2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Chrome Door Handle Strips.
      11-15-2010, 04:32 AM   #1
SAuchterlonie
Drives: BMW 520
Does anyone know if you can purchase the chrome strips for the door handles?
Cheers
Simon
      01-08-2011, 11:13 PM   #2
elchevere
Drives: 2008 BMW 535i
Simon, did you find anything out....the way I configured my new 535 M-sport, I did not order the Premium 1 package and probably will be getting door handles without the chrome strips...the chrome strips are a very nice addition and match up nicely with the M-sport wheels...did you check with a locak BMW dealer parts department???
      01-10-2011, 01:35 PM   #3
tomjscott
Drives: BMW 520d
Probably need to change the door handles themselves as the chrome strips are recessed.
      01-12-2011, 10:45 AM   #4
SAuchterlonie
Drives: BMW 520
Yeah the stripes arecessed into the handles, just thought someone might have seen some stick on ones...
Cheers
Simon
      08-15-2011, 07:33 PM   #5
Krash7172
Drives: 2014 640Xi GC M
Rather than starting a new DYI, here is what I learned. You can get the inserts out relatively easily. Use a good adhesive remover and a small flat screwdriver. The catch in the front is small. Start there and slowly work your way back. Be careful. It's still unsure if you can get the inserts individually or if you have to purchase an entire handle assembly if one breaks. I will update with the adhesive I used when I get the parts back from paint.
Markings:
Left driver: LL3
Left rear: L4
Right front: R1
Right rear: R4
      08-16-2011, 07:10 PM   #6
Krash7172
I used 3M outdoor mounting tape which you can find at a hardware store. I think it is also the same as trim / molding tape you find at an auto store. It seems to work just fine but it is thicker than the BMW adhesive and 3M 4925 would be what I recommend using to put them back on.
      11-09-2011, 09:00 PM   #7
T-Man
Drives: 535i M Sport
How do you get the adhesive remover behind the chrome? Checked with the dealership and they said that the chrome strip could not be sold by itself. I need to black them out ASAP. Any info would help Thanks
      11-10-2011, 01:25 AM   #8
Krash7172
As far as I know, you still cannot buy the inserts alone so be careful if you wish to proceed.
I used a product called "Liftoff". The bottle has a bit of a nozzle and I did what I could to get it behind the insert. I tried not to use much because I didn't want it going into the handle or door. I took the first one off without any chemicals but the others were easier with the adhesive remover.
As an update, it still looks great. The adhesive I used is good. No regrets. Again, be careful until someone offers replacements.
Hope that helps.
      11-14-2011, 03:52 PM   #9
T-Man
Thanks for the info. I'm going to give it a try as soon as I find a good body shop to do the painting. Did you go flat black or does it have a gloss to it?
      11-15-2011, 04:26 PM   #10
Krash7172
I went with gloss for both the inserts and fender light trim to match my performance grills and shadowline trim. If you are considering the fender trim, do it all at once and save a couple $$.
      11-17-2011, 06:49 AM   #11
Mike30
Drives: 550i M Sport, 6spd
I also had gloss 3M tape professionally installed. It did not required insert's removal. So far holding just fine
Past: E39 528i, E46 M3, E60 335i. Present: F10 550i
      03-15-2013, 04:19 AM   #12
asp17
asp17's Avatar
Drives: 2011 F10 550i
Send a message via AIM to asp17
Has there been any update on this like full replacements in colors?
ASP
      03-15-2013, 11:40 PM   #13
omer
Drives: 2016 M
If you going to black them out go with vinyl, you don't need to take the crime handles out.
      03-18-2013, 03:41 PM   #14
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
Found this link: http://www.idfr.com/2010-2012-BMW-5-...-bw203-09c.htm , bit expensive though.
      03-23-2013, 12:12 PM   #15
Approver
Drives: F10
The look good, but they are out of stock. Did you happend to find another stockists?
      03-25-2013, 02:33 PM   #16
top6491
MSGT USMC (Ret)
I haven't ordered any yet. The price needs to come down for four small pieces of plastic for me to purchase, then pay more to have them painted.
      03-25-2013, 02:34 PM   #17
top6491
MSGT USMC (Ret)
In the meantime, I covered them in taillight tint, looks pretty good actually.
      04-28-2013, 04:14 AM   #18
528imsport
528imsport's Avatar
Drives: Msport
nice write up.
I did my by painting them smoke black
