2010 2011 BMW 5 Series Forum F10 DIY: Interior LED Lights |
12-23-2010, 05:39 PM | #1 |
Rep 315
A few people asked me how to replace the interior LED lights so I decided to just do this post to share it with everyone.
I got my LED lights from http://store.ijdmtoy.com/ No Error Code Door light, Glove Compartment, Trunk: very simple, just use a flathead to pop it out Foot light: just pop the left side of the light It should look like this Just twist the cover and will be able to replace the lights Rear dome light: Just have to pop out the clips that surround the doom light. The 2 reading bulbs are harder to get out so I used double sided tape and just tape it to the bulbs and pull them out. Mirror Light: Just pull out the cover and unplug the wire and remove the metal clip. Front Dome Light: You have to remove the black cover and you should see 4 holes. You need to use a small flathead and push the clips that's in the L shape holes. (might require a bit of force) And then you just have to pull the surrounding clips around the dome light. Enjoy your new LED lights |
02-22-2011, 02:02 AM | #3 |
Total Newbie
Rep 47
Great job!
Would you mind sharing exactly which bulbs at ijdmstore you actually used in the install above? Also would using aftermarket bulbs void the BMW warranty? |
02-23-2011, 09:51 PM | #4 | |
Rep 315
I think you will need 14 bulbs for the whole car. And it would void the BMW warranty but you could just change it when you bring your car in. |
03-21-2011, 12:35 AM | #8 |
Rep 12
I bought the 2.0 LED set. They gave me 21 bulbs but I only used 18, which is weird because I don't see any more lights so did they just sell me a 21 bulb kit set when our car only has 18 bulbs? Anyways, the lights look great and thanks kyheang12 for the write up! The pictures helped a lot because I've tried a few times to do this but kept failing. I'm still confused on the front domes so I just kinda did it my own way. The 3M double sided tape does help in removing some of the bulbs!
04-27-2011, 01:37 AM | #9 |
Rep 42
Thanks for the pics. I just did this install today. Very easy. Bulbs were very hot so be careful when removing them. I also found another site the sells the bulbs cheaper if anyone cares.
http://store.ledoption.com/LEDoption...option_l54.htm |
06-12-2011, 10:46 AM | #11 |
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
Hey Respect did the bulbs you used throw any errors? Really want to do these next but don't want the errors. And what color did you get from that site? Thanks
Smoke
LIVE FAST..DRIVE FASTER!! |
06-13-2011, 02:44 AM | #13 | |
Rep 42
no I did not get any error codes after installing the lights. The color I got was Xenon White, which is the color you see in the pics in the original post. They look great in person. I was so happy with the way they made the interior look. |
06-13-2011, 11:03 PM | #14 |
Rep 11
Why would this void warranty....even down to bulbs you need bmw...ie if you replace tires they do not need to be exact brand just runflat etc and of accepted brand
06-17-2011, 01:33 PM | #15 |
Rep 1,793
Cool thanks a lot for the reply. Gonna order them now bro.
07-09-2011, 12:56 PM | #17 |
Rep 26
Hey guys, I'm trying to figure out how to do this on the new X3 (F25). The overhead console looks to be extremely similar if not the same as the F10 (based on these pictures). I'm a little bit confused about changing out the bulbs for the dome light.
When you mentioned inserting a flat head to press on the clips in the L holes, then pulling on the surrounding clips around the dome light, which surrounding clips are you referring to? Is it the clips for the whole overhead console? |
07-26-2011, 05:11 PM | #18 | |
Rep 42
07-28-2011, 10:23 PM | #20 |
Rep 552
That trunk bulb looks interesting. Anyone know what type to get to replace it?
2019 RANGE ROVER SPORT SUPERCHARGED; 2023 JEEP WRANGLER RUBICON 4XE
2022 AUDI R8 PERFORMANCE RWD; 2023 BMW M3 XDRIVE; 2017 MERCEDES G550; 2023 CORVETTE Z06 (ORDERED) |
08-01-2011, 08:33 PM | #21 |
Rep 26
