2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum PROBLEM SOLVED!!... If your F10 has hesitation or jerks at 0-10 mph
      06-10-2011, 02:15 PM   #45
ghueser
Drives: 2014 M5
Originally Posted by osxcode View Post
Would this reset procedure work on my 5GT ? My 550i sedan has no issue with jerkiness, but the GT certainly does.
The reset should work with the GT. keep in mind, this just erases the memory and sets the car back inot the learning mode for shifts points. The jerkiness will likely come back, but worth a try.
      06-10-2011, 10:27 PM   #46
DuneMan
Drives: 2011 535i, Sophisto Gray
Originally Posted by ghueser View Post
What is the verdict? Has this solved the issue in your mind?
Sorry to disappoint you... But the car is back to jerking and throttle delay.
So, it wasn't a real fix after all.
      06-11-2011, 12:47 PM   #47
osxcode
osxcode's Avatar
Drives: The M's
Send a message via AIM to osxcode Send a message via Yahoo to osxcode
My GT really isn't that jerky, but it's definitely not as refined as my now week old 550i sedan. It seems to get much smoother after it warms up 20 minutes later, I wouldn't complain if there is no fix though, I very much enjoy the GT.
2016 BMW X5 ///M
2016 BMW M4 ///M Convertible
aLatteHotte - www.aLatteHotte.com - The Future of Coffee
      06-21-2011, 10:46 PM   #48
mlai
mlai's Avatar
Hong Kong
102
Drives: 650GC/E93M3/Lexus LS600HL
Some members over at BF reported that there is now a SI B12 09 11 that seems to rectify the problem. Anybody tried getting their SA to perform the update?
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      06-22-2011, 08:37 AM   #49
yogi799
Drives: '11 535i
Can the moderator change the title of this thread then? (unfortunately)
2011 535i F10 delivered
1999 328i E46 retired
Kill time at the pump!
http://logmympg.com
      06-23-2011, 08:07 AM   #50
sbw
Ultimate Driver
sbw's Avatar
19
Drives: 2015 Porsche Cayman
My 5 never hesitates and the only jerk is the one in the driver's seat.
      06-30-2011, 05:39 AM   #51
redzuanhassan
Drives: None
I was told that if its not working at first time, try to floor the pedal for 30 seconds instead of 5 seconds..
      07-28-2011, 05:36 PM   #52
Sonnie
Bama Hillbilly
Drives: 2011 BMW 528i
The SI B12 09 11 is only for the N55 engines, not the N52 in the 528i.
My dealer said it was "normal" and intended to help with gas mileage.
It is anything but normal to me... it is dangerous and enough 528i owners need to complain to corporate BMW or BMW-NA ... or somewhere higher up than their local service shops.
      07-29-2011, 08:54 AM   #53
flyguy708_2000
535i Dark Graphite Metallic
flyguy708_2000's Avatar
Drives: 2011 F10 535i
There is a fix. I had mine fixed and it runs great now.
Have your dealer look at Bulletin =SI B 12 09 11. It refers to the hesitation issue.
Link: http://www.bmwtis.com/tsb/attachment...411_Slides.pdf
F-10 535i Dark Graphite Metallic, Black Dakota Leather, Cold Weather Package
Drive Assistance Package, Premium Package, Steptronic automatic trans
Dark wood trim, Parking Distance Control, Pro Navigation system.
Delivery date: June 19, 2010
      08-05-2011, 05:05 AM   #54
blaz
blaz's Avatar
Drives: F10 520d
Originally Posted by flyguy708_2000 View Post
pls can you post the full link?
      08-05-2011, 04:52 PM   #55
Sonnie
Bama Hillbilly
This fix is only for the N55 engine... and NOT the 528i.
I did the procedure in the first post and it definitely helped. Not sure how long it will last based on what some others said, but it only take a few minutes to run through it every so often and start fresh, until maybe a more permanent fix is available.
      08-05-2011, 05:15 PM   #56
PR_F10_535
PR_F10_535's Avatar
Drives: 2011 f10 535i
Will try this tonight after work...what the latest on software update?
      08-08-2011, 12:49 PM   #57
Sonnie
Bama Hillbilly
Did it work for you?
I have read a few rumors that some 528i owners were able to get their 528i flashed with the 535i SIB fix and it worked. I would like their dealer and SA name so I can pass it along to my SA for verification.
