2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: BMW Performance Black F10 Grille Install & Removing Bumper Silver Trim
      10-25-2011, 04:31 PM   #89
bighungry618
Serious About Shine
bighungry618's Avatar
Drives: 2011 535i M-Sport
Originally Posted by ianzammit View Post
can someone please tell me where I can get the black grills for the BMW F10??
Make your own, use your OEM parts and DIY!
      10-30-2011, 05:11 AM   #90
XDEEDUBBX
XDEEDUBBX's Avatar
49
Drives: 535I
wow those came out great! I was going to plasti dip mine..lol
      12-22-2011, 03:15 PM   #91
Shark_535i
Drives: 2011 535i M Sport
Thanks for the DIY info! Just completed mine; 40 minutes with a Torx-25 instead.
Not as easy as on my e39, but looks great on the f10!
      01-09-2012, 09:16 PM   #92
Susoa
4 Star General
Susoa's Avatar
Drives: 2013 M5
Well I went out and gave this a try and no luck. I have a 550 so I wonder if there is less space. After I took the screws out I had maybe an inch to work with. Should I use a long screw driver to push down on the top tabs? How do I get to the bottom ones? Maybe a precision hook shaped tool would work?
Also, It looks like the chrome ring and plastic fins are seperate parts so I could spray the fins black. I have dark graphite so I dont know how it would look totaly blacked out.
Another option is vinyl - Anyone know where I can find black vinyl for the fins?
Thanks for the help!
      02-27-2012, 04:50 PM   #93
ld757
Drives: 2014 BMW 750xi
Great instructions. Thanks. Did you install matte or glossy covers. I can't tell by the picture. Thanks.
      03-22-2012, 02:24 AM   #94
gre8tw8LL
Drives: 2012 F10 535i
Cheapest place is www.getbmwparts.com or JBspeed. Total cost is $130.
      03-22-2012, 02:32 AM   #95
gre8tw8LL
Great post LACSTER!!!! I just installed my grills but took me about 2hrs and a helper as I was using my hands to push on the tab while the other person was pulling on the grill. I was a little worry about the flexibility of the front center as i was pulling it back to reach my hand to push the bottom clips. By any chance, do you have a DIY for the front bumper side reflectors?
      05-03-2012, 11:10 AM   #96
nduckson
Drives: 2011 AW 528i
Nice demo
Great step by step for a common DIY. Thanks!
      05-12-2012, 08:48 PM   #97
blueridger
Drives: 2011 335i
getBMWparts.com has two versions of this grill. It's very hard to tell the difference in the tiny photos they provide. Which ones are you guys using? They have a.) OEM BMW Performance F10 5 Series Gloss Black Grills, and b.) Genuine BMW M Performance Black Kidney Grills
      06-02-2012, 03:54 PM   #98
sonny
Drives: BMW M3 F80 (white alpine)
Originally Posted by LACSTER
Okay so with many pm's asking how to install these grilles I decided to go out today and do the process agian with pics so fellow members can see how easy this is to do. All you need is a Torx-20 screwdriver and about 20 minutes.
First off remove rubber strip in the center on the hood right in front of inside bumber.
Attachment 421827
Once done you should see two hex bolts underneath.
Attachment 421828
Now you can start removing the 6 hex bolts using the Torx-20 screwdriver. The 2 in the center is straight forward but the two right on top of each headlight has a cover the needs to be removed first.
Attachment 421830
There's two clips/locks holding the cover in place. All you need to do is with you fingers just pull the center pin up ( real easy )
Attachment 421831
Below. Repeat on other side
Attachment 421832
Once all screws are removed you'll need to pull the center of the front bumper forward to remove chrome grilles. There's nine clips holding it to the bumper. With one hand just pull the grill out on the portion of the grill where you are pushing the clip down with your other hand.
Attachment 421833
Attachment 421834
Once both grilles are removed you'll see this.
Attachment 421835
Now time to install BMW Performance Grilles.
Attachment 421836
Side by side comparison.
Attachment 421837
Time to put everything back. The two hex bolts on top of the headlights need to be put on first before the clips/lock pins.
Attachment 421838
Then place the clip/lock pin in and press down then put lock pin in to secure.
Attachment 421839
Attachment 421840
The center piece removed in the beginning need to snap back in.
Attachment 421841
Now the extra....... Painting silver trim near the fog lights.
All you have to do to remove the mesh is take two fingers and pull forward on each corner to remove the mesh.
Attachment 421842
Unclip the three parts holding the trim to the mesh.
Attachment 421843
Attachment 421844
Attachment 421845
Paint trim with matte black or gloss spray paint. Your choice. I used matte black then reverse process and install.
Attachment 421846
Here's the completed look.
Attachment 421847
Hope this helps all the DIY'er.
Kevin
Thanks for the. DIY
Sonny
      07-05-2012, 02:47 PM   #99
mmanes1
mmanes1's Avatar
Germany
Drives: F30-320D SPORT
great stuff, i love the PERFORMANCE Tools. . . .
