2010 2011 BMW 5 Series Forum F10 2014 F10 and BMW 313 wheels does it fit? |
03-13-2020, 05:06 AM | #1 |
PhillyF10
Rep 4
Does anyone know if I can put a BMW 313 style wheels on a 2014 F10 (535xi). What tire sizes is recommended for the front and rear without getting a spacer along with fitting on the 313 wheels. Thanks
More information: BMW 313 wheel came off a E90 335i, 19" wheels 5X120, front 8/19 rear 9/19. Hope these added information help - thanks I currently have 18" wheel with 245 45 R18 tires, trying to see if this 313 wheels can be a direct fit with new tires size. |
03-13-2020, 08:50 AM | #2 | |
Rep 7,535
Give us something to work with. Collectively...we may know the wheel offset range for the f10 5 series and may be able to play around with a few alternate tire sizes for the various wheel diameters etc. But you only gave us a BMW wheel style number (thanks for that )...and probably 99% of us will have to go dig up specs and other details just to attempt to give you an answer. If you already know this info...give us a helping hand to help you.
EDIT: just came back from a quick search about this wheel...and it looks like it was offered in 3 different models...and has 3 different specs...which one are you looking at? That will help determine tire sizes required and what the wheel offset will be. And if you want something with more or less "poke".
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-13-2020 at 04:27 PM.. |
03-13-2020, 11:50 AM | #3 |
Rep 5,388
And use this to get the right size (circumference) tire/wheel combination.
https://tiresize.com/calculator/ |
jchenman0.00 |
03-13-2020, 02:20 PM | #4 | ||
PhillyF10
Rep 4
03-13-2020, 04:39 PM | #5 | |
Rep 7,535
Then you can compare the e90 19" Style 313 wheels to the various f10 19" wheels. If the offsets are within millimeters of each other...and the wheel widths are the same or within inches of each other...then you should be able to mount the recommended 19" site tires for the f10 to those wheels. The e90 and f10 share the same hub size (72.56mm) and the same wheel bolt pattern (5x120mm). You can also compare the 18" & 19" wheel tire combinations at the following site to see how much "poke" and/or "inset" the 19" wheel/tire combo will have versus the original square 18" wheel/tire combo you have. Compare the old front to the new front axle setup...then the old rear to the new rear axle setup: www.willtheyfit.com
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
jchenman0.00 |
03-16-2020, 04:49 AM | #6 |
Rep 482
The wheels will fit with those offsets but overall look is subjective so with that being said if the main reason you are going from your current 18 to 19 for something more flush with your fenders these will not help. Additionally they would look great on a E90 but an F10 not so much!
03-18-2020, 07:07 PM | #7 |
Rep 277
Yes they should fit no problems
Tires should be able to go pretty thick as well. Guards are pretty good on the F10s but just depends on your awd? Might need all the same sized tyres to not throw it off? |
03-27-2020, 12:20 AM | #8 |
Rep 46
313's totally fit . I have 19's
ezaircon4jc4534.00 |
