@bimmerpost on twitter
BimmerPost - BMW Forums
BMW Garage BMW Meets Register Members List Search Today's Posts Mark Forums Read
2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW unveils single turbo N55 six-cylinder engine for new 5-series GT
      05-26-2009, 02:28 PM   #1
darknightohio
Drives:
BMW's latest engine dubbed the N55 is a twin scroll single turbo engine which boasts 306HP and 400Nm of torque out of a 3.0 litre inline 6 cylinder engine. Sound familiar? Yup this is a similar amount of power from the N54 of 335i/135i fame, but now using the new twin-scroll technology BMW can achieve this power from the use of only one turbo.
This is not simply a more efficient engine, but it achieves the similar amount of power with quicker throttle response and max power lower in the rev range (1200rpm).
What is twin-scroll?
Dual side by side exhaust inlets feed into a single housing in this setup. Because there are now two exhaust inlets being fed into the housing the exhaust channel can be smaller given more precise control of the velocity of air flow.
Valvetronic -- finally
Yes valvetronic is back in BMW engines again, due to technical reasons the engineers weren't able to use valvetronic correctly with the N54 but have finally overcome whatever obstacles were in their way and now it returns to the N55 with direct injection.
This engine is making its debut on the 535i GT but as in BMW fashion will likely filter down the range and take its place in the 135i, 335i, 535i, 735i, etc..
BMW’s current N54 series straight-six engine is one of the most praised engines in the industry today, having taken out the coveted International Engine of the Year award last year and appearing in a vast array of BMW models. With the unveiling of the new 5-series GT last week, BMW has announced a new variation of the 3.0L engine which will debut in the crossover at the end of the year.
The N54 features a twin-turbocharging system, as well as direct-fuel injection and BMW’s own Valvetronic technology, and in its most potent configuration develops up to 326hp (243kW) at 5,800rpm and 332lb-ft (450Nm) of torque from as low as 1,500rpm. BMW’s new variation on the engine, labeled the N55, is based on the same basic engine block and valve system but only sports a single turbocharger. It is the world’s first engine to combine turbocharging, direct fuel injection and fully variable Valvetronic valve management developed by BMW.
Peak output is still a healthy 306hp (225kW) at 5,800rpm and 295lb-ft (400Nm) of torque from an even lower 1,200rpm. Furthermore, the new N55 is also said to be more fuel-efficient than the N54 though no independent test results have been produced.
As previously mentioned, the N55 engine will debut in the 535i 5-series GT along with an eight-speed automatic transmission. This model will be able to accelerate from 0-100km/h in around 6.3 seconds and is rated at 26mpg (9L/100km) in fuel economy.
http://www.motorauthority.com/bmw-un...series-gt.html
darknightohio is offline
      05-26-2009, 02:42 PM   #2
sparkyg
sparkyg's Avatar
Drives: SSII 2008 E90 M3
wow, intereting torque beast, must have a small impeller and prob does not rev that high hense teh peak hp 5800 rpm
Good for a family car like the GT
Look forward to more details
sparkyg is offline   Canada
      05-26-2009, 03:05 PM   #3
lyndon_h
lyndon_h's Avatar
Drives: e90
Yep, good for family cars and SUV's, CUV's
lyndon_h is offline   Reply With Quote
      05-26-2009, 04:40 PM   #4
ptack
ptack's Avatar
Drives: 135i
Good for little old ladies and the like.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod
ptack is offline   United_States
      05-26-2009, 04:42 PM   #5
boymonkey
Drives: slow
New fuel pump?
boymonkey is offline   Taiwan
      05-26-2009, 05:02 PM   #6
Excitmnt94
Detailer & Fitness Freak
Drives: '09 135i ///M Sport Coupe
Send a message via AIM to Excitmnt94 Send a message via Yahoo to Excitmnt94
8-speed auto? *sigh* who the #$%^& needs 8 forward gears?
135i coupe...Alpine White // Glacier Silver Aluminum Trim // Heated Coral Red Leather Seats // M-Sport Package // I-pod // PDC // 6-Speed Manual
Excitmnt94 is offline   United_States
      05-26-2009, 05:04 PM   #7
Mega Man
エアーマンが倒せない
Mega Man's Avatar
Drives: 2009 135i
Sounds good!
You know what sounds better though?
TWIN-Turbo
Mega Man is offline   Japan
      05-26-2009, 05:25 PM   #8
Deda
Deda's Avatar
Drives: BMW X6 35d
so cool!
Deda is offline   Croatia
      05-26-2009, 05:35 PM   #9
imported_mega
Drives: various bmw's
why the n54 picture?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Gone but not forgotten..
