2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 550i Valentine One Install ?
      10-10-2010, 02:32 AM   #23
taylorpetie
taylorpetie's Avatar
Drives: 550i X-Drive, Dark Graphite II
Originally Posted by E60orBust View Post
Anyone experience a lot of false positives with the valentine one? If my V1 is at i-Drive screen or higher (holding it in my hand), I get a constant false positive coming from behind. I've had no choice but to unplug it.
Something in my 550i must be broadcasting a lot of interference.
I have mine mounted just below the rear view mirror and V1 works fine (there's the usual X-band alarms, but not constant as you would describe it)
If you have active cruise control, the laser may trigger the V1, but you mentioned that it is coming from behind, so not sure what it could be...
      10-10-2010, 08:40 AM   #24
mautzi
Drives: 2011 550i xDrive
Do you have the driver assistance package?
I just read on the radardetector.net forums V1 section that someone is having a similar issue. I will find out shortly and will be extremely disappointed if I can not use the V1 in my new 550i xdrive with the driver assistance package (which I added last minute as an option and would have not ordered if it indeed does interfere and give false positives to the V1)
      10-10-2010, 09:34 PM   #25
E60orBust
Drives: "The Brothers //M-Sport" E90/2
I do and it does. Buck me...
This one? http://www.radardetector.net/forums/...ector-era.html
Down for Maintenance
      10-11-2010, 08:42 AM   #26
mautzi
well buck me too then! Will this render my V1 useless? I guess I'll find out soon.
      10-11-2010, 01:05 PM   #27
E60orBust
It did for me. Only position I've found where it is not constantly hitting off false alerts is in the seat. Not exactly good range.
I tried mounting it to the bottom of the windshield on top the dash but that also got the false alerts. There might be a 'sweat' spot somewhere in the car but I've yet to find one.
      10-18-2010, 11:47 PM   #28
Grizzles
Grizzles's Avatar
Drives: 2011 550XI MSPORT
Originally Posted by taylorpetie View Post
Hardwiring a radar detector should be the same, whether it's V1 or Escort. I installed an 'add-a-circuit' mini fuse (purchased mine at parts-express.com) to the fuse box (located in the glove compartment). Fuse #48 worked for me. You'll also need a 'direct wire' from Escort (their website escortradar.com has it). For general overview of direct wiring, Youtube has lots of 'how to' for direct wiring the Escort. Hope this helps.
i ran the wire to the fuse box, does anyone have a picture or a detailed connection description for me? its hard to figure out without blowing several fuses.
      10-19-2010, 12:28 AM   #29
taylorpetie
My car is still in the shop, so can't help you identify... But, in your 550 trunk, there is another fuse box to the right side... open it, and there is a white card (that slides out) which shows the diagram for the front and back fuse box. This will help you identify which fuse is #48.
      10-19-2010, 03:10 PM   #30
F10550xi
Drives: 550xi ZMP
Here is a pic of a v1 install in my 330i. I had the installer drill a very small hole in the left side of the rear view mirror housing and run the wire straight across to the v1. This involved removing the plug on one end of the wire to pass it through the hole and reattaching it before plugging into the v1 hardwire kit.
      10-23-2010, 09:06 AM   #31
72M4
Drives: 2015 Alpine White M4
Which Fuse is #48
I took off the fuse block cover in the glove box and noted that there are about 100 plus fuses on the fuse block.
1. How do you tell which is #48?
2. How do you get to it since it is so far back from the glove box access?
Thanks for any input/help
2011 F10 535I
      10-23-2010, 12:20 PM   #32
Grizzles
Grizzles's Avatar
2011 F10 535I
diagram is in the trunk fuse box.
fuse 48 worked for me.
      10-23-2010, 01:48 PM   #33
72M4
Thanks for the reply, I found the fuse list and fuse 48. Now all I have to do is figure a way of getting my extra large meat hooks to it....
      10-23-2010, 04:34 PM   #34
Bmrmeup
Drives: 2011 535xi, Graphite Grey
2011 535xi  [0.00]
Driver to driver it seems to me that you have to pick & choose where & when you put the pedal to the metal. Radar detectors..........I don't trust them. Maybe they are more reliable now....I don't know.
      10-28-2010, 10:12 AM   #35
x5 '08
Drives: 2008 535xi
Which Escort do you have? I had all sorts of problems with my 9500ci in my 2008 535xi. Pulled it out last week when I returned the car and am waiting for my f10 to come in. Hope to make sure my installed does it right this time.
      10-28-2010, 10:17 AM   #36
E60orBust
Off-topic; what year is that 330i? That mirror looks like it is from an //M Car.
      04-29-2011, 09:21 AM   #37
fx104elec
Drives: Smart
Valentine 1 to Nokia mobile via bluetooth
Hi everybody
I see alot of you searching for a place to install the remote display, So i decide to build an electronic project to send the data of valentine 1 to Nokia mobile via bluetooth .
In this case you can put valentine 1 at any place in the car and connect my device with 12v source to it and you can see all data of V1 in your mobile with bluetooth.
Do you find this interesting and worth to build ????
      12-13-2011, 03:46 PM   #38
Karrera4
Drives: Lots of them
I installed my V1 last week, and cannot remember the fuse I used off the top of my head. I just mounted the control module right behind the door in the glove box fuse panel. I ended up simply pulling the fuse, then sliding it back in with the wire at the same time. I might try one of the mini add-a-fuse for a better connection; however, I did notice something weird yesterday. When I was at a stop light, the auto start/stop cut the engine and when it started bak up, the V1 beeped as if it were starting up too. At the next stop, the engine cut again and I looked up at the V1 to see if it was still on and it was.....however, when the engine fired back up, the V1 still went thru is normal start up function again! Then, on the way to work today, it didnt do it! What the heck is going on? I will check out fuse 48 I think.
      12-14-2011, 02:56 PM   #39
1HOT BMR
1HOT BMR's Avatar
Drives: Car-less and shopping +'12 35d
This is what I did:
http://www.bimmerfest.com/forums/sho...944&highlight=
      12-14-2011, 03:25 PM   #40
vdubturbo
Drives: 2011 535i
Not sure if anyone has seen this, but I always thought this was the ultimate, especially here in VA where radar detectors are illegal.
It's been a while since I've read through the website, so I'm not sure what cars it is available for...
Their Website
Tags
550, install, valentine one, valentine v1, wire
