2010 2011 BMW 5 Series Forum F10 Repainting brake calipers? |
07-19-2021, 05:39 PM | #1 |
Rep 175
A few years ago I used a G2 caliper paint system on my F10 to paint the calipers red. They're chipping pretty bad so I was thinking about repainting them with a different G2 color. Have any of you repainted calipers? Wondering if a rough sand and clean will suffice, or if I need to remove the paint all the way? G2 says a rough sand will work but wanted your input. Thanks.
07-19-2021, 10:00 PM | #2 |
Rep 14,521
i did mine back in July of 2017 and i did mine with gold! still holding strong as i made sure it was super clean from dirt and grease so it doesn't start to peel and flake.
EV8634.00 |
07-20-2021, 01:48 PM | #3 |
Rep 175
Damn, that looks good! Especially with gold rotors. Is that G2 gold? Was that the first time or did you paint over old caliper paint?
07-20-2021, 07:49 PM | #4 | |
Rep 14,521
https://f10.5post.com/forums/showthread.php?t=1409223
07-21-2021, 09:11 AM | #5 |
Rep 2,595
M539 had good luck with this epoxy based paint:
https://www.foliatec.com/shop/en/rim...er-lacquer-set
2015 BMW 535xi
07-21-2021, 12:20 PM | #6 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Planning on doing the same with G2 (blue) once the weather cools a bit. DC heat & humidity is unforgiving this days. I have to replace my rear discs/pads so will plan to paint off the car (similar to M539). Already ordered brake line plugs for when disconnecting calipers.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
07-24-2021, 02:23 PM | #7 |
Rep 14,521
i ended up swapping out the OEM lines for the Goodridge stainless steel lines when i did upgraded to my custom CQUENCE brakes!
