2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions FSC Generator for Navi Update 2017-1 Next
      12-13-2016, 02:30 AM   #1
Encyyo
Drives: F11 09/2012
Hello guys
For First i was Able to code my f11 (09/2012) with e-sys. It Works great. Nie i have the Navi update 2017-1 next Europe. I have a DIY Guide to Generate the code to aktivate.
Only One problem the fsc generators list do. NOT have 2017??? How can i proceed???
      12-13-2016, 06:15 AM   #2
claykin
Drives: various BMW
You need to edit the xml file and add
0x2D 0x29
2023 840GC | 2021 740i | 2019 X3
      03-06-2017, 04:49 AM   #3
berndh
Drives: BMW F11 525d
Super. This will also help me. Thanks
      03-16-2017, 09:01 AM   #4
Temrotec
Drives: BMW 640d GC
Originally Posted by Encyyo View Post
Hello guys
The exact map type can be found in Info_Map.imp in map #1 on the USB stick with new map update, using a Hex editor the first line at Offset 8 will read 00 A9 00 27 for Road Map Europe NEXT 2016-2 and 00 A9 00 29 for Road Map Europe NEXT 2017-1
Running a command line : nbt.exe DE.fsc 0xA9 0x27 7DIGITVIN >fsc.txt
(replacing 7DIGITVIN by exact VIN of your car but you can leave it blank if you wish). Fsc.txt is a simple output text file with the FSC code for your car-VIN.
      03-18-2017, 11:14 AM   #5
Mwahab
Egypt
59
Drives: F30
2015 BMW F30  [0.00]
I have a relatively similair issue, how can change the map date.
as in the navi generator there is no Egypt maps for CIC for 2012 and 2013
it is available starting from 2014 only, however there are alot of cars in which their NAVI needs the fsc code and their map is dated back to 2013 and 2012.
do you have solution? what should i change in the map?
should i send you the saved storeFSC from their car?
      10-12-2017, 03:00 PM   #6
mturnford
Australia
Drives: F10 550i 2011
Hi
Does someone have a link please to download the Australian 2017 maps?
      10-14-2017, 04:07 AM   #7
davejack
davejack's Avatar
Drives: F22
Hello guys
Hi,guy!I find below article about FSC code and BMW Navigation map update.Mayby it is helpful to you.
How to generate BMW FSC Code by yourself
BMW NBT Map Update 2017 Guide
How to generate BMW NBT & CIC FSC code
