04-20-2020, 12:48 PM | #1 |
Rep 18
AC Blower Turns Off -
535i 2013
I have been experiencing an intermittent problem with my vehicles Climate control. When I turn the AC on past the third level - max it will shut off. It will resume if I leave it off for a few minute but has to be below the third level. (this happens regardless of AC, Defrost or heat) I recently changed the Fan Motor Regulator/Resistor and that did not help (still experiencing the same problem). I am considering changing the blower motor next but I am unsure if that is the problem as the motor does turn on and works partially. Is there a way to bench test the regulator with a multi meter? What should be the next step. Thank you all in advance for all the help!! |
04-20-2020, 01:01 PM | #2 |
Rep 1,876
What is the condition of your battery and charging system? Any battery, charge level, or "discharge while stopped" messages on your cluster?
The IBS can make high loads like the blower fan and heated seats shut off or be limited in speed if your battery is weak. If you have replaced your battery, was it registered? |
04-20-2020, 01:30 PM | #3 |
Rep 18
93k on the vehicle with original battery. No messages on dash and everything else works.
Should I will go get the battery tested? Or can I just take the voltage and identify like that? |
04-25-2020, 12:33 PM | #4 |
Rep 18
Just got the battery tested and it is bad.
QUESTION If I buy an exact fit battery with the exact specs will I still have to register? Thank you |
OnlyGerman363.50 |
04-25-2020, 05:04 PM | #5 |
Rep 5,409
Yes. The IBS needs to know the condition of the battery; i.e. how many hours on it, age, state of charge... things of that nature.
04-25-2020, 05:52 PM | #6 |
Rep 1,264
Interstate battery can register it. Replaced a battery in my E60 just a few weeks ago and they did it all. If your changing the type of battery then it needs dealer attention.
05-17-2020, 09:17 AM | #7 |
Rep 18
Okay, So far I have replaced the battery and registered it with foxwell scanner, replaced the ac regulator and the ac is still turning off after a few minutes of it operating at high fan speed.
I am thinking of replacing the motor but when it runs it runs strong. So I am stumped. Please help. |
05-17-2020, 11:15 AM | #8 | |
Rep 5,409
05-17-2020, 06:07 PM | #10 |
Rep 5,409
05-18-2020, 08:55 AM | #11 |
Rep 1,876
05-18-2020, 12:05 PM | #12 |
Rep 697
Drives: 2013 535xi
This was my experience when my AC ran out of refrigerant. The interior blower continued, but there was nothing cold coming out. In fact, prior to complete cooling failure, while there was still perhaps bit of refrigerant in the system, I could hear a loud hissing sound from inside the cabin when the compressor kicked in and it had almost nothing to compress.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
ezaircon4jc4574.00 |
05-20-2020, 05:52 PM | #13 |
Rep 18
The blower shuts off regardless if the AC is on or off. I have tried it with ac off, heat on and ac on and it does the same thing. Shuts off after a few minutes of running high. Oh, btw AC is cold.
08-07-2020, 08:56 AM | #14 | |
Rep 1
I am facing an issue with my F10-530D where in the blower speed reduces automatically. At start up the blower speed is proper , but it reduces after couple of seconds. Is any one facing the same issue ? Do you guys have any solution for the same ? THanks in Advance |
08-15-2020, 10:10 AM | #15 |
Rep 1,254
Did you get this fixed
I started experiencing noise with my blower motor I opened cover under the hood come to find out filter on the box was detrained and bunch off leafs and other crap was stuck. I took motor out clean everything replaced filter with coarse pond filter everything is back to normal
12-30-2021, 09:33 AM | #16 | |
Rep 1
Solved
I took the blower assembly out and changed the control module on the side, but that had no effect. I then read someone changed the fan and that solved the problem. I was at first a little unsure about this, as the fan seemed to run fine at full power, so why would that be a problem? When I compared the new motor assembly with the old one, it was obvious that the old one seemed stiffer to rotate. My guess is that this extra resistance caused a current anomaly or voltage drop that the control unit saw and then rolled the power back to avoid burn out. Dropped the new motor into the blower assembly, cleaned it all out and popped it back in and it now works as new. In fact, there appears to be a performance increase, or at least restoration. |
