2010 2011 BMW 5 Series Forum F10 BMW 5-Series Gran Turismo GT (F07) Forums General 5-Series GT (Gran Turismo) (F07) Forum BMW xDrive on All Engine Variants of the BMW 5 Series Gran Turismo and the BMW 740d
      04-15-2010, 06:25 AM   #1
Mark's Avatar
Drives: 1M
PRESS RELEASE + Expand
BMW, the world’s leading manufacturer of premium cars, is consistently enlarging its wide range of all-wheel-drive models. Starting in June and, respectively, September 2010, all engine variants of the BMW 5 Series Gran Turismo will also be available with intelligent BMW xDrive all-wheel-drive technology. And also starting in September, the BMW 740d xDrive will become the top diesel in the luxury sedan class to feature this innovative drive system.
The BMW 5 Series Gran Turismo combines elegance, spaciousness, comfort and variability in a truly unique car concept – and now this combination offering supreme motoring comfort is becoming even more thrilling and overwhelming. First, starting in June 2010, customers will have the choice of two versions of the BMW 5 Series Gran Turismo featuring BMW xDrive all-wheel-drive technology. In both the BMW 530d xDrive Gran Turismo and the BMW 550i xDrive Gran Turismo, permanent, electronically masterminded all-wheel drive ensures the appropriate distribution of drive power front-to-rear in every situation. Then, following in September 2010, the BMW 535d xDrive Gran Turismo and the BMW 535i xDrive Gran Turismo will round off the engine range, helping to give the BMW 5 Series Gran Turismo even greater and more versatile character within the premium segment through BMW xDrive technology.
Making its debut in April at Auto China Beijing 2010, the BMW 550i xDrive Gran Turismo is powered by a supreme V8 boasting BMW TwinPower Turbo Technology and High Precision Injection. Displacing 4.4 litres, this outstanding eight-cylinder delivers maximum output of 300 kW/407 hp all the way from 5,500 – 6,400 rpm as well as peak torque of 600 Newton-metres/442 lb-ft maintained consistently between 1,750 and 4,500 rpm.
This superior torque coming in at an early point and maintained throughout a broad speed range is now converted into supreme driving dynamics even more precisely and in even more superior style through BMW xDrive technology, accelerating the car to 100 km/h in 5.4 seconds. Top speed is cut off by the engine’s electronic control unit at 250 km/h or 155 mph. Average fuel consumption in the EU test cycle, finally, is 11.8 litres/100 km, equal to 23.9 mpg imp, with CO2 emissions amounting to 275 grams per kilometre.
The BMW 550i xDrive Gran Turismo is the first model to combine such intelligent all-wheel drive with the supreme driving dynamics, motoring comfort and efficiency of an eight-speed automatic transmission.
The straight-six diesel engine in the BMW 530d xDrive Gran Turismo likewise represents the latest state-of-the-art in BMW engine development. Displacing 3.0 litres, the engine comes with an all-aluminium crankcase, its turbocharger system featuring variable intake geometry ensuring a superior surge of power and performance tailored harmoniously to all kinds of driving conditions.
Fuel is delivered by the latest generation of piezo-injectors operating at a maximum pressure of 1,800 bar. This gives the engine maximum peak output of 180 kW/245 hp at 4,000 rpm, with torque reaching its peak of 540 Newton-metres/398 lb-ft at just 1,750 rpm.
Benefiting from this kind of power, the BMW 530d xDrive Gran Turismo accelerates from a standstill to 100 km/h in 6.9 seconds and reaches a top speed of 235 km/h or 146 mph.
At the same time the car combines this sporting performance with average fuel consumption of 6.9 litres/100 kilometres, equal to 40.9 mpg imp, in the EU test cycle. The CO2 rating, finally, is 183 grams per kilometre.
The BMW 535d xDrive Gran Turismo features a second even more powerful representative of the new generation of straight-six BMW diesels. Boasting BMW TwinPower Turbo Technology and common rail direct fuel injection, the all-aluminium power unit in this equally outstanding model develops maximum output of 220 kW/300 hp at 4,400 rpm as well as peak torque of 600 Newton-metres/442 lb-ft maintained consistently between 1,500 and 2,500 rpm.
The straight-six gasoline power unit in the BMW 535i xDrive Gran Turismo combines turbocharging, High Precision Injection and variable VALVETRONIC valve management with one another. This unique combination gives the BMW TwinPower Turbo an extremely spontaneous and direct response to the gas pedal. This outstanding response is then further optimised by VALVETRONIC valve management as well as the turbocharger system applying the twin-scroll principle both in the exhaust manifold and the turbocharger to separate the ducts and flow channels of three cylinders at a time.
With its high-tech injection nozzles, High Precision Injection doses fuel with maximum precision, delivering the fuel required into the combustion chambers at a pressure of up to 200 bar.
Displacing 3.0 litres, this outstanding six-cylinder delivers maximum output of 225 kW/306 hp at 5,800 rpm. Peak torque of 400 Newton metres/295 lb-ft, in turn, comes between 1,200 and 5,000 rpm.
