2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Drivetrain Malfunction Full performance not available
      10-21-2023, 05:06 PM   #1
ADOSne
Drives: F10 2012
Hi , i got Drivetrain Malfunction Full performance not available problem ,
Car : bmw 520d 2012 f10
i run diagnostic and got those problems , which one is the Main problem and how can i fix it ?
-28CC00 LIN bus : Communications fault Permanent
-28E200 Exhaust temperature sensor upstream of the oxidation catalytic
converter, signal: Open or short circuit to B+ Permanent
-2A0D00 Local Interconnect Network, bit-serial data interface, message;
alternator: missing Permanent
-2AA000 Thermal oil level sensor, signal: No signal Permanent
-24CE00 Air mass measurement: Measured air mass is too high
compared with the calculated air mass. Permanent
-244C00 Charging pressure control, control deviation: Charging pressure
too low/positive control deviation Permanent
      10-22-2023, 05:07 AM   #2
ADOSne
Drives: F10 2012
Any Help ?
      02-16-2024, 09:17 AM   #3
Dlucke17
Drives: 550i, X5, 240sx
Update? ADOSne
