2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i Undercar pictures
      07-03-2011, 04:11 PM   #1
Edman951
Edman951's Avatar
Drives: 2014 i3, Capparis White
So i got my new 550i Xdrive with adaptive drive up on my 4 post lift on saturday.
Love to see under my cars and inspect it, and learn more about it.
Here are a few pictures from my iphone. Mostly the exhaust do
The exhaust has a outside diameter of 2-3/4''OD (70mm) from the downpipes all the way to the mufflers. I must say i was impressed on the setup ( for a factory setup) Nice big dual piping all the way, with nice secondary cats. These pipes must flow pretty good. A few crushed areas to add extra clearance room. But not bad at all in general.
I was thinking of making a mid section to bypass the resonator x-pipe with a high flow x-pipe. This could add a bit of sound to the car. The 550 is just to quiet, needs a little more tone!!
My car has the adaptive drive suspension, i took a picture of the rear swaybar hydraulic motor that is located right in the center of the bar, the other edges of the bar is like a normal swaybar, but it has the hyd motor in the middle. This motor must increase and decrease hyd pressure as required by the suspension controler. Pretty cool stuff.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
      07-08-2011, 05:45 PM   #2
'17 750i Msport
'17 750i Msport's Avatar
Drives: 2017 750i M Sport
Very nice...thanks for the pics...agree with you that the car is away too quiet...wish BMW would take a page out of the mercedes V8 cars..all the benz 8 cylinders have great sounding exhausts.. Wonder if just removing the center resonator and replacing with straight pipes/tubes will make a noticable difference.
      07-11-2011, 03:32 PM   #3
SkiingMonkey
Russian Federation
Drives: F10 535i
Can anyone point out the lift points for the rear in these photos? I assume the front point isn't visible in these.
      07-12-2011, 09:29 PM   #4
Edman951
Edman951's Avatar
You don't see the jacking points on these pictures.
The car has 2 plastics square lifting point on each side below the rockers.
      07-12-2011, 10:50 PM   #5
SkiingMonkey
Russian Federation
Drives: F10 535i
I meant the central lifting points, not the jack pads. The beamers of old had a pad under the engine and a brace that in front of the diff that was the place to use seemingly.
      07-12-2011, 11:16 PM   #6
Edman951
Edman951's Avatar
oh sorry, was wondering before how come you asked that,
I should have figured that lol
But i did not notice one
      07-13-2011, 08:24 AM   #7
richb811
richb811's Avatar
311
Drives: 2011 E92 JZB M3, 2000 750iL
Removing the resonator is going to give you a raspy tone which I don't think fits the 5 Series very well. You may also get highway drone which is a killer.
Try an eisenmann system, you will definitely hear the car after installing it.
      07-13-2011, 10:07 PM   #8
Edman951
Edman951's Avatar
Do you have info on the Eisenmann systems?
      07-13-2011, 11:46 PM   #9
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE
Nice.
2016 M5 CP Monaco Blue
2018 ZL1 1LE Hyper Blue
      07-28-2011, 09:18 AM   #10
richb811
richb811's Avatar
311
I do actually
      08-10-2011, 07:51 PM   #11
av689
Drives: ESBII F30 328xi
Looks really good)
