2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Jeremy Clarkson suggests you buy F10 BMW 535i
      05-17-2010, 07:48 AM   #1
Jason
Jason's Avatar
Drives: E90 M3
Thumbs up Jeremy Clarkson suggests you buy F10 BMW 535i
Jeremy Clarkson has developed (rightfully so) a reputation as a bit of a sourpuss when it comes to BMWs. That's why BMW owners take notice when he reviews a BMW favorably. And he does so very favorably in his review of the F10 BMW 535i, which he calls the "absolute best of absolutely everything we know." Pretty darn good endorsement if you ask us.
BMW 535i SE
Most right-thinking people know that when all the oil has finally been spilt into the Gulf of Mexico, the world will turn to hydrogen for salvation. But right now hydrogen is complicated to use, difficult to distribute and expensive to make.
Much work needs to be done before it’s viable, but the green-eyed monster won’t wait. The green-eyed monster is impatient. It wants results now. So all car makers — even Ferrari — are being forced to adopt the short-term solution of hybrid technology. That means using a conventional engine to charge the batteries, which power a second motor that runs on electricity.
I know, I know, it’s stupid and wasteful, but I don’t make the rules. That’s the job of the green-eyed monster.
We’ve seen this before, of course, and not that long ago. Back in the Eighties, when Mrs Thatcher invented climate change as a weapon to fight the coal industry, the monster clamoured for catalytic converters to become law.
Ford and other car makers argued that given time they could make lean-burn technology work — engines that run almost entirely on air. But the monster wouldn’t wait. “No,” it shrieked. “You must stop carbon monoxide coming out of the exhaust pipe NOW!!!! It is making people in Birmingham stupid.”
So lean-burn research was abandoned and, with sagging shoulders, the car industry raped the world of all its platinum and shoved it up the exhaust pipes of all its cars.
Of course, it worked. Except that what a catalytic converter does is turn carbon monoxide into carbon dioxide. And the green-eyed monster has decided that this is the new peril. “You must stop with the carbon dioxide,” it shrieks. “It is killing all the polar bears, so you must make hybrids.”
Frankly, I’m surprised the car industry doesn’t just tell the monster to get lost but, deep down, I am beginning to suspect the engineers are secretly quite pleased that they’ve been given something to do.
Think about it. Ever since the Austin Seven laid out the basic template for what would become the modern car, everyone has known that there should be a wheel at each corner and an engine that mixes fuel and air, blows it up and ejects the waste gases. There’s only so much you can do, given those essential parameters.
It’s not like the delivery of music, where you have to replace your entire collection every 15 minutes. There’s been no cassette or eight-track or Mpeg moment in the car industry. Jenkins from Drivetrain Projects may complain about that as much as he likes — “Oh but sir ... can’t I use crystals and lemons and have nine wheels all on one side?” But he’ll always get the same reply. “Don’t be stupid, boy. Wheel at each corner; engine that sucks, squeezes, bangs and blows. Same as usual.”
Hybrid power is horrific, unimaginative, short-term, blinkered nonsense but it will unlock the creative juices in Jenkins and, to be selfish for a moment, give motoring journalists something interesting to write about for a change.
Let us take the BMW 535i as a classic example of the problem. The seats are pretty much perfect: they’re not too hard and not too soft and the side bolsters don’t dig into your kidneys but do provide just the right amount of support in the corners.
Then you have the engine. It may say 535 on the back but — probably because BMW’s marketing people wanted to experiment — it doesn’t actually have a 3.5-litre engine as you’d expect. It’s a turbocharged 3-litre six and it’s wonderful. Creamy smooth, powerful and as economical as can be: just what you’d expect, really, from a company that’s been doing the same thing over and over since Douglas Bader forced it to rethink its aircraft business.
Perhaps the most impressive part of this new car is the ride-and-handling compromise. It’s very difficult to make a big, heavy car such as this handle well and ride over bumps comfortably. In the same way as it’s very difficult to do a Fosbury flop. But if you practise enough ...
And, boy, have those Bee Em boffins been practising. Frankly, it’s hard to see how on earth it could be better, short of replacing the wheels with a Maglev system. I don’t know what that is either. It just sounds good.
Styling? Well, recently, under the stewardship of a chap called Chris Bangle, BMW did try to be different and do something new. Nobody liked its effort all that much so the new car is far more conventional. That said, the view down the bonnet is delightful. Most bonnets rise in the middle to hint at great power beneath — for an example of this, see the E-type Jag or David Beckham in those underpants commercials.
But the bonnet on the new 5-series dips. That should send out the message that it has nothing in its trousers. And yet it doesn’t. It looks elegant. Certainly, it is more elegant than Merc’s attempts to be different with the E-class. Those sculpted rear wheelarches just look silly.
See the problem here? Cars are now so bloody good and so well thought out that all there is to write about is a dipping bonnet or a crease in the rear wing.