1974 2002, 1987 325ic, 1987 325is
1995 M3, 2001 X5, 2007 MCS R56
imported_mega is online now   No_Country
      05-26-2009, 07:48 PM   #10
McReary
Drives: 2008 AW 128i
Send a message via AIM to McReary
al gore will be unsatisfied.
McReary is offline   United_States
      05-26-2009, 08:16 PM   #11
mapezzul
Special Agent
mapezzul's Avatar
Drives: Depends on the day!
Here are some images from my flickr account- sorry they are not full res, I made them too small and have not had a chance to fix them.
This motor (N55) will NOT be replacing the N54. It will not be part of the initial launch of the GT in the US. There will be no TWIN POWER name in the US- THANK goodness as that is the cheeziest- name ever ( EU Only will see that naming).... US will remain as BMW POWER or M POWER ONLY; no stupid tag lines.
Like we have been saying for months; BMW will be releasing several new motors using twin scroll chargers (next step in Efficient dynamics). Everything I hear points to a US launch in the last model to receive a turbo engine (outside the ///M)- I am sure you all know what that is!
There is also a power bump coming to another motor in the future as well....
Lots of new stuff in the works; it is a great time for us enthusiasts; and me being the only one who like the 5er GT (it looks better in person).
2008 ///M3 Sedan: Jerez, Sycamore, ZTP, ZPP,ZCW,EPS, iPod, 6 speed
2007 530XIT ED 3/22/07
BimmerFile.com
mapezzul is offline   United_States
      05-26-2009, 09:01 PM   #12
tpipta
Drives: 2009 E92 335i
looks like a decent sized compressor housing.
2008 Alpine White 335i - Lemon
2009 Alpine White 335i - Round 2 Basic Mods: GP Thunders, Painted Reflectors, Matte Black Kidneys, JB3 1.22
tpipta is offline   Reply With Quote
      05-26-2009, 09:13 PM   #13
ik999
ik999's Avatar
Drives: monacoblau e90 335i
n54's peak power is also at 5800rpm
ik999 is offline   Canada
      05-26-2009, 09:40 PM   #14
BMWI6
BMWI6's Avatar
Drives: P: 2005ZHP, 2007335 C:Z4M
will still take the TWIN turbo n54 over it in a heart beat.
If everything seems under control, then you are'nt going fast enough"
BMWI6 is online now   Colombia
      05-26-2009, 09:45 PM   #15
GreenPlease
GreenPlease's Avatar
Drives: BMW 335i e92
Ultimately, this lowers the cost of the engine. Valvetronic is sort of a bittersweet addition. Amazing technology for sure but it is a pain in the ass for tuners to work with. Valvetronic is solely responsible for tuners never touching the existing 550i, 650i, and 750i (now replaced).
The 8 speed from ZF is a work of art. See these articles on GCC:
ZF Develops 8 Speed Automatic
New Hydraulic Oil Element
The 8 speed will shift faster AND be more efficient AND it allow for skipping gears. Thus, in theory, you could be cruising along in 7th and drop it directly to 2nd for an overtaking maneuver.
Anyone else think that the piping (DP?) from the turbo to the catalyst looks RIDICULOUSLY small?
GreenPlease is offline   United_States
      05-26-2009, 10:05 PM   #16
Thud
Throbbing Member
Drives:
Originally Posted by Mega Man View Post
Sounds good!
TWIN-Turbo
That is so 1990's. Nowadays we say "biturbo."
I wonder what kinda power that twin-scroll (biscroll?) motor will make with a tune?
2008 135i / SGM / Terra / Grey poplar / sport / premium
Previous cars...
2002 Z06 Black/red, hurst shifter, blackwing intake (sold)
2001 Audi A4 2.8 quattro / white / tiptronic / daily grocery-getter (..traded)
Thud is offline   Reply With Quote
      05-26-2009, 10:20 PM   #17
kooper
Drives: E36 M3 (I wish)
Hopefully with BMW bringing out more of these sweet turboed inline 6s, that means the V6 M3 rumor is nothing more than just that. Rumors.
Maybe this is a good time to share what I've read in a local magazine recently:
Apparently, possible collaborations (very hush-hush) are being discussed between Merc and BMW. Up to the point of them sharing chassis for the next 3 & C, 5 (6) & E (CLS), Mini & A/B and X5 & ML/ X3 & GLK. Probably more like the Z4 & SLK, SL & Z-who-knows-what. Apparently the suits at Munich and Stuttgart are aiming for the same platform sharing efficiency that VW has with its Golf/ Leon/ A3 and every other platforms they share.
Part of this involves them sharing the same engine blocks with different heads, turbos, gearboxes and suspension bits. Now that involves them having to decide whether to go V6 or inline 6 (and no prizes which one I'll be rooting for if any of this turns out to be true...).
