2010 2011 BMW 5 Series Forum F10 Did I Reduce F10 Exterior Noise With $29.56 + 30 Minute Install Time? |
01-06-2024, 08:12 PM | #1 |
Rep 870
I thought long and hard before deciding to post, as results may not be replicated in other vehicles.
There is a long history of folks chasing the noise reduction in the F10, and after driving around for a month now, and having rear seat passengers confirm, there is a small chance that this info might help other F10 owners. After comparing a G12, that is really quiet, with that of the F10, there were major differences between the two regarding the seals around the doors and while I could have modified the G12 gaskets, it was much cheaper to use the two items below:
There is a night and day difference in exterior noise in side of the vehicle. It was well worth $29.56 and 30 minutes to install. The key to all of this working really is how you install, as well as "where" you install....I can provide more pictures if asked. I will post a picture of the fender and door gap fill in a future post. I plan to redo it so it's tucked in a bit better. BTW, the road noise due to my almost bald run-flats will be further reduced when I put in non-run-flats this Spring...but even now, the F10 is now almost as quiet as my G12. Wish I had done this 9 years ago. Last edited by M_Bimmer; 01-06-2024 at 08:51 PM.. |
01-08-2024, 10:32 PM | #4 |
Rep 870
Will do...I'll post them later in the week.
I also found another gasket shape for the bottom of the door, and ordered it. I will install that, test it, and post more pictures this weekend. While I could claim the noise reduction could be discounted as a placebo effect, this effect can't be manifested by all my passengers, without telling them what I did. The sound reduction is similar to the sound reduction from rolling up your window completely, versus having it opened about an 1/8 to 1/4 of inch. And it could be said that my door seals are bad...they are 10 years old and I'd say the $28 is much cheaper than replacing multiple seals on each door. Noise propagated through a solid panel is NOT reduced, but this noise reduction is mainly from my almost bald RFT's. I am currently trying to address the air noise from the mirror assembly. Last edited by M_Bimmer; 01-09-2024 at 11:04 PM.. |
StradaRedlands5033.50 |
01-09-2024, 07:51 PM | #7 |
Rep 231
I did this to reduce the door noise while I was upgrading my speakers.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
