2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Idle Tensioner Pulley Problem
      06-15-2020, 08:09 PM   #1
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
So I bought the INA tensioner from FCP Euro for my F10 535i and after installing I noticed that the shaking has come back a lot. I don't know whether I got a faulty part but the older still shakes enough to mess up my idle.
      06-15-2020, 08:32 PM   #2
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
It should have a small play... post a video... did you get the genuine Bmw part?
      06-15-2020, 08:49 PM   #3
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Mine wobbles a little after replacement
      06-15-2020, 09:04 PM   #4
ey2001
ey2001's Avatar
310
Yea little bit is fine
F10N557.00
      06-15-2020, 10:02 PM   #5
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
I replaced mine with the same part from fcp. Still had shakes after install. That is the oem part supplier for the tensioner
      06-15-2020, 10:03 PM   #6
David_Vasha
I will post a video tomorrow. It is worse on cold starts
      06-15-2020, 11:28 PM   #7
BurrNinja
I have same thing. Little movement is perfectly fine.
Instgram @burninja
      06-17-2020, 01:00 PM   #8
David_Vasha
Here is the video. The wobble sometimes gets even worse than what's in the video.
      06-17-2020, 01:38 PM   #9
BimmerHausPerformance
BimmerHausPerformance's Avatar
514
Drives: F10 S55, E93 M3, E89 N54
2012 BMW Z4  [0.00]
2011 BMW 535i  [10.00]
That is fine, IMO, because that's what it's supposed to do to allow some play...PLUS you are not getting noise like mine! I'll post a video.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      06-17-2020, 01:45 PM   #10
514
2012 BMW Z4  [0.00]
2011 F10 S55 6MT
      06-18-2020, 09:27 AM   #11
OnlyGerman
OnlyGerman's Avatar
Normal as long as there is no noise
      06-30-2020, 10:17 AM   #12
mashpotato
Drives: '11 F10 N55
just curious. During the tensioner work, has anyone replaced the idle pulley near the alternator and AC compressor? I could not get to it as the hard AC lines are in the way.
      04-13-2024, 05:40 AM   #13
happian
Drives: BMW F10 535i
mashpotato, yup, I had the exact same problem and ended up replacing tension pulley and belt only. I did a bit of research and found AC compressor can be detached after removing air box and charge pipe. This will give me the way to idler pulley volt access.