      08-08-2011, 03:59 PM   #58
PR_F10_535
PR_F10_535's Avatar
So i tried this out after work n to be honest I did not feel a difference so I tried it out again n still no change; idk if I'm doing it wrong but I followed the steps correctly...someone or BMW pls help considering there r soo many suffering from this
      08-08-2011, 08:20 PM   #59
Sonnie
Bama Hillbilly
I read elsewhere that a 528i owner had the latest software update and it did not help this issue. Not sure if it was the SIB 12 9 11 (specifically for the 535i) or the one from a couple a weeks ago... or something else, but it did not help.
More people need to call BMW NA and their SA and complain. The more complaints the better chance of something getting done.
      08-09-2011, 03:07 PM   #60
rmastale
Drives: F10 535i MSport, F15 X5 MSport
Even if temporary; this worked like a charm on my 535i. Drives so much better now from a stop or even a rolling stop.
Thanks!
      08-10-2011, 01:21 PM   #61
SideSwipe_24
Drives: Deep Sea Blue 550i 6spd
I can't wait to try this on my 550i! thanks for the tip !
      12-05-2011, 04:55 PM   #62
mtgbkr200
Drives: 2011 535i
My son's a BMW tech. The holding the throttle down to reset thing is an old wives tale that's been going around for a long time. the only way to reset the adaptive controls is through the computer. I've had the 12 9 11 upgrade and doesn't help either. It's a software issue and BMW needs to get their act together and fix it.
      12-06-2011, 05:42 AM   #63
FrankyD
Drives: F10 525D Sedan
Oh, really!!!
My local BMW workshop chief was actually also a bit sceptic about this trick.. But when he tried it on my car after software update, he got completely excited to see the results! I tried it myself few times and I could feel much more of an effect effect, than after any adaptation resets "through the computer". Trust me, I’ve been around 15 times to the workshop in 2011 with software issues.
One more fact. They flashed my i-drive in Jan 2011 and in April 2011 after which the gearbox stated jerking. They could not do anything to fix it and therefore they changed my gearbox, official reason as announced by the chief rep for my region "there was a possibility that the old gearbox was not understanding correctly the new software"..... Even after installation of the new gearbox and all adaptation resets "through the computer" the gearbox was jerking just like before the change.... It took 1500 km of driving and "throttle down reset thing" to get things came back to almost normal! ... things back to absolute normal after the last software reset in October 2011...
PS. There is way to much electronics in this car and BMW guys, unfortunately, themselves do not know how it works! Not to mention how great of a programmers they are!
      04-02-2012, 03:22 PM   #64
surreybmwdriver
Drives: F10 525d Imperial Blue
My car has the N47 engine and is affected by this hesitation issue. Earlier today I tried the throttle reset solution for the second time (as the hesitation was back) and it worked again, with very clear impact on acceleration and responsiveness.
It is a shame I have to do this every week or so though!
F10 525d Imperial Blue with Oyster/Black Interior
      08-30-2012, 04:32 AM   #65
Marius84
Drives: BMW 535D F10 M-sport
Hi ,
I have some small problem with my 535d. When i start braking , seems like car wants to go forward. Very strange feeling is that normal ?
Please advice.
      08-30-2012, 05:24 AM   #66
BestManWins
BestManWins's Avatar
Singapore
Drives: G30 530i Msports
Hi everybody,
After suffering months of hesitation problem, especially worse when the steering is turned (like while trying to make a u-turn and awaiting oncoming traffic to clear), I tried the TBA and must report that it worked wonderfully!
The sluggish N55 535i sprang back to life! Fuel consumption also improved markedly and throttle response is back to its original state.
But, like many others here, the solution is at best temporary. After a couple of weeks, the same old problem returns.
Its very annoying (and definitely dangerous) to have the engine hunting (much like not all the spark plugs are functioning) and the engine seemed to be stalling anytime - and even more so when one needs to drive away faster than the oncoming traffic in a u-turn.
After numerous flashing of the s/w and seeing no solution, the dealer informed me more than a moth ago that a new software that especially addresses this issue is coming and I am still waiting. When I escalated this issue to the BMW regional rep office, I was told that they are looking at Sept for the new s/w.
That s/w will be the last straw ... somebody's back gotta break!
2011 F10 535i . Xirallic Sophisto Gray . Oyster . Black Dakota Leather. Delivered on 22 Dec 2010
2004 - E60 530i Olivin Green :: 1996 - E39 523i Titanium Silver :: 1992 - E36 318i Vulcangrau :: 1990 - E30 316i Alpine White
