2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Juice Box aka JB3 stage 1 for N55...initial impressions
      06-17-2011, 11:20 PM   #45
blackberrycubed
Drives: 535i Xdrive
Are you guys placing the main JB3 control unit in the ECU box by removing the cowl etc? Or is there a better place outside, tuck it somewhere? which will also make usb upgrade\change easier.
Guys post up pictures where you tucked it? Thanks
      06-19-2011, 08:58 PM   #46
blackberrycubed
Drives: 535i Xdrive
Originally Posted by AKSteve View Post
It's actually pretty easy to install, except for the MAP sensor. Your option with that one is to either remove the airbox or spend a frustrating period of time trying to get at it with the airbox in place. I wasn't interested in taking my airbox out just for this install, so I went ahead and installed it with the airbox in the way.
First I pulled the airbox up as high as I could by hand, then stuffed a tall, empty plastic water bottle in to hold it up. Then I lifted up the tubes of cables that are strapped to the side of the airbox and moved them out of the way. With the cables out of the way, it's not that hard to slide a thin butter knife or something in there from the side to unclip the original cable from the sensor.
At this point, no matter how frustrating it is, you will motivate yourself to get the JB3 cable in place because your car is now undriveable until you do. I put a blanket across the top of my engine and laid on top of it so I could get into a good position to slide my hand in there and wrestle with getting everything in place. If you have a set of long needle-nose pliers or something like that, it might be easier. Or, if you have small hands, it might not be hard to do it by hand.
In any case, now that i have it installed, I don't plan on messing with it until my next visit to the dealer in 6,000 miles or so. This isn't something you want to do very often. The top photo is a view of the MAP sensor partially tucked underneath the back of the airbox. The second photo is a view from the side after propping up the airbox and moving the attached cables out of the way.
Thanks for posting the pic and giving those tips, it helped alot when I did the MAP sensor. I now have it installed and no codes but do not know where to hide the jb3 brain unit. Where did you put yours and how did you get to that location? You got any pics?
Thanks in Advance.
      06-22-2011, 10:40 PM   #47
Snowrider
Drives: 2011 535i Xdrive Msport
I finally installed mine as well. The map sensor gave me all types of issues. A butter knife did wonders though. I took the car for a spin shortly after, vroom vroom. Car has a significant kick and I feel the shifting is now much cleaner.
Regarding storing the brain unit, where did everyone place there's? I decided to tuck it behind the wires facing the maf sensor.
Obviously the install looked nothing like the video, nor could I find an actual ecu box.
      06-23-2011, 02:45 AM   #48
jaekeem
BMW Noobie
jaekeem's Avatar
Drives: e90 M3 dct, e46 M3, Macan S
Thanks in Advance.
if you pop the hood and look on the passenger side there is a plastic cover on the top left. You can remove those covers since the are clipped on. Then you can get a bit creative on how to place the device in the box.
In my opinion this is not a 15 min install. Plug and play yes.... If you want a clean install take your time placing the brain unit in a good spot.
      06-25-2011, 10:05 AM   #49
Softwareguy14
Drives: 2017 740i M Sport
JB1
Guys,
I have an early build 2011 535 (bought in early Dec2010) and I'm very close to pulling the trigger on this but just wanted to listen to a few more opinions on the good, bad, and ugly of installing this... Of course my concern is not the costs ($425 installed for 30 horses?) but the affect on the warranty. Thanks for the help!
      06-27-2011, 09:13 PM   #50
blackberrycubed
Drives: 535i Xdrive
anyone done 0 to 60 with the stage 1? hopefully big improvement over the stock 5.9!
      06-27-2011, 09:28 PM   #51
78mao
78mao's Avatar
Taiwan
65
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [0.50]
im getting my unit installed this week
maybe i will borrow my friends vbox and see how fast from 0 to 60 is.
      06-28-2011, 12:42 PM   #52
jaekeem
BMW Noobie
jaekeem's Avatar
You should alex! I'll try it too to compare
2011 F10 535i | Build Thread | Power Mods & Dynos
      06-28-2011, 05:55 PM   #53
Bill Bonney
Drives: 535i
I'm considering a Dinan software upgrade when my 535i arrives next month. My question is....