And when it comes to finding fault? My God, you have to be picky. In the 5-series, I’m reduced to complaining that if I set the steering wheel where I like it, fully back and as high as possible, I can’t see the “range” read-out on the dash. Oh, and the electronic gearlever is a bit of a fiddle. Until you get used to it, which takes about three seconds.
In terms of electronics, there are some new things on the 5-series that I ought to mention. It has something called “efficient dynamics”, which is another way of saying, “We were bored.”
What it does varies from model to model, but on mine energy was taken from the brakes and put into the battery. Wow. That must increase the mpg figure by at least 0.00001. In addition, I had active steering (a £1,300 option) and DSC+, which includes ASC, CBC, DBC, DTC, EBD and a hairdryer on the brakes.
It also has a sat nav screen that shows a satellite view of the terrain through which you are driving. Some of my colleagues in the business have shown how desperate they are for something to say by claiming: “It’s a bit far away.” Far away from what, I wonder. The moon?
I like most of the gadgets. There are optional cameras that show you views from all around the car when you’re parking. Why? No idea. And there’s an equally optional head-up display, which, so far as I can see, is useful only in court. “Well you see, m’lud. I didn’t see the old lady because she was hidden behind my speedometer.”
This, I suppose, is the price we pay for messing around with a fundamental principle that’s been shown to work. If you start to get adventurous, you’re going to end up with a problem. That’s fine for motoring journalists — I certainly enjoyed tearing the dreadful BMW X1 apart recently — but for everyone else? No.
That’s going to be the future with hybrids. Lots of new stuff. Lots of new issues. And for what? So that the green-eyed monster can come along in five minutes and say, “No. You can’t have hybrids. They cause acid rain.” Which they do, incidentally.
So, if you have the wherewithal, I suggest you buy a 5-series. It’s the absolute best of absolutely everything we know. Unless you want a Jag, of course, because that is as well.
THE CLARKSOMETER
Clarkson’s verdict: basically, it’s a very, very good Austin Seven
BMW 535i SE
Engine 2979cc, six cylinders
Power 306bhp @ 5800rpm
Torque 295 lb ft @ 1200rpm
Transmission Eight-speed auto
Acceleration 0-62mph: 6.1sec
Top speed 155mph
Fuel 33.6mpg
CO2 195g/km Tax band J (£425 for first year)
Price £38,795
Release date On sale now
http://www.timesonline.co.uk/tol/dri...cle7125818.ece
Check on the Latest BMW News
Jason is offline   United_States
      05-17-2010, 02:22 PM   #2
sfbayguy
sfbayguy's Avatar
Drives: Coming in June: F10 535i
Sweet review from "sourpuss Clarkson" as you so aptly described him regarding his reputation for his reviews on BMW. Very nice that he loved it, must be a superb car for him to gush over it!
sfbayguy is offline   United_States
      05-17-2010, 03:44 PM   #3
Mpistolis21
Drives: series 335i E90
BMW FTW!
Mpistolis21 is offline   Reply With Quote
      05-17-2010, 03:53 PM   #4
MDS
Drives: None
the term "sourpuss" fits him like a glove....
I love the guy, but I do notice a slight difficulty in saying anything positive about BMW´s... I see things change.... " a little" sometimes...
MDS is offline   Reply With Quote
      05-17-2010, 04:34 PM   #5
Vintage
Vintage's Avatar
Drives: 2010 Z4 35i and 2010 X5 35d
awesome review - I cannot wait to test drive one of these at my dealer in a month when they are released stateside
Vintage is offline   United_States
      05-17-2010, 04:49 PM   #6
delvek
delvek's Avatar
Drives: F10 550i Msport
good read ... thanks for posting
2011 550i M-sport:Mods: Hartge ECU (490hp/497ps@5500rp 531ft-lb/720Nm@2000rpm), ACSchnitzer suspension, ACSchnitzer sport exhaust, Msport Spoiler, Shadowline Grille, Color matched front reflectors, dvdinmotion. MyBavarianBeast: http://f10.5post.com/forums/showthread.php?t=530637
Future: 2014 F82 M4
delvek is offline   Germany
      05-17-2010, 04:49 PM   #7
tonmonde
Drives: e82, e93
entertaining read, made me chuckle and wonder about the upcoming season.
e60, e90, e92, e82 : retired
e93 n55: active F30 335 ED 09/10/12
tonmonde is offline   Reply With Quote
      05-17-2010, 05:35 PM   #8
MI6
The World is Not Enough
MI6's Avatar
Drives: Aston DBS-R
Originally Posted by Stankia View Post
Jason, I don't know where you got the idea that Jeremy dislikes BMWs. He always liked them, just because he hates the iDrive doesn't mean he hates BMWs.
Yes, if I remember correctly he owned/owns an E60 M5 and loves it.....
Nonetheless he once stated "M3 owners have no friends." Basing it on their arrogance and such.
And of course, he's right on that......
