2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions How to Removing Trunk Emblem
      08-02-2011, 08:25 AM   #1
yxc145
Drives: 2011 535i
HI All
Has anyone replaced/removed the trunk emblem for the F10 model?
I have removed the hood emblem and it is not like what the online instruction shows that only held by 2 pins with rubber grommetts. It actually has heavy duty double sided tape.
I couldn't get the trunk emblem off at all. I don't want to force it by damaging the surrounding paint. Can anyone tell me if the trunk emblem is just like the hood one or is it actually part of the trunk?
Thank you all in advance.
      08-02-2011, 09:15 AM   #2
Z4C_luvver
Z4C_luvver's Avatar
Drives: Phoenix Yellow Z4C
Look here!
      08-02-2011, 09:17 AM   #3
yxc145
Drives: 2011 535i
Originally Posted by 5er_luvver View Post
Look here!
Is that the EXACT trunk emblem from the F10 model?
      08-02-2011, 09:50 AM   #4
Z4C_luvver
Z4C_luvver's Avatar
Yep!
      08-02-2011, 09:51 AM   #5
yxc145
Drives: 2011 535i
Yep!
Thank you very much. I wonder why it is so hard to get it off....
      08-02-2011, 10:10 AM   #6
Z4C_luvver
Z4C_luvver's Avatar
Put masking tape around the emblem so you don't damage the paint and try and prise it off with a screwdriver wrapped in a bit of cloth. You know where the pins are (east west), so you know where to concentrate your efforts!
      08-05-2011, 09:26 AM   #7
monogramus
Drives: bmw
>Sorry for my English <
Cut along strow from Mc Donalds, slide under emblem, then pull two ends of strow.
Safe & effective
No Screwdrivers!
      02-05-2014, 10:56 AM   #8
leftymo
Drives: BMW 550i
Safe & effective
No Screwdrivers!
wow, never thought of that... hardly doubt a straw will damage any paint. but threading it through the back of the emblem might be a challenge.
      02-05-2014, 10:15 PM   #9
EZDozzit
Civilian
EZDozzit's Avatar
Drives: 2014 550i M Sport
Use a nylon fishing line. It will cut thru the double sided tape without a problem. Then use Goo-Gone to remove any excess glue.
Warning, I'm prone to sudden attacks of enthusiasm.
__________________________________________
2014 BMW 550i M Sport - Jet Black
2014 BMW X6 35i - Black Sapphire
2011 BMW X5 50i - Titanium Silver (traded)
      02-06-2014, 06:32 AM   #10
metman1490
Drives: 2011 BMW 535i
You might also try a blow drier to heat up the double sided tape to make it a little easier to cut through. I used this method to debadge my 350Z and it worked well. Just a thought.
      03-06-2014, 01:48 PM   #11
jackass
Drives: M5, 911 Turbo s
Originally Posted by yxc145 View Post
HI All
I have the same problem, itīs not coming off. Can someone help, please...?
edit. got it! it was so fu##ing hard...
      04-05-2014, 08:18 PM   #12
dan the man
Drives: 2017 M4 CP
2014 models hood and trunk badges
Just figured out this morning when I was trying to replace it.
For 2014 models the hood and trunk badges are different. The hood one is double sided tape type and the trunk one is the old 2 pins with rubber grommets style.
So....for the front one I had to cut the 2 pins of the aftermarket one and use 3m VHB double sided tape to attache it to the hood. The trunk one was just normal fit.
2017 F82 M4 CP - Black Sapphire Metallic - drive it like you stole it
2014 F10 550xi M Sport - Jet Black - gone
2010 E92 335i Coupe - Black Sapphire Metallic - gone
2004 E46 330xi Sedan - Black Sapphire Metallic - gone
