to be sure about whats got to be done. Speakers and crossovers waiting to go in there new home with door card off and hopefully no clips snappedyou can set to work on the wiring this is where some general knowledge of electrics will help, i generally just twisted soldered and heat shrink tubed every connection, PLEASE NOTE>>there is no need to take door card right off just makes more work like bavsound guy says, 'just have everything to hand on car seat and put door card on your lap or a chair like i did. make sure you fassen speaker down well as you dont want to be taking door card off again!! once all wired up test everything is working and now your ready to mount the crossover not to many options for placement, i chose bottom corner and it fit like a glove bit of araldite and hot glue around edge and she stuck like sh1t to a blanket. now its door card back on again refer to vid as mentioned and have a cup of tea before tackling drivers door. pretty much everything is the same as passenger side just make sure to take time and test everything before reassembling Just for a note,I set focal tweeter crossovers at -2db, i think -3db is preferable but it was a choice between -2 or -4 so i went with -2. overall seems a really good addition to sounstage, music is alot crisper and it can stay crisp without disstortion to much higher levels than standard setup. Along with my rears, my ears are deffinately thanking me. hope this helps someone and best of luck, any querys please dont hesitate to ask. 1 last cheeky pic
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio Last edited by Diesel Flash; 01-09-2016 at 11:21 AM.. |
01-11-2016, 02:37 PM | #2 |
Rep 2,071
Thanks for this. Doesn't look too bad. I used to to do full ICE installs in my 20's on all my cars but that was 10 years ago so I'm sure I can do this, just needed this sort of DIY to push me in the right direction!
01-11-2016, 03:09 PM | #3 |
The Flasher
55
Rep 164
Ha yeah things have changed now, its not a £1500 peugeot 205gti or mk2 golf its a 40k+ motor. I winced at every door clip coming out and several times questioned why i was doing what i was doing. But the end result was worth it. And i actually enjoyed myself like you said i felt 20 again lol
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio |
01-11-2016, 03:12 PM | #4 |
Rep 2,071
01-11-2016, 03:19 PM | #5 | |
The Flasher
55
Rep 164
Those were the days
01-11-2016, 04:10 PM | #7 | |
Rep 1,597
Had many set ups but the pinnacle was in my MK2 Golf GTi 2 JBL 1500 GTI subs - 2 1000 watt Kenwood RMS amps Infinity mids and tops - rear JBL mid/bass and mid/tops- front Active crossovers 500 watt kenwood 4 way amp for mids/tops Could hear my car a mile away, I too am slightly deaf as a result!!
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
01-11-2016, 04:17 PM | #8 | |
The Flasher
55
Rep 164
01-11-2016, 04:24 PM | #9 | |
Rep 1,597
I used to love taking that car apart, would have door panels, seats and carpets out regularly. Running cables, installing sound deadening or upgrading. However I think cars came apart more easily i.e. visible screws to undo stuff rather than the clips they use now. However we didn't have YouTube, it had to be trial and error or a Haynes manual
01-11-2016, 04:28 PM | #10 |
Rep 1,597
Or maybe kids have more sense now.... Buying a £4k car and spending £3k on mods wasn't the greatest use of cash!!
02-01-2016, 06:43 AM | #11 |
Rep 14,522
Nice install Diesel! I thought about going with another set of K2's in the 5er but probably go Gladen Extremes since it comes with the 8's. With the crossover what differences is there between the -2 and -4 settings? I searched a few Years ago when I first installed it but no luck?
02-01-2016, 07:43 AM | #12 | |
The Flasher
55
Rep 164
My pretty much untrained ear just thought they sounded fantastic compared to the oem ones so i stuck the door card back on and havent tweeked since. I have heard the gladen's are very good and have read good things about the 8"underseats, will you need adapter plates for those or do they fit nice and snug?
02-01-2016, 08:13 AM | #13 | |
Rep 14,522
02-01-2016, 08:15 AM | #14 | |
Rep 14,522
02-01-2016, 09:30 AM | #15 |
Rep 1,597
09-13-2016, 02:27 AM | #16 |
Rep 20
Where did you buy the bmw 4" adapter plates from?
I also had to order the bmw 4" adapter plates due to the speakers being a standard aftermarket 4 bolt fitment and bmws use on 3 securing bolts, adapters as shown Attachment 1344673 Attachment 1344672 i used stormguard door draft seal 10mm thick sandwiched top and bottom between adapter plates to provide a super snug sealed surface for speaker to sit. right now its time to watch bavsounds vid, several times! just to be sure about whats got to be done. Speakers and crossovers waiting to go in there new home |
