FORUMS
- 5
DIY Oil Change F10 5-series (N55 motor)
| 07-20-2010, 08:39 PM | #1 |
![]() Drives: 2011 E92 335 M-Sport Join Date: Feb 2010
1100 miles, time for a oil change.
Parts:
Make sure oil is at operating temp before doing this. 1. On a level surface, engage parking brake and chock rear wheels 2. Lift front of car, I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F10. 3. Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup. 4. Remove small bolt that holds trap door in place, remove trap door. 5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining) 6. Lower car back down to ensure even oil draining. This will take a while, I made a sandwich during the time. 7. Remove oil filter, I did it by hand but if your kung fu grip isn't strong enough buy the filter wrench. With needle nose pliers remove green gasket and large black gasket on oil filter housing. Pull oil filter out. Install new filter, the writing was facing out or down. Put new gaskets on the filter housing. I soaked the new filter in a little oil and rubbed some oil on the new gaskets. I sucked out all the residual oil in the filter seat with a turkey baster. Screw filter back into the base. Match the green alignment marks (thanks for that Dingolfing!) 8. Jack Car back up, place jacks stands in position again, make sure the rear chocks haven't moved around. Put copper crush washer onto new bolt, put a little oil on the threads of the bolt, and tighten bolt back by hand at first then use the 17mm socket and torque the bolt back to 25-30lbs/ft, don't over tighten. 9. Put trap door back in place (or leave open to check for leaks later, I skipped this as I am confident in my DIY skills, if you're not, triple check everything). 10. Place car back on level ground, and fill with 7 qts of oil. I list the 3 grades and brands above because they are the most common in N. America and can be found easily, don't send me PM's about how great Amsoil or Redline is, most people don't want to deal with the hassle of getting that stuff. 11. Drive car around until oil level appears on IDrive (this took forever, and pissed me off. My kingdom for a dipstick!!!) 12. Bask in your glory by consuming beer or adult beverage of choice. Castrol Syntec European Formula 0W30 chock rear wheels I used two floor jacks with plastic pads to keep from damaging plastic jack points on the F103. Use jacks stands in case floor jacks malfunction (this is VERY IMPORTANT) Never get under a car without proper safety backup. Remove small bolt that holds trap door in place, remove trap door. 5. Using 17mm socket and wrench loosen drain plug. (Bolt faces down, so no mess with angle draining) I sucked out all the residual oil in the filter seat with a turkey baster. Match the green alignment marks (thanks for that Dingolfing!) Early and often for the first year. I own this car, it's not rented.: Planned schedule: Total Vehicle Mileage 1. 1,200 Miles (Owner) 2. 7,500 miles (Owner) 3. 15,000 miles (Dealer) 4. 22,500 miles (Owner) 5. 30,000 miles (Dealer) Last edited by gatoman39; 02-03-2011 at 07:23 PM. |
| 07-20-2010, 10:36 PM | #2 |
Our first DIY! And a great one at that. Thank you for sharing.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
| 07-22-2010, 12:02 PM | #6 | |
Old School BMW Maintenance Schedule: Break-in Service for New Cars Traditionally, BMW performed a break-in service at 1,200 miles on new cars, which included changing the engine oil and filter, manual gearbox oil or automatic transmission fluid, and differential oil. With the advent of Free Scheduled Maintenance, BMW stopped performing break-in services except on M cars. I have seen that the engine and driveline oils in new modern BMWs are literally full of metal at 1,200 miles – as has always been the case with any new car. For this reason, I recommend a 1,200-mile break-in service. |
| 07-22-2010, 01:58 PM | #7 | |
| 07-22-2010, 02:14 PM | #9 |
fuel additive manufactured from the netherlands. add it to the fuel tank after every oil change. it'll clean the injectors and the entire fuel system. adds an extra 15+ whp. use heineken lite if you're not tuned.
btw, great diy. car looks great!
| 07-22-2010, 02:35 PM | #10 |
| 07-22-2010, 02:47 PM | #12 |
A $65,000.00 car and a $35 jack. I see you've been shopping at Harbor Freight again............ I'm just bustin ya. Obviously I've been grabbin stuff from there too, or I won't know that "U.S. General" means Made in China. Good write up. Nice to know there are other BMW drivers out there that will get their hands dirty
| 07-22-2010, 03:07 PM | #13 |
![]() ![]() Drives: Montego E90 Join Date: Sep 2007
no way...
![]() Op, well done and nice and clear diy.
E90 325i Montego Blau - 2011-2012 (SOLD)
E90 320d TiAg - 2007-2011 (SOLD) E36 320i Avus Blau Msport - 2007 (SOLD) |
| 07-22-2010, 03:10 PM | #14 |
Bayerische Motoren Werke
Drives: 135i Coupe Join Date: Aug 2007
Great write-up, thanks for sharing! I've follow Mike Miller's guide for my E90 as well.
The last step is the best.
| 07-22-2010, 03:12 PM | #15 |
M POWER
Yes! All M's and Alpina vehicles come with a 1200 mile break in oil change. Which includes a transmission (only on manual vehicles) and diff oil change.
| 07-22-2010, 03:18 PM | #16 | |
Dumped factory fill at 1200 miles Mobil 1 5W-30 10 months and 5600 miles later... Last edited by gatoman39; 07-22-2010 at 03:26 PM. |
| 07-22-2010, 03:48 PM | #18 |
![]() ![]() Drives: 09 MKV JETTA 2.5 & E90 M3 :) Join Date: Sep 2007
Thanks for the write-up.
I appreciate those engineers that design small simplistic items such as the trap door on the shield; Rather than taking the whole shield out to gain access to the Oil pan nut.
| 07-22-2010, 04:36 PM | #19 | |
Driving: 11 F10 528i Memorium:07 E92 328i, 04 E46 325ci, 87 E30 325e, 76 E6 2002ti |
| 07-22-2010, 04:45 PM | #20 |
No, I surely did not see any metal, not that I was looking. I believe the metal and basic elements may be suspended in the oil, or in a form that is not clear to the naked eye. As you can see from the Used Oil Analysis, there are a lot of individual metals and elements they can test for. From what I could tell the oil looked clean and thin, not that you can tell much by simply looking at it.
| Bookmarks |
