2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Proper Tire Gauges
      08-03-2010, 01:06 PM   #1
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
Proper Tire Gauges
I recently bot a proper tire gauge and what I discovered was a bit surprising. I just bot a Michelin Digital Tire gauge and it exposed to me the amount of error in my regular analog version. These tests are unscientific, but it's what I have experienced:
Marin of error in PSI +/-:
Michelin Digital Tire Gauge: 0.1 -0.3
Slime Brass Tire Gauge with Bleeder Valve: 0.5 - 1.0
Cheapo Pen Version: 1.0-2.0
Moral of the Story: Considering how import tire pressure is in a car, it's worth spending $20 on a good one. (Especially for guys who are as neuotic as me)
      09-24-2010, 05:18 AM   #2
Jon D
Jon D's Avatar
Scotland
109
Drives: 2016 F12 640i
Gatoman,
OK, we're neurotic, but there's nothing the likes of us can do about it; if we weren't worrying about tyre pressures, there'd be something else to fret about.
Case in point being the price difference between the UK and the US - are you saying that you bought that Michelin gauge for $20? The cheapest I can find it here is 25 - that's $39, and I thought I was going to have a good day !!!
As a matter of interest, what did you use to determine the gauge accuracy?
      09-24-2010, 11:33 AM   #3
gatoman39
gatoman39's Avatar
Originally Posted by Jon D View Post
Gatoman,
You can buy that gauge off the internet. 40 bucks sounds expensive. I used the digital gauge as the reference as, repeated measurements yielded the same numbers. Then I measured the other gauges off of the reading I got with the digital gauge. This is all on the assumption that the digital gauge is the most accurate of the 3. Considering it's measuring in increments of 1/10 of a PSI when the others are using units of 1 and 2 respectively, I think it's safe to make this assumption.
      09-24-2010, 03:44 PM   #4
gatoman39
gatoman39's Avatar
Michelin uses truly disturbing puppets to talk about importance of tire pressure
[u2b]Om_dNhss3sw&feature[/u2b]
