2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Can't get to position 2 on Ignition DME,EKPS,DKG,LMV not responding
      05-10-2024, 10:21 AM   #1
iverson03tj
Drives: e39 M5, F07 535gt xD
Unhappy Can't get to position 2 on Ignition DME,EKPS,DKG,LMV not responding
I am way out of the depths here. But I hope you guys can help me solve this issue.
Car was running normal, AT ran smooth, never an issue, I heard a weird intermitent clattering noise while idle.
I stopped my car to check under the car and then it wouldn't start up again...
- Transmission malfunction & parking brake limited notice on dash with 4X4 symbol
- Can't get out of parking (I know I can if i go underneath the car if i have to)
- Lights on dash flicker when i press push-start (won't stays in Position 2)
- won't stay into position 2 even with brakes off (Ista didn't like that, kept losing connection)
- No crank, No start
- Voltage was 11.6v at battery, T30, T15 and inside engine bay cleaned ground wire on the leftside of engine bay.
- Checked fuses for power and continuity
- checked power at battery distribution fuses
- ordered a Oscilloscope but not sure how to use it yet. Learning how to read wiring diagrams as I go
Trying to learn as much as possible from a BMW F01 Workbook on modules.
Any help is greatly appreciated!!
      05-10-2024, 12:37 PM   #2
s_ribs
Drives: '15 535i xDrive M-Sport, E30
Other more seasoned folks like chime in but culprit #1 is your battery. 11.6v is dead. Modern cars do funky things when batteries get too low.
Have you tried charging the battery? It may be time to replace it too.
      05-10-2024, 07:46 PM   #3
iverson03tj
Yes, It was my own doing letting the battery get that low.
But i charged it overnight till its stable at 12.6v and passed a volt drop test.
I really need to get these modules to communicate, atleast then i can try flashing them.
I believe my primary fault is something to do with the Gear selector switch. GWS to EGS/DME. But what do I know xD
      05-10-2024, 07:56 PM   #4
iverson03tj
This is why I think its due with the GWS. Test plan is prioritizing it.
Is it possible to maybe run a service function to override my car to put it into Position 2, just to run the ABL?
      05-15-2024, 02:30 PM   #5
iverson03tj
SOLVED! I think... Only drove it for 15 kms so far
But it turns out it was the ground strap that is near the transmission.
Even though once i used a multimetre and tested the voltage and continuity and passed that test.
I guess it wasnt a great connection. $80 CAD at the dealership for this wire but worth the pain of finding out it didnt work.
s_ribs46.50
      05-15-2024, 02:32 PM   #6
iverson03tj
Side Note: I want to add some more ground wires to prevent this from happening anyone have any tips on where i should place them?
