2010 2011 BMW 5 Series Forum F10 Buckled wheel problem HELP |
10-25-2019, 06:14 AM | #1 |
Rep 5
Hi I have a 2010 bmw f10 530d msport (uk)
One of my wheels are buckled I took it to a local garage to get all 4 wheels refurbished and the buckle sorted . They put a set of 19 inch bmw wheels on not sure what model threw up drivetrain fault breaking faults and tyre faults . Immediately changed the wheels back and all the lights went off but now I'm stuck with a buckled wheel Any suggestions |
10-25-2019, 07:30 AM | #3 |
Rep 7,586
Wheels & tires work as a combo and when discussing them (especially if you're seeing warnings from the check control system)...the size/specs of BOTH the wheels and tires need to be considered in the discussion.
For example, many 5/6/7 series WHEELS may be interchangeable...but the 7 series (and I believe the f07 6GT) uses a larger TIRE overall diameter/circumference. So mounting their wheels may be okay...but you need a lower profile TIRE mounted on their wheels. In regards to the TYRE fault...please be more specific. Was it the TPMS warning that indicates that the tire pressure? Anytime you exchange wheels/tires...you need to reset/reinitialize the TPMS to set a new baseline.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
EL Jeffe 5612.50 lsturbointeg9167.50 |
10-26-2019, 10:19 AM | #4 |
Rep 14,521
what is "buckled" as I never heard that in regards to wheels?
10-26-2019, 10:51 AM | #5 | |
Rep 5
10-26-2019, 11:26 AM | #6 |
Rep 14,521
ah we call it bent in the US
