04-27-2023, 08:55 PM | #1 |
Rep 353
Faint knocking sound
Does anyone know what a faint knocking sound might be? It's audible only from inside the cabin and in the steering wheel. If I turn the climate off it goes quiet. Thank you!
04-28-2023, 09:24 AM | #2 |
Rep 1,876
Need more description to get an answer (how frequent, how loud, what pitch, sound metallic or dull, varies with engine RPM?)
But, what comes to mind for me based on what you've said is heater control valves - #5 on this diagram https://www.realoem.com/bmw/enUS/sho...diagId=64_1665 They sit near the top of the engine compartment just fore of the brake booster area. They often seem to make a "thump" when cycling on and off. This happens when the engine is up to temperature and the interior climate control is calling for partial heat. They will thump once per second or so and if the interior is quiet it can be heard and felt. Pop the hood and check these out to confirm. This isn't an F10 thing. My E39 had the same behaviour. There's some debate whether that indicates failure of the valve or not, since it seems to continue to work fine. |
zvery777292.00 |
04-28-2023, 09:28 AM | #3 | |
Rep 353
Thank you for your input! |
12-21-2023, 08:09 PM | #4 |
Rep 353
Replaced the heater control valve today but the thumping seems to still be there, also my front center vents blow hot air when heat is on but not the side ones (front passenger and driver). Does anyone know what this could be?
01-05-2024, 10:57 PM | #7 |
Rep 132
ChiltiCoatl891779.50 zvery777292.00 |
01-06-2024, 03:24 AM | #8 | |
Rep 353
01-06-2024, 04:20 AM | #9 | |
Rep 1,876
If you're trying to fix normal behaviour, bumping the thread isn't likely going to get you much more info. If you've replaced the valve twice and both new ones thump, and your heat is working, maybe you're done. |
01-06-2024, 08:51 AM | #10 | |
Rep 353
I'll keep pursuing this issue and update the thread once I can get this figured out. Thank you everyone for their input! |
01-06-2024, 09:54 AM | #11 |
Rep 132
zvery777 , Could it be air in the cooling system somehow or someway? How about bleeding the cooling system. There is no wrenching involved and it takes 10 minutes. I think its worth the try. Cheers
01-06-2024, 10:39 AM | #12 |
Rep 353
I did the bleeding every time I replaced the valve and not just once. I also feel like there could be air trapped somewhere. Will keep trying to get to the bottom of this!