If I get the Dinan software tune, can the dealer tell it's there? It seems if the dealer updates the car software, blowing away the Dinan tune, then I can go back to Dinan for a reinstall at little or no cost.
FWIW, I would be going to the Pleasanton, CA shop. If there are any pros/cons, I'd like to know.
      06-28-2011, 06:55 PM   #54
blackberrycubed
Drives: 535i Xdrive
there is no dinan tune for the 535i as of yet....
      06-28-2011, 07:14 PM   #55
Bill Bonney
Drives: 535i
Ah yes, I saw that.
It would have been better if I asked the question generically. Are the Dinan tunes, in general, detectable while being service at the dealer?
      07-02-2011, 04:44 PM   #56
jaekeem
BMW Noobie
jaekeem's Avatar
I honestly believe no matter what you do it will be detectable. So tunes should be used at your discretion.
For me I really like my stg1 at the moment.
      07-03-2011, 08:46 PM   #57
Needsdecaf
Everything's Bigger in Texas!
Drives: Porsche Tractor
Originally Posted by Bill Bonney View Post
Ah yes, I saw that.
Yes, it is.
The whole point of paying for the Dinan tune is that they will warranty anything that BMW doesn't due to their tune.
      07-04-2011, 12:46 PM   #58
Bill Bonney
Drives: 535i
Thank you.
      07-05-2011, 02:52 PM   #59
blackberrycubed
Drives: 535i Xdrive
Common guys ! post 0 to 60 already !
      07-07-2011, 01:31 AM   #60
eurotechnik
M POWER
eurotechnik's Avatar
      07-10-2011, 05:17 AM   #61
jaekeem
BMW Noobie
jaekeem's Avatar
Just wanted to share with you my times with the vbox I borrowed from my friend. In all I've done 8 pulls 0-60 and I keep spinning tires in first.
First three runs 5.8 / 6.1 / 5.8 seconds
Runs four and five were 5.4 / 5.4 seconds and 30-50mph was 2.1 seconds. This was done Saturday morning.
Then I did three runs just now on the way home 5.4 / 5.3 / 5.5 seconds up to 60, and the best 30-50 time was 1.9 seconds.
I'm slowly starting to get the hang of taking off from a stop. Interesting thing is the first three runs were done without holding down the brake and gassing. But once I started holding down the brake and letting the car rev up and build boost it made a huge difference.
My biggest problem is keeping the tires from spinning once I take off. The other thing I noticed when holding the brake and gas was that the car would hit a max rev differently everytime. My fastest time was when the car revved up over 2.5k rpm but the other ones was 1.8-2k.
Figured since you guys wanted to know that I'd try a few runs for you all.
      07-10-2011, 02:08 PM   #62
blackberrycubed
Drives: 535i Xdrive
Thanks Jakeem !!!
What boost are you running ? Those times seem to be on the slow side. I was expecting with the default boost (2.75) 5.2 or under.
      07-10-2011, 10:50 PM   #63
jaekeem
BMW Noobie
jaekeem's Avatar
Thanks Jakeem !!!
Default boost setting I received from Terry was 3.5 psi. The setting I did those runs with were at 4.5 psi over stock.
If 5.2 seconds or faster is what you were thinking then I don't think stage one would be the answer. My dyno review showed changes from stock boost to 3.5 over stock as <30hp.
      07-10-2011, 10:55 PM   #64
jaekeem
BMW Noobie
jaekeem's Avatar
The inside line review I read said 5.9 seconds for a stock 535. So I think my times came in pretty close and a decent change from stock
      07-11-2011, 03:18 AM   #65
blackberrycubed
Drives: 535i Xdrive
Jakeem: I have been reading that people are putting down better numbers with the boost set to 3.0 on california gas 91. Also read that the turbo lag is much reduced with the lower boost setting.
If you get a chance, try doing a couple of runs with 3.0...
Regardless, thanks for taking the time out and doing the testing.
      07-11-2011, 12:31 PM   #66
jaekeem
BMW Noobie
jaekeem's Avatar
Sure thing I'll set boost to 3.0 and get a few runs in. Maybe with that setting there will be less wheel spin in first.
*crossing fingers*
