2010 2011 BMW 5 Series Forum F10 How can Code out adaptive headlights using bimmer code? |
06-20-2022, 12:46 AM | #1 |
Enthusiast
507
Rep 318
Drives: 2025 M4 Comp xDrive
Hey guys my 2012 pre lci 535 x drive was getting a good ole car wash and then all of a sudden all these light malfunctions happened. The passenger side Angel eyes are out and the driver side REAR tail lights hyper blink. The passenger side indicator hyper blinks too. I opened the headlight cap and let everything dry out and the blinkers all work properly now. However the right Angel eye turns on when I unlock the car but as soon as I start the car I get "adaptive headlight malfunction" and my passenger side Angel eyes turn off and no longer turn back on. I don't know if the tms is damaged but I am thinking that if I'm able to code OUT the adaptive headlights then my Angel eyes will turn back on.
2025 M4 Competition xDrive
IG: Automaz_ |
06-20-2022, 09:27 AM | #2 |
Rep 1,261
That will not fix DRL. The module controls everything besides low/high beam. Better to isolate issue and correct. Check module, it may still be OK
06-20-2022, 03:09 PM | #3 |
Enthusiast
507
Rep 318
Everything is now working perfectly again
However I keep getting the adaptive headlight malfunction error and cannot clear it using bimmerlink Can anyone help me clear this code?
IG: Automaz_ |
06-20-2022, 08:54 PM | #4 | |
Rep 139
automaz_507.00 |
06-20-2022, 11:05 PM | #5 | ||||
Enthusiast
507
Rep 318
Thanks for the video link
IG: Automaz_ |
06-21-2022, 08:33 AM | #6 |
Enthusiast
507
Rep 318
It's kind of ridiculous that everything on my car works perfectly fine but this error will not go away. ADAPTIVE HEADLIGHT MALFUNCTION is the worth error possible created lol
IG: Automaz_ |
06-21-2022, 08:34 AM | #7 | ||
Enthusiast
507
Rep 318
Did you have to do any coding after installing?
IG: Automaz_ |
06-21-2022, 06:35 PM | #8 | |||
Rep 139
06-22-2022, 11:45 AM | #9 |
Enthusiast
507
Rep 318
BimmerCode - how to code out adaptive headlights
I've done so much research but can't seem to find the answer for F10. I know it can be done as people have commenting saying online that they've done it. Does anyone know how to code out adaptive headlights for the F10 using bimmercode?
IG: Automaz_ |
06-22-2022, 07:09 PM | #10 |
Enthusiast
507
Rep 318
I figured out the solution
After many days of trying to code this thing. It was 100% possible to code out the infamous "ADAPTIVE HEADLIGHT MALFUNCTION" using bimmer code for the F10
Go to footwell module and expert mode and select FRM 3400 and change the following three sections ALC_AFS_ENABLE > nicht aktiv AHL_ENABLE > nicht aktiv LWR_AHL_TYP > ohne_lwr No more Adaptive headlight malfunction error code
IG: Automaz_ |
07-17-2022, 04:54 PM | #13 | |
Enthusiast
507
Rep 318
Yeah otherwise the tms module needs to get coded. I ended up getting a new tms module but I will be doing custom headlights anyways though so will have to disable adaptive headlight
IG: Automaz_ |
02-22-2023, 12:45 PM | #14 | |
Rep 35
Thanks so much for providing this code! I've been dealing with this error message for longer than I can remember and just came across your fix. Much appreciated!! |
02-23-2023, 06:58 AM | #15 |
Rep 2,485
Just a word of warning, the LCIs use a different sized module - it has the red gasket and three screw holes. That one DOES need coding. Pre LCI module is slightly smaller and just has two screw holes.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
ChiltiCoatl891775.00 |
03-19-2023, 02:02 PM | #16 |
Rep 88
It’s probably just worth buying a new one from an aftermarket shop considering you’ve had the car for awhile, it sucks these F10’s are prone to this type of headlight damage.
Car washes, rain or just condensation really destroy them. |
03-25-2023, 06:27 PM | #17 |
Rep 5
Did you code it yourself? I'm in the same boat--replaced the module but now need to program it.