MI6 is offline   United_States
      05-17-2010, 05:38 PM   #9
Oulixes
Oulixes's Avatar
Drives: 330xi, 335i
Have you noticed how positive has our world become? It is oh so positive that people who still recognize a car battery when they see it they dislike it, since one of the terminals is negative. Car "evaluators" are so positive that the fluff they write is next to useless. More power to Jeremy Clarkson and anyone who dares to sourpuss when it is called for. After all, when he drove the 535i he saw the light, and the high pressure pump held its own.
Oulixes is offline   Reply With Quote
      05-17-2010, 07:04 PM   #10
positiveions
positiveions's Avatar
Drives: 09 MKV JETTA 2.5 & E90 M3 :)
Send a message via MSN to positiveions Send a message via Yahoo to positiveions
I agree with him, hybrid technology crap is a temporary "band aid" to the problem. but great review on behalf of a chap. I need to test drive this one.
positiveions is online now   Lebanon
      05-18-2010, 12:18 AM   #11
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [5.00]
Send a message via AIM to MrHarris
What ever happened to you getting your M3?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
MrHarris is offline   United_States
      05-18-2010, 12:20 AM   #12
2045
2045's Avatar
Drives: always changing
hmmm... just think that the M5 will be even better. just don't put too many stupid //M & hp settings in there.
2045 is offline   Reply With Quote
      05-18-2010, 05:20 AM   #13
bm323
Drives: F10 535i
Originally Posted by TheFlashback View Post
I drove one today - very upsetting experience - it is not even close to my 2003 540i I still drive. Tall, soft and bulky. The soul is gone. It was not a bimmer - was something else. Making cars with no true heart is the hyundai's piece of the cake I always thought until today.
Which model did you drive and what option if any did it have eg 2VA, 223, sport suspension and what mode eg comfort, sport?
bm323 is offline   Reply With Quote
      05-18-2010, 06:14 AM   #14
ebeem
ebeem's Avatar
Drives: E93 335i M - Paket
I have to agree with him on that...
I had the F10 for a few days while my car was at the shop and the ride was smooth and comfortable yet firm enough in corners to handle like a much lighter car.
Very comfortable and agile
ebeem is offline   Germany
      05-18-2010, 07:32 AM   #15
UsualSuspect
Lieutenant General ***
UsualSuspect's Avatar
Drives: this way and that way...
Thanks for sharing! Clarkson is great.
UsualSuspect is offline   United_States
      05-18-2010, 07:45 AM   #16
kinan_sleiman2006
kinan_sleiman2006's Avatar
Drives: BMW X3
He is know an f10 lover!!!!!!!!!!what a surprise?
kinan_sleiman2006 is offline   Syria
      05-18-2010, 07:46 AM   #17
kinan_sleiman2006
Drives: BMW X3
So when m5 comes the meter will go to 5 stars!!!!!!
      05-18-2010, 09:46 AM   #18
J-Raid
J-Raid's Avatar
Drives: E46
Sometimes I wonder if people think they are Schumacher themselves...
Don't get me wrong, the director of tests of the car mag I work with told me too that the car had lost a bit of it's sportiness, but sincerely 99% of the users will be happy with it, and will still beat a Merc or an Audi any day.
But seems there's always people who love complaining. this is like people praising the good old days, but the thing is that actually new things are better; just non-sense nostalgia implicit in (certain) humans.
It's not like we are meant to drive a racing car on the roads...
J-Raid is offline   Reply With Quote
      05-18-2010, 10:05 AM   #19
Robin_NL
S0THPAW
Robin_NL's Avatar
Drives: AW 1M + N55 mids
Clarkson is a clown and a very humouristic TV presenter, that's all.
The last couple of years he hated almost anything with the BMW badge and/or its drivers or at least he acted like that....
Anyway nice article, but his opinion didn't make me choose a F10 or my 8th BMW fwiw.
Better watch Jason Plato, Chris Harris, Richard Meaden, Tiff Needell or Vicky BH judging cars.
Cheers
Robin
Robin_NL is offline   Netherlands
      05-18-2010, 11:46 AM   #20
HighlandPete
Drives: BMW F11 535i Touring
Strange... I'm from an E39 540i and I really thought the F10 was getting us back to the E39 experience, soul and all. Where the E60 should have taken us, IMO. Both in the whole interior/ambience and the chassis capabilities. OK, so we may have to spec them to suit our needs, then the E39 540i was no different.
An F10 535i is a superb blend of modern BMW, from where I sit. The 530d is the sensible choice, in the UK.
HighlandPete
HighlandPete is offline   Reply With Quote
      05-18-2010, 02:04 PM   #21
positiveions
i just finished my nursing school, and rethinking the future. I don't think the future wife will like a mad man behind an E9X M3. I have to "BEHAVE"
      05-18-2010, 02:37 PM   #22
delvek
delvek's Avatar
Go for the M3 ... and if the wife says anything, do what I do ... just yell in a primal scream ... I WANNA ROCK!
Future: 2014 F82 M4
Forum Jump
