2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum What to do
      10-31-2020, 09:49 AM   #1
moshii
Drives: F10 535i
What to do
Hi friends,
2012 535ix (Automatic) with clunky/jerking problem at something like 8 mph and again at about 21 mph (slightly less) then completely fine at higher speeds.
It's started at about 125,000 miles. Currently at 130,000. Replaced transmission fluid, pan and filter when it first started happening and it did not help. It wasn't that bad then so I ignored it. Gradually it seems to be getting worse and now its is bothering me enough that I cannot just ignore anymore.
I tried the "Reset Driver Memory" as described here. The problem does not go away entirely but it does seem to help a lot but only temporarily. Switching to sport mode makes the clunking/jerking worse.
Will getting it "flash" coded help? Custom tuning?
Should I try the dealership for engine transmission software update? (Never had any sort of software update)
Will any of these solve the issue? Advice please, thank you!
      11-01-2020, 03:12 PM   #2
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Did you check the transmission mounts?
      11-02-2020, 03:37 PM   #3
mashpotato
Drives: '11 F10 N55
if it is the tranny internals. You can check clutch fill pressure (indicate wear) through ISTA-D, XHP and some other apps. My tranny is not doing so well on downshift to lower gears. For the 8 speed is 5 clutches: I read somewhere good performance <180mBar, ok <300mBar, just operational is <750mBar (XHP recommends).
Flashing might help a bit, but in the end it cannot fix wear and tear (for me its too late to change tranny oil). So you have to rebuild your valve body or other fixes.
      11-06-2020, 07:51 PM   #4
moshii
Drives: F10 535i
Went to the dealership and asked for engine and transmission software update. They did something called 1.5 Program (that's all it says on the service sheet). This 1.5 Program unfortunately hasn't resolved the clunking/jerking.
Inspection & recommendations show I need to replace the drivetrain flex disc and change the oil for the transfer case.
I keep getting a Drivetrain malfunction warning that says, "Drive moderately maximum output not available" which I've never had before the update. Car won't go over 20 mph when this happens but it goes away when I restart the car. The warning keeps coming back though....
I hope replacing the flex disc and changing out the oil like dealer recommend will fix all the issues....
      11-06-2020, 07:53 PM   #5
moshii
Drives: F10 535i
Thank you I will get this checked
      11-06-2020, 07:54 PM   #6
moshii
Drives: F10 535i
Transmission mounts no problem
      11-06-2020, 08:04 PM   #7
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
bad engine mounts, bad transmission mounts, driveshaft issues? Just some of the things that could cause vibration
      11-07-2020, 08:30 PM   #8
RConnor535i
Drives: 11 BMW 535I
Changing the Vanos solenoids fixed my jerking and stuff