With the top-of-the-range BMW 750i xDrive and BMW 750Li xDrive already introducing BMW’s intelligent all-wheel-drive system in the 2010 model year in the 7 Series, the BMW 740d xDrive is making its appearance in September.
With its all-aluminium power unit, the BMW 740d xDrive boasts BMW TwinPower Turbo Technology as well as common-rail direct fuel injection with its piezo-injectors operating at a pressure of up to 2,000 bar. Maximum output, as a result, is 225 kW/306 hp, with peak torque of 600 Newton-metres/442 lb-ft maintained consistently between 1,500 and 2,500 rpm.
Permanent, electronically controlled all-wheel drive ensures exactly the right distribution of engine power under all driving conditions. Precise and quick drive power control, finally, gives this supreme luxury sedan absolutely safe and incomparable driving behaviour at all times.
Originally BMW’s intelligent xDrive all-wheel-drive technology was conceived for the BMW X models, then being introduced step-by-step in the BMW 5 Series, the BMW 3 Series, and the BMW 7 Series. The big forte of this superior technology is its uniquely precise control and engine management helping to optimise traction on rough surfaces and at the same time deliver supreme driving dynamics to the road.
The system stands out as a particularly intelligent all-wheel-drive technology by distributing drive power through a power divider with an electronically controlled multiple-plate clutch in exactly the right way and properly dosed to the correct axle and wheels with optimum road contact at any given point in time.
Featuring this superior system, BMW xDrive enhances driving stability also in dynamic bends by recognising even the slightest tendency to over- and understeer at an early point and taking appropriate counter-action right away.
Photos and Wallpapers Click on the thumbnails below to enlarge
The new beast. BMW M5.
Mark is offline   United_States
      04-15-2010, 09:28 AM   #2
npd2983
Drives: '10 128i MT; '09 335d
Way to go BMW! More weight and worse MPG for 3 more models...
npd2983 is offline   United_States
      04-15-2010, 10:06 AM   #3
BMW-NC
Selling drugs to BMW addicts
BMW-NC's Avatar
Drives: 135i e82 6MT N55
I love it, more models - more to sell ;-)
Unfortunately the 740d stays european, eh?
Quality US Spec Used Cars for Military Members stationed in Europe. Specialized in BMWs and MINIs up to 10k miles.
BMW-NC is offline   Germany
      04-15-2010, 10:12 AM   #4
Oulixes
Oulixes's Avatar
Drives: 330xi, 335i
The lovers of German-made AWD shall be happy about this development. They can now compare the X-drive with Quattro and with 4-matic.
Oulixes is offline   Reply With Quote
      04-15-2010, 10:22 AM   #5
frantzy
Drives: 2010 535i Gran Turismo
I take it you don't get much snow in Alabama, otherwise maybe you'd want the option.
Speaking of MPG, I see the 535i GT is on the BMWUSA site now, but MPG is still TBD. Is there a delay in fuel economy certification?
frantzy is offline   Reply With Quote
      04-15-2010, 10:52 AM   #6
jaybird124
jaybird124's Avatar
Drives: '09 335d Sport
Means it probably sucks, and they're stalling as long as possible. The car has to be certified before it can go on sale. That's already been done.
jaybird124 is offline   Reply With Quote
      04-15-2010, 11:09 AM   #7
e46e92love
e46e92love's Avatar
Drives: e92 ///M3; X3 (wife's)
Send a message via AIM to e46e92love
Now please BMW, offer the 5GT with the 535d engine and we will be golden. A big car like this will be perfect with that torquey engine and much lower fuel consumption then the twin-turbo V8 they have in her now.
Cheers,
e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan.
e46e92love is offline   United_States
      04-15-2010, 11:20 AM   #8
vladberca
vladberca's Avatar
Drives: '09 jetta tsi 6mt
Is the name 535d GT for US market and 540d GT for European market?
It s the same engine from 740d...
vladberca is offline   Romania
      04-15-2010, 02:27 PM   #9
bdardashti
bdardashti's Avatar
Drives: '11 E90 328i xDrive
Well there's no such thing as a 535d GT for US market; don't know if any of the 5GT variants you mentioned exists for the European market either. However, the x30d, x35d, and x40d (x being 5, 7, w/e) are all different, not just name changes.
The 30d is 245hp, the 35d is 286hp (down-tuned to 268 in US if I'm not mistaken), and 40d is 306hp. The torque numbers vary as well, with similar variances. It's very likely (in fact, almost certain) that the underlying engine in the three is the same, but tuned (both mechanically and by software) differently.
The only engine certified for US/Canada is 35d (down-tuned).
bdardashti is offline   Canada
      04-15-2010, 05:57 PM   #10
frantzy
I believe the GT variants are:
550i GT (V8),
535i GT (inline 6 cyl turbo)
530d GT (not in the US)
plus then the forthcoming xDrive versions
Forum Jump