That's the first hurdle. The second one (and it's a big one) is the Quandt family controlling BMW (who cannot stop this from going ahead on their own) will not bite. They're highly secretive, and they've made it known on more than one occasion that they want BMW to remain independent.
Another snag is even if these two do team up as some sort of not-merged-but-working-as-one deal, they're still nowhere near what the pundits consider the absolute minimum of 5 million units per year figure. Which means if they do team up, they'll need to team up yet again with another manufacturer who has a larger footprint in the volume markets.
Someone like PSA for instance... BMW and PSA already have engine-deals, which makes PSA a candidate. Problem here is that the current head of PSA was once at Airbus, who Daimler once not too long ago was very much interested in buying a piece of. PSA's current head didn't make that possible.
The magazine made mention of Honda, which doesn't sound too bad - if all this teaming up is inevitable of course -, as they are engineering driven (very good thing) and are globally represented (making up the volumes).
Now this all sounds very peachy, but my problem is this:
VW may be masters at the same-buns-and-meat-different-burgers manufacturing, but to me at least there's very little that distinguishes a Golf from a Leon from even an A3, bar some bells and whistles.
The other big thing is that it's only a matter of time before one company gobbles up the other. Let's face it, Daimler has the bigger wallet at the end of the day...
Some more puzzles: The 1 Series wouldn't fit in the grand plan so chances are that it'll go FWD in the generation after the one that's still to be released (gasp).
But, as they say, que sera sera.
EDIT: Oh yes, I forgot to mention that (again, apparently) the 7 and S as well as RR and Maybach will not be sharing anything, apart from between the 7/ RR and the S/ Maybach.
kooper is offline   Reply With Quote
      05-26-2009, 10:52 PM   #18
Zell
Impatiently saving for an E92
Zell's Avatar
Drives: Nothing
What, you didn't know that the more gears your car has, the cooler you are?
335i fund-o-meter:
0%|********-----------|100% 41.17%
1: 4/10/09 2: 5/12/09 3: 8/8/09 4: 12/25/09 5: 2/9/10 6: 4/10/10 7: 6/25/10 7: 8/20/10
Zell is offline   Reply With Quote
      05-26-2009, 11:36 PM   #19
zamm3k
Bla!
zamm3k's Avatar
Drives: JB E90 M3
Don't mean to be an ass, but, ALL that sounds very VERY unlikely. BMW and FWD? I hardly believe so. And them pairing up with Mercedes Benz to share chassis and engines, highly doubt that too. We can already see BMW progressing and scheming their future engines and chassis with no intentions of pairing up with Mercedes Benz. We already have prototypes of the future M5 and M6 engines ( the new X5m and X6m engines). These engines are early stage projects for futures engines that will most likely become single turbo engines with valvetronic technology. Even though companies are leaning towards reducing production costs, they won't change their ways of being or the essence that makes them what they are. Hence, BMW will never become a non-luxury automobile manufacturer. FWD and BMW simply haven't mixed since the beginning of time and I doubt thats the way they will head. But again, this is just what I believe.
:.-. KW .-. RPi .-. MACHT SCHNELL .-.BBS .-. VREDESTEIN .-.:
zamm3k is offline   United_States
      05-27-2009, 12:12 AM   #20
Bimmer Nerd
I | L Photography
Bimmer Nerd's Avatar
Drives: no car yet
and what you believe i think is totally right, BMW teaming up with mercedes ? possible but to some level, i do think that they might do something together on the environmental issues and reducing emissions since 2 heads are better than one but sharing chassis and engine components and all that is little bit to much because that is really what distinguishes this cars , engines, chassis and design.
Bimmer Nerd is offline   Georgia
      05-27-2009, 12:38 AM   #21
ianbiz
4th E90
ianbiz's Avatar
Drives: Black E90 and a SGM E90
Send a message via AIM to ianbiz
now we need a bi-scroll turbos and valvetronic.
is the scroll turbo similar to what porsche uses in the 997 turbo?
Ian
ianbiz is offline   United_States
      05-27-2009, 04:28 AM   #22
Bluesummer
Bluesummer's Avatar
Drives: ///M-less atm :'(
Send a message via MSN to Bluesummer
Sounds good!
TWIN-Turbo
エアーマンが倒せない!!
11' JzB E90 ///M3 |Eisenmann Race|H&R|NEEZ|
08' SG E92 ///M3 | Lemon'ed 7/10' @ 22xxx miles |
07' AW E92 335 | Lemon'ed 10/08' @ 26xxx miles |
Bluesummer is online now   Taiwan
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1Addicts.com, BimmerPost.com, E90Post.com, M3Post.com, ZPost.com, 5Post.com, 7Post.com, XBimmers.com logo and trademark are properties of BimmerPost
