2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions What size wheel spacers for best.
      07-26-2018, 06:46 AM   #1
monmouth356
Drives: f10
Hi everyone, I have a 2011 550x with the factory M wheels. Has anyone done wheel spacers? If so what size did you use? I want to go for an aggressive look,but don't want any rubbing.
      07-26-2018, 09:51 AM   #2
BMW550AD
Drives: 2014 BMW 550i
2014 BMW 550i  [0.00]
I did 10mm front and 15mm rear but I could have easily gone 12mm front and 18mm rear and still been good.
      07-27-2018, 09:34 AM   #3
203banshee
203banshee's Avatar
181
Drives: F10 535, F25 35i X3, EVO 8
I went 20mm in the rear and it looks great IMO. No rubbing or anything even close to that (Even when I have 5 ppl in the car).
      02-01-2019, 09:30 PM   #4
chmsalman
chmsalman's Avatar
Drives: 2014 F10 535i x-drive
what size are your rear tires? Just wondering if its a staggered setup or square.
I want to get new rims, going for the staggered setup with the 275 at the rear. Do you think I'd need a 20mm spacer to get the same look?
      02-24-2019, 11:12 AM   #5
Luky
Luky's Avatar
Drives: 2016 550i M Sport
If you are going for a staggered set up with different width wheels front/rear you can just get new wheels with the correct back spacing so you don't need spacers (but you cannot rotate these front to back, and only rotate side-side if the tread is non-directional). I would think you only need spacers for a square set up to push the wheels flush with the wheel wells (which is more cosmetic). I have the staggered set up on my 550i and probably will be going to square with some spacers in the future when my current tires wear out... I like to be able to rotate the tires to get the most life out of them.
      03-03-2019, 04:58 PM   #6
chmsalman
chmsalman's Avatar
Thanks for that. I don't understand I can just get the right wheel dimensions to start off with.
I was asking above poster to confirm his picture was with a square setup and 20mm spacer rather than a staggered with another 20mm spacer on top.
Most likely square with the spacers on the rear.
      06-13-2019, 02:55 PM   #7
cals
cals
cals's Avatar
17
Drives: E34, E39, E60, F10, E70, F15
2017 BMW X5  [0.00]
2001 BMW E39  [0.00]
2004 BMW E60  [0.00]
2011 BMW F10  [0.00]
2007 BMW X5  [0.00]
I have a 535ix with Square Setup - 19" Sport Wheels (Tires 245/40 R19) and installed 17mm Spacers in the rear with no rubbing issues
      06-13-2019, 05:48 PM   #8
Desilvyr
Drives: 2012 BMW 335i / 2015 BMW 528i
I would say go for 12mm and 18mm
