01-21-2024, 09:16 PM | #1 |
Rep 16
Ebay Headlight
Hello, I found the headlight on eBay for $369 new. Has anyone here had any experience with a non-OEM headlight from ebay? Here is the link.
https://www.ebay.com/itm/40444062858...tid=5304439119 Moisture got in my driver side headlight, and now I get adaptive headlight malfunctions, headlamp vertical aim control malfunction errors, and also daytime running lights that don't work. I really don't want to spend $1000 on a used OEM headlight. |
01-22-2024, 03:59 PM | #2 |
Rep 52
You may need to replace the control module instead of the headlight assembly.
Try drying out the headlight and see if that resolves the malfunctions/errors. Use GE advanced silicone kitchen & bath caulk ($11 at Home Depot) to seal your existing headlight. There are many posts about this issue. |
01-23-2024, 08:09 PM | #3 |
Rep 16
I replaced the control model; the old one was all corroded from the moisture. By changing it, I got the blinker to work, but the day-running light is still out.
I will try to use silicone and at least stop water from coming and creating more damage. Thanks. |
02-03-2024, 01:02 PM | #6 | |
Rep 16
No i did not. Is that something i can do with bimmercode? |
02-13-2024, 07:09 PM | #7 |
Rep 16