      07-19-2012, 08:27 PM   #100
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
I was changing my grills out for the second time, and it was much easier to pull the front bumper out of the way when it was warm. I suggest doing this mod after the car has been running for a while and the bumper material is warm, much more pliable.
      08-17-2012, 02:55 AM   #101
WST
Drives: F10
Awesome, great info and instructions!!! Can't wait to do the same on my one!!!
      08-19-2012, 05:40 PM   #102
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Originally Posted by Sylon View Post
Now I know I come from the 1 series community, but we have the same directions for the kidney grill install, and I still dont understand the purpose of removing the rubber seal at the top of the bumper. Its not necessary. Just push down on the grill clips and pull the grill out. Thats how it was on my car, never had to remove any screws or seals.
Just take a flathead screwdriver, press down on the plastic tabs in the clips, pull the grills out. The new ones just snap right in.
I started with the best intentions of going through the whole bumper unscrew process, but after reading your post, and a few seconds of energetic test-pulling on the grills, I found that they came out smoothly with no extraordinary force. The Turner Motorsports matte black replacements went in just as easily as the original grills came out. Everything seems snug and correct. Thanks for the idea of not having to unscrew the bumper!
      08-19-2012, 05:46 PM   #103
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Can you please tell me where you can a set of these BMW F10 Black Grilles please.
Kind regards and many thanks for the pictures how to remove the grills.
Turner Motorsport
http://www.turnermotorsport.com/p-50...550i-2011.aspx
      09-08-2012, 12:35 AM   #104
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
Send a message via MSN to mdrobc13 Send a message via Yahoo to mdrobc13
Just did mine and your post saved me time and $$$. At 1st look under the hood of my 550i I was like oh shyt gotta let the dealers do it but then looked on the forum here and found your thread and DIY. Excellent! 20 mins later and a gentle tug with pressure from an auto trim tool on the rear and both grilles are out and the new ones installed. I went with carbon fiber sport grilles I got from Modbargins. Looks really great! Thanks man.
'14 Range Rover Sport SC (Chille/Black) - Mine
'15 BMW M3 (Black/Black) - gone but not forgotten
'16 Cayenne (Black/Black) - Herz
'13 Harley Davidson Dyna Custom - born to ride
      09-11-2012, 04:45 AM   #105
kave
Sweden
12
Drives: BMW 520D Touring 2012
Thank you for this Lacster. I just did it yesterday. My fingers got stuck really good in the grill when trying to pull them out And I really applied pressure on them from inside as well. I imagine this would be even harder when the plastic gets older after a few years time.
      09-11-2012, 09:15 PM   #106
Hill Country F90
Hill Country F90's Avatar
Drives: F90 M5
I just did this in about one minute. After reading all of the posts, I decided to do this when the car was nice and warm. Car was in work parking lot all day in sun (85 degrees), drove about 15 minutes home to find my grills on the front porch fresh from Turner Motorsport.
Came in and cracked a beer, then went out to the garage to gauge how big of a task this would be. Grabbed a hold of the right kidney grill and started to pull outward while wiggling just a bit. Grill came right out. Ditto for the left. Put in my new grills in about the same time.
Must be the temperature of the plastic that made it so easy...that and maybe the fact that it is only a couple weeks old?
2018 F90 M5 (coming soon)
2015 F80 M3
2013 F10 550i MSport
2011 E92 M3
2008 E92 335i
      09-11-2012, 11:49 PM   #107
LACSTER
Drives: Hybrid
Awesome man!!! I like the additional with a beer!!!
      09-12-2012, 03:17 AM   #108
Hill Country F90
Drives: F90 M5
Lacster,
Thanks so much for the thread! I remember that doing this on my e92 M3 was much harder, but also remember doing it in the winter.
Always have to crack open a beer when working on or detailing the ride!
2015 F80 M3
2011 E92 M3
2008 E92 335i
      09-29-2012, 03:20 AM   #109
secret agent
secret agent's Avatar
13
Drives: 428 M Perf & 328 M Perf
Hi there a great DIY.
How did u remove the side blinker frames?
Thx
      11-07-2012, 04:27 PM   #110
VWtoBMW
VWtoBMW's Avatar
Drives: 2013 750i
THe other day I had tried installing my M Performance grills by taking off the screws and clips on the bumper per the DIY process. It was a PITA and I could not get the grills off! I gave up and figured I would try it another time.
Based on feedback I read on here, I took the route of trying to pull them off without doing any removal of screws and clips. I just got back home from a meeting and the engine was hot after having sat in stop and go traffic so I gave it a try. Done! They popped off! The bottom was a bit of a challenge but some force and wiggling, it let loose. Far easier way to do it.
2016 G12 750Li xDrive Singapore Grey on Black with every possible box checked off on the option list ?
